Question about Ingersoll Rand - Rand - Ir 2545K10FP Type - 30 Electric Driven Air Compressor 10 Hp 120 Gallon Vertical - Fully Packaged
Constantly releases 30psi of air into atmosphere before holding air in the tank
I've removed the plastic cap under the on/off switch to adjust the cut out to 90psi for the tank via the sprung bolt. The compressor will cut out at whatever psi I set it at but will then release a further 30psi of air via a hole directly under the switch housing that connects a thin bronze pipe to the tank (not via the relief valve which is separate and can be operated manually by pulling the end pin.
Why does it release 30psi before it will hold the air in the tank?
If at this point I don't immediately switch the compressor off at the wall, it will continue to release 30psi after cutting out then start again until 90psi is in the tank again before going thru the whole cycle of releasing 30psi again.
Please help me
Regards Peter Bellas
0400 850005
  • 89 Answers
Posted on Mar 20, 2009
Mine does the same damm thing , is it broke or can it be adjusted . It buggs the heck out of me.
Posted on Oct 23, 2008
Bosch CTE4 -20w compressor after releasing all pressure on tank it worn't restart?
pressure cut out switch could be bad or out of adjustment or bent. Find owners manual go to adjustments and follow instrctions for cut out switch adjustment.
Apr 15, 2013 | Bosch CET4-20W Wheeled Twin Angled Tank...
Dewalt Aircompressor model 55168 type 2 is leaking on small hole under the adjustment knob how do you fix it from constantly leaking?
Assuming your talking about the regulater it is repairable. first remove from comp. disassemble bottom needle valve and seat by simply unscrewing round cap on bottom of reg. check to see if the valve is hanging up . normally due to air comp. oil blow by. clean lubracate and check for o ring or seat damage. remove 4 screws from top of reg. first loosen adjustment knob to release spring tention once you remove make sure diapham isnt torn or damaged clean lub. reassemble bottom valve push the needle down to make sure it releases and works properly. reassemble top diaphram spring adjustment and cap test if the through cleaning doesn't work and in my experiance it does 85 % of the time you can buy a rebuild kit for it. hope this helps it is a simple repair
Feb 24, 2013 | Dewalt Air Tools & Compressors
Mac 5200 pumps pressure to 140lbs. then blows off pressure until 120lbs is reached. Cut in is about 115lbs. I have replaced main switch and it still does same. Tried small adjustments on mainswicth st
Check your Safety Valve. It is on the back of the tank sometimes on one of the pressure switch ports or on the air manifold. It has a ring on it to pull to relieve pressure from the tank. The spring in these can get overheated so they don't hold air unless the tank gets over 165 psi. When the motor is running hold the center pin in to see if you have the same results. If the valve holds air until you let it go, replace it.
Jan 30, 2012 | Makita MAC5200 Electric Powered Air...
Compressor will only build up to 30psi,i have checked head gasket its ok reed valves seem ok (not broken)
there should be a pressure regulator on your compressor. sometimes the adjustment is covered by a plastic cap, remove the cap and use a flat screwdriver to turn the pressure regulating screw. clockwise for more pressure or counterclockwise to decrease the pressure. depending on the type of pressure regulator it should only take 2 to 4 complete turns to increase your pressure to 110-120 psi.
Dec 18, 2010 | Air Tools & Compressors
We have a Craftsman 15 gallon air compressor, model # 919.166442. It has worked fine for small jobs for the last few years. Went to turn it on and it simply won't turn on. It won't pressurize. Is this...
Hi, my name is John. Welcome to FixYa. Will it come on at all? Check the outlet circuit breaker, if it comes on at all, check where the line comes form the pump to the tank, there got to be a leak, you may have to remove it in order to check under it. Check for a reset button next to the wire coming to the switch. Thanks for choosing FixYa...John
Nov 24, 2010 | Craftsman 15 gal Air Compressor 3 hp UMC...
Why does my compreeor switch release the air after reaching the required pressure instead of holding the air at the required pressure??? I've just purchased and fitted a new automatic cut off switch to my...
There are two valves in play here. There is a relief valve that opens when the motor kicks off to release the pressure in the compressor itself. That is normal, and is required so that the motor can restart next time without having to overcome that pressure. The other valve is the problem. It is a reed valve between the compressor and the tank. This valve's job is to prevent the air in the tank from returning to the compressor. Think of it as a ratchet for the air. It is this reed valve that has failed.
May 27, 2010 | Northern Industrial 2 Hp Twin Tank...
Pump Will not pump over 30psi.
If the pump cuts off at 30psi the pressure switch needs to be adjusted. Take the cover off and turn the screw clockwise until you get the pressure you want. I like 60psi on mine. If the pump don't cut off, just runs and runs the bladder in your presssure tank could have a hole in it, or you could have an air leak or the bladder needs to be pumped up. There is a valve on the tank like a tire valve and it needs to have air in it. I think it is supposed to be half of the cut out pressure. If it was working ok before I would check this first, that might be all you have to do.
Jan 06, 2010 | Flotec Corrosion Resistant Shallow Well...
My 5hp 30gal upright craftsman compressor will not shut off when its on AUTO i dont know why it runs fine nothing else is wrong with it, it just wont shut off i have set the gauge to 120 psi and it wont...
I am not sure what you are referring to when you say "set the gauge to 120psi". Do you mean you set the pressure switch to 120psi?
Or are you referring to the regulator and regulator gauge?
If you the pressure regulator this will have no effect on your cut-out psi. You must adjust the cut-in cut-out psi setting at the switch.
To make these adjustment first disconnect the power and remove the plastic cap covering the switch. Under it you will find two adjustment screws. Most of the time under the plastic cap itself is a diagram of the switch and an explanation of the adjustments. As long as the cut-in psi is correct then make your adjustment to the cut-off psi only. It should be counter clock wise. I would make a large adjustment down, then small ones back up to the desired psi.
Hope this helps.
If not, one screw adjusts both the cut-in and cut-out psi. The other only affects the cut-out psi.
Aug 18, 2009 | Air Tools & Compressors
I have a Sears 30/50 pump system for my camp in NY and I cannot get the switch to shut off without throwing the breaker. I tried a new pump and it also will not shutoff but the pressure is much better. I...
Drain and clean the supply line using air pressure (min. 30psi). Remove pressure switch cover and adjust pressure setting, usually a nut on top of a coil spring as shown under the switch cover on most pumps.
Jul 10, 2009 | Plumbing
Pressure switch out of adjustment
Before you adjust the perssure switch, make sure that the intank check valve is not leaking pressure back to the pressure switch after it cuts off at 140psi. The check valve should hold pressure at 140psi. Follow the discharge airline to the tank to find the checkvalve (either chrome or brass with large cap). To check for leaking valve, run compressor till shut-off at 140, then unplug the compressor from wall and remove the 1/4 air fitting at the checkvalve and check for leak. If leaking, replace valve and leave the pressure switch at present setting. You should be good to go. Good Luck with your repair and email if you have questions.
Apr 03, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Ingersoll Rand - Rand - Ir 2545K10FP Type - 30 Electric Driven Air Compressor 10 Hp 120 Gallon Vertical - Fully Packaged Logo
167 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
