Question about Refrigerators
RF266ABPN/XAA temperature indicators flashing the temperature setting, but not cooling in the fridge or freezer
I purchased this used. When I first powered it up, it was so quiet, I thought it wasn't working, but the fan was spinning and the compressor gently vibrating. It took several hours before the temperature indicators moved off of the 68 degrees they were showing upon power-up. When they reached the setpoint temperatures (34 for fridge and -14 for freezer) the actual temperatures were still ambient, although the door handles were cool. Now they flash the set points with no actual cooling.
fridgetech
  • 473 Answers
SOURCE: not cooling
Listen for a clicking noise from the compressor. Could be a bad relay on the compressor, sealed system problem, or faulty board.
Posted on Oct 05, 2007
  • 531 Answers
SOURCE: fridge not cold - freezer cuts out at minus 10 degrees.
check damper control
Posted on Apr 03, 2009
woodchuck789
  • 4070 Answers
SOURCE: Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Posted on Jul 08, 2009
SOURCE: Samsung Cooltech SL-L551DP fridge Freezer.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
The answer to these questions lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason.
The reasons the air is not moving is usually two reasons
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it's own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
  2. The timer device
  3. The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Take care.
Posted on Oct 06, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have an fisher and
Hi and welcome to FixYa, I am Kelly
You should enter the diagnostic mode to determin your fault:
Diagnostic Mode
To enter diagnostic modes, press and hold the MENU button
- then press the UP button for 4 seconds. The PC temperature
will be displayed on the LCD. The actual temperature of the PC is
shown. Note Temperatures are shown in Degrees Centigrade.
PC Sensor Temperature ____
- By pressing the Up button once more, this
will indicate the FC sensor temperature. Note: The "min" indicates minus 12°C
FC Sensor Temperature
- By pressing the Up button once more, this will indicate the Defrost sensor temperature.
Defrost Sensor Temperature
- By pressing the Up button once more, this will indicate the input/Output Status.
Input/Output Status
- Press UP one and two more time, both LCDs display 87.5 but should be ignored
Spare/ Blanks
- Press UP one more time and fault history will be shown.
Fault History
To exit diagnostic mode press MENU button
FAULT CODES:
A wrench symbol and LCD fault code will appear automatically if there is a fault in the
temperature measuring system, defrost system, fans or low ambient heater.
When the PC door is opened an alarm will sound, the number of beeps also indicates
the fault code. Pressing any of the control buttons can deactivate these alarms
Fault Code 1
Reason: On last power up, the power module failed self test.
Primary Action: Replace power module
Fault Code 2
Reason: The previous 2 defrosts were aborted after 30 minutes
Primary Action: Check defrost element
Fault Code 3
Reason: The resistance of all the temperature sensors is outside the normal range
(>45K Ohms)
Primary Action: Check 6 -way Rast connector at power module
Fault Code 4
Fault Code 5
Reason: The resistance of the FC sensors is outside the normal range (>45K Ohms)
Primary Action: Check sensor connector at power module
Fault Code 6
Fault Code 7
Reason: The resistance of the Defrost sensor is outside the normal range (>45K Ohms)
Fault Code 8
Fault Code 9
Reason: The resistance of the PC sensors is outside the normal range (>45K Ohms)
Fault Code 10
Fault Code 11
Reason: The current for the LAH, PC &FC Fan is lower than expected
Primary Action: Check the 6 way fan/LAH, connector at module.
Fault Code 12
Reason: The current for the LAH, PC &FC Fan is higher than expected
Fault Code 13
Reason: LAH is drawing less current than expected.
Primary Action: LAH open circuit
Fault Code 14
Reason: LAH is drawing higher current than expected.
Primary Action: Check wiring connection
Fault Code 15
Reason: PC fan is drawing less current than expected.
Primary Action: PC fan open circuit
Fault Code 16
Reason: PC fan is drawing higher than expected current
Primary Action: Check fan wiring or connections
Fault Code 17
Reason: FC fan is drawing less current than expected.
Primary Action: FC fan open circuit
Fault Code 18
Reason: FC fan is drawing higher current than expected.
Primary Action: Check FC fan & wiring circuit
There are also Ice maker faults that are NOT included above. This should get you started and if everything passes above diagnosis the problem is most likely in your ice maker circuit. The reason I did not include ice maker faults is because they do not cause alarms.
Thanks for choosing FixYa,
Kelly
Posted on Mar 15, 2011
Whirlpool S20b American style f/f. The fridge is very cold and some foods are freezing.
Suggest lowering the refrigerator set point to a lower number such as 3. There is usually an indication of normal setting on the adjustments. Wait 24 hours and check the refrigerator compartment again. Use a thermometer to record the temperatures. The meat compartment will be normal just below freezing. If no success then read the following.
One reason that this occurs is that the unit is working near continuously to reach the freezer temperature. Another words the unit is not capable or cooling the freezer to the prescribed temperature. The result is the excess cooling eventually reaches the refrigerator section causing the refrigerator to freeze. The unit will if this is the case run nearly continuously. This situation is counter intuitive. Freezer not reaching set point, excessive cooling over cools refrigerator therefore refrigerator freezes.
The cause is either the freezer door/seal is not closing or sealing the freezer compartment or the compressor or defrost cycle is not functioning properly.
Check the freezer door seal using a strip of paper. Check to see if air is flowing from the vents in the freezer. Using a thermometer check the temperature of the freezer. Listen for and record if the compressor is running or not.
The normal freezer temperature is around '0' Fahrenheit. If no or little air is flowing from freezer air vents look for ice on the back wall. If ice is present it is likely the auto defrost cycle is not working. Attempt to defrost by hand which requires several hours with everything removed.
Check that lint and dust has not blocked the coils under the unit and that the lower fan is running. Usually warm air exits from the machine grill in the front. Remove the grill and check for air flow and debris buildup. Vacuum if necessary.
And unfortunately if the compressor runs continuously and no air blockage underneath would indicate that the cooling capacity is reduced requiring a major service or replacement.
Hope this helps?
Oct 17, 2016 | Whirlpool Refrigerators
Why would the freezer and fridge temperature indicators flash after a few hours of the unit being switched on?
Hi, some fridge freezers the indicators flash as they have not got to the right temperature yet. Also some freezers have indicators that will start flashing to let you know that the door has been open to long and the freezer temp has risen.
Jan 20, 2016 | Refrigerators
How do I set the temperature for miele fridge freezer pigeon pair kfn 9753 iD?
Wait for it to cool
while it dies you will see flashing bars
wait
it will cool
Feb 24, 2015 | Miele Refrigerators
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
Iceream is not freezing
The temperature is not set to high cooling.First check the temperature setting.But if temperature is set right and still the ice cream is not cooling then .Problem relates to weak compressor. ------------- The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that ice cream is not freezing, so that means freezer is not freezing to its required temperature.------- This indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Kenmore Side by Side Refrigerator
RS2545SH. Fridge side is not cooling. Thanks
I have the same problem....anyone have a fix
Oct 18, 2009 | Samsung Refrigerators
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
Dec 05, 2008 | Samsung RS2578BB Side by Side Refrigerator
Fridge tempertature
I have the same symptom too - freezer temperature flashes at -2. "Power Freezer" or setting it to any other temperature is not working either.
As a result, no ice being made. Please help!
Aug 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
