Question about Dryers
Small plastic toy down lint trap
A small plastic toy fell into the lint trap and is too deep into the machine to get it out with my fingers. Once the electrical supply is disconnected, can we access this toy through one of the back panels? Or should we get a Sears repair person in? I doubt it's still covered under any plan. It is a Kenmore Extra Capacity Heavy Duty dryer. (We bought it used about 5 years ago and we do not have the manual.)
  • Anonymous Feb 17, 2009
    White, old
    Kenmore 80 series is the product
    President:
  • Dryers Master
  • 2,651 Answers
Is the lint filter on the top of unit??? if so you ll need to disconnect power remove the 2 phillips head screws under the lint trap holding it to the main lid. then after removing about 10 1/4in screws from back panel you ll see a metal sleeve running down the back of the unit( the lint filter actually slides in to it) ending in a circular shape below. remove perhaps 4 more screws holding that panel on and youll gain acess to retrive whatever has fallen down there. easy enough to do yourdself no need to call in a professional
Posted on Oct 23, 2008
Small toy accidently fell down dryer vent. What to do? Afraid to turn dryer on. Help
To get to where the toy fell on this unit is a little involved. Unplug unit. take out the lint filter and gently turn the machine upside down hoping the object will fall out if not you will need to take the back off the unit and loosen or remove the blower chute to get at the blower wheel and your missplaced object
Good luck...
Aug 10, 2010 | KitchenAid KGYS700LQ Gas Dryer
Water leakage after cleaning lint trap
make sure that when you replace your filter that there is no obstruction in the filter thread(small stone), i have had many problems with this,if the drain light keeps comming on then check the waste pipe stand.
Apr 07, 2010 | Miele W1926A Front Load Washer
How do I remove the lint trap holder. I have lint
you have to remove the top then the control pannel then the entire front. are you ready for this?
Jan 08, 2010 | GE Washing Machines
Object fell in lint trap
GO TO A HARDWARE STORE AND ASK FOR A TELESCOPEC MAGNET USE THIS REMOVE CLIPPER FROM TRAP .
Nov 30, 2009 | Dryers
I turn the start button and the dryer makes an awful clunky sound. The belt seems to be intact. I just thoroughly cleaned out the lint trap and line running outside on Saturday and this problem occurred...
Do you mean you took a brush and cleaned out the vent below the lint trap?If so yes you probably filled the blower wheel housing full.Hope this helps,have a great Thanksgiving.
Nov 25, 2009 | Televison & Video
A clothes pin and piece of paper fell down the lint trap when I was cleaning the screen. How do I reach the pin and paper to get them out?
This may take you awhile to do, but once you get to it you may find a lot more than that down there. You have to remove the back on most all dryers. If the lint trap is on top, there is a metal chute that lint and other objects fall down.Remove the back and you will see what I am talking about.Once this is done, it is fairly easy to remove the collars that go down to the lint hose. You will then be able to clean all of the lint build up down below that gets by the trap.
Good luck, Sincerely, shastalaker7
Oct 30, 2009 | Dryers
Lint is massing toward the bottom of the lint trap
please check your exhaust vent, where the dryer air comes out of the house, this particular pattern is very indicitive of a slow moving exhaust, you may need to clean the duct between the machine and exhaust as well
Oct 22, 2009 | Kenmore 62602 Electric Dryer
Combination washer dryer full laundry center does not heat to dry clothes
1) check the lint trap, and reach way into the dryer to remove all lint.2) Look at the dryer motor, and make sure that it spins freely (toys and small objects fall into the lint trap and drop into fan. While there make sure you remove all lint
Aug 29, 2009 | Frigidaire Dryers
Estate dryer with lint trap on top- a bottle fell down in the hole- how get OUT?
Go to www.repairclinic.com and enter dryer model. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Estate video showing disassembly. The dryer should not be operated with the vent blocked.
Oct 06, 2017 | Dryers
Dryers Logo
625 people viewed this question
Top Dryers Experts
