Question about RCA 27R410T 27" TV
UNUSABLE SINGNAL I WAS WATCHING TY ONE DAY AND ALL I GET IS unusable signal LIKE EVERY 15 MIN AND I SHUT THE TY OFF ITS COME BACK FOR 15 MIN ITS WEIRD CAN ANY ONE HELP ME
  • 899 Answers
This and many rca models need a special kind of solder and paste to correct the tuner soldering and some other spots that need this kind of solder that withstands heat better and will hold longer
hope this helps
electech
Posted on Oct 23, 2008
Unusable signal
This is a resolution mismatch problem. One of the devices will not accept the resolution of the other. Try another type of connection or try another input.
Apr 13, 2014 | Sony DVP-SR200P DVD Player
Entivoe DVD player worked fine. The next day, the tray opens, closes and the power turns on and off but the screen says only "Unusable signal", either with or without a video disc in the player. If there...
check the connection cable to the tv, unplug this an replug it to see if this helps.
if you used a cheaper HDMI cable for example the connectors are very wobbly and often make poor contact....
Aug 31, 2010 | Televison & Video
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Dec 05, 2009 | RCA L42WD22 42 in. LCD Television
Unusable signal on rca lcd tv
i have the same problem. i looked all over the net and found out that its the digital board, there is a fuse on the right hand side that has a f1 under it and a cover on it. that is what needs to be replaced, but i havent done that myself yet. have to find the fuse at a electronic store first.
May 10, 2008 | Televison & Video
61" RCA Projection TV, no picture, "unusable signal" message
Read the suggestion of unplugging the TV for at least 4 hours to re-set to factory specs and that took care of it!
Apr 03, 2008 | RCA HD61LPW165 61" Projection HDTV
Unusable signal
A brand and model would be helpful. However if you have some knowledge on TV's you could try replacing the Jungle IC first. This usually controls the AV inputs on a standard CRT. Probable cause, Static on the Video line. Good Luck. Jus004
Dec 07, 2007 | Televison & Video
VID1 showing unusable signal
If you have been using Vid1 with your DVD and have NOT changed it, make sure that the connection has not come loose, just a slight jarring can cause the problem.
2) You might also want to clean the contacts with "contact cleaner" available from a Electronics store.
3) Try a DVD that is a known "good" DVD in your DVD player, if that works, well you know...
Sep 22, 2007 | RCA 27F530T 27" TV
Unusable signal
Substitute video jumper cable....
Re-check video out hook-up on back of DVD......
Sub out DVD with different DVD / VCR for test......................T.
Sep 01, 2007 | GE 31GT660 TV
RCA 27R410T 27" TV Logo
51 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
