Question about Karcher Garden
My Karcher high pressure cleaner K 2.180 is not working. When connected to power and water there is water coming out of the lance but it is similar to the pressure of a garden hose and there is NO noi
Have owned for 1 year but this is the second time it has been used. First time the machine turned on (very noisy!) and good water pressure but the next time nothing happened!
  • 33 Answers
SOURCE: I purchased the karcher for
there should have been an adapter from the factory on it. if not you can go to the dealer and get one.
Posted on Apr 21, 2009
  • 32 Answers
SOURCE: repair to old Karcher steam cleaner
q services settle north yorkshire.
01729825656
damian thats me
07970636222
Posted on Jul 04, 2009
  • 56 Answers
SOURCE: Hi, my Karcher steam cleaner is working ok apart
There can be multiple problems with the burner.
Here is a link to a page for troubleshooting burners.
link
Posted on Dec 23, 2009
  • 569 Answers
SOURCE: Pressure hose not working on Karcher pressure washer
A common problem with these is a pressure valve inside the unit that controls the power to the pump. If the unit has not been used for some time the valve can stick.
Does the motor run when you press the trigger?
Please respond and I will advise further. (add a comment)
Posted on Apr 06, 2010
cool78259
  • 228 Answers
SOURCE: My Karcher 330 M has blown two water inlet (
I have a larger gas powered karcher, just make sure the water going to your karcher is not obstructed from its path. on mine i bought a goodyear hose that can be purchased at northern tools or any hardware store. and use it just for pressure washing. good luck!
Posted on Jan 04, 2011
Karcher troubleshooting
check your lance nozzle is not blocked... Remove the lance from the trigger assy and see if you have water coming through then. If you do then the nozzle is blocked :@)
Jul 21, 2014 | Karcher K2.26 Electric Power Washer
Pump working - no pressure from hose. B2002?
Sounds to me that you may have a blocked high pressure jet.
Dec 13, 2009 | Karcher K2.26 Electric Power Washer
Karcher Motor Pulese On and Off
hi mark, you do have a problem with the lance.
you need to disconnect the lance and straighten a paper clip and insert down the nozzle end.
use the machine to wash the dirt in the nozzle backward down the lance.
Dirt only in nozzle end.
if still no good, purchase some nozzle cleaners and file out nozzle very slightly.
Jun 29, 2009 | Garden
My karcher G2000QT WORKS AT HIGH PRESURE FOR A COUPLE OF SECONDS AND THEN STOPS THEN A COUPLE OF SECONDS LATER WILL START AGAIN WHATS GOING ON?
are you making the machine **** for water, if so you have got a air leak on the suction hose.
try force feeding with water by connecting your hose to the mains water hose and see if you can see a water leak.
could be starved of water also,chack the filter
Jun 28, 2009 | Karcher 2500 PSI Pressure Washer
No pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Apr 29, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
I have a Karcher 3.99 Pressure Washer. The motor appears to be working and water is passing through the machine when turned to the detergent application setting. However when the lance is tightened to turn...
Hi I have a karcher 3.99 the motor comes on and water comes out however thre is no pressure i have tested the lance on my brothers washer and this is ok what is wrong
Feb 21, 2009 | Karcher K 5.85 M Electric Pressure Washer
Karcher K2.89
Dear Pajodi,
I just came across your problem. I have just joined FIXYA, and solved various Karcher problems. First of all with all respect, the shop from where you bought the machine, must have told you all necessary instructions to operate your machine.
Now the soap always works on low pressure. So if you have a variable lance, turn it to low pressure. You can also remove the lance, and the soap will surely starts to work. With turbo lances, the soap system does not work. This concludes that the soap does not work when high pressure is used. Bigger machines do spray soap at high and low pressures. But these have regulating knobs, to swith off and on, the soap supply.
Regards,
MG.
Jul 21, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
368 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
