Question about Samsung Televison & Video
Samsung LN T4666F no picture or sound only multicolored flickering boxes
praky16
  • 744 Answers
SOURCE: Black picture, perfect sound
hi...your convergence IC's have gone bad.
These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 large IC's , probably STK392-040, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.
Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go.
If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!
Hope that helps u alot...
thank u!!!
Posted on May 25, 2009
SOURCE: samsung lcd model LN-T4661F,no picture, no sound,
I have had this problem twice. about 9 months apart. each time i vacumed out the back the tv through the vents. the first time i did this the tv worked right away. the second time the screen went it took a little more. i had to reverse the vacum to blow the air out i blew the air throught the vents and vacumed it. one think i realized was the hole where the stand went made it very easy to accomplish this. the first time it last for a while we will see how it works this time. my unprofiessional opinion is the the dust build up blocks something. if this works for anyone please let me know.
good luck.
Posted on May 30, 2009
ginko
  • 19396 Answers
SOURCE: sound no picture
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
Theinverter is the high voltage board that provides variable power to thebacklight lamp. This is the most common. When inverter is faulty youcan get no picture, or a very dim picture that can only be seen bypointing a torch light with a 45 degree angle on the LCD surface fromvery near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
Thisis quite uncommon, but happens. If the TV had been hit or moved the LCDcable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
Thisis the board that controls the video signal, it is difficult to test,as there is need to read determined values on IC pins. To test thisboard you need to purchase a service manual and follow thetroubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where youconnect the video and audio cables, if a signal board is defective,then you may get no picture on particular inputs located on faultyboard.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on Jul 18, 2009
lukster
  • 217 Answers
SOURCE: samsung LN-T4071F WASHED OUT ON LEFT SIDE WITH
CHECK LVDS CABLE FIRST, TAKE IT OUT OF THE T-CON BOARD FIRST AND RESEAT IT, THEN TAKE IT OUT OF THE MAIN BOARD SECOND, COULD GET LUCKY AND FIX IT, OTHER WISE THE SCREEN IS PROBABLY BAD
Posted on Dec 30, 2009
cschindle725
  • 67 Answers
SOURCE: My Samsung LN-T4061F
The inverter board has gone out
Posted on May 23, 2010
Samsung LN- S5797D left half of picture goes dim and color distorts sometimes a multicolored bar appears and is sometimes fixed by giving it a good smack. Anything I can do to permanently repair?
The TCON board or the LCD panel is faulty. Can confirm by replacing the LCD panel
If you wish to get some details about TCON board troubles and solution ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 24, 2016 | Samsung LN-S5797D 57 in. LCD HDTV
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Samsung LN-S2651D LCD TV no picture
What happens when you turn the TV on? Is there a clicking noise or popping sound?
May 28, 2014 | Samsung LN-T4665F 46 in. LCD Television
Tv made a loud noise and does not work
Sounds like you blew a capacitor on your power supply board. Common problem that is addressed elsewhere on this site. I had the same problem on my Samsung LNT4672F, and replaced the blown or bulging capacitors with better ones. That was about 4 years ago. I now am having other issues with the TV, vertical multicolored bars across the screen, and am seeking resolution (pun intended).
Feb 20, 2013 | Samsung LN-S4692D 46 in. LCD HDTV
Have a Samsung LNS4695 DX LCD about 3 1/2 years old. When powers on will take about 5 secs and then picture but has thin, multicolored vertical lines. After turning off and on a few times, picture is...
yes this is due to bad caps I have replace dozens of caps for samsung tv's you can do it your self or have some body do it for you or ship the power board to me
Sep 04, 2010 | Samsung LN-S4695D 46 in. LCD HDTV
Samsung LN-T4071F WASHED OUT ON LEFT SIDE WITH LINES GOING THRU SCREEN AND PICTURE FLICKERS
Dec 30, 2009 | Samsung LN-T4071F 40 in. LCD HDTV
Samsunb 4051: TV screen turns off sound stays on.
Most likely this set has an "integrated" inverter, as most samsungs do--and this DOES sound like an inverter problem. Make SURE thought, there are no more bad "10 volt" caps on the power supply...ALL of them need to be replaced no matter HOW they look.
Oct 15, 2009 | Samsung LN-S4051D 40 in. LCD Television
Image problem
Its only 3 month old, so its still under warranty. Yes, its a major problem.
Jul 21, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Not supported mode lcd tv samsung lnt4061f
with the PC input or analog SVGA the only 16:9 resolution it supports is 1920x1080, which can be difficult for some older systems to handle. However, on HDMI it should support all the standard HD resolutions.
Dec 29, 2007 | Samsung LN-S2651D 26 in. LCD Television
Horizontal multicolored lines appearing
Open up the TV and unplug and re-plug the connectors to the circuit boards. This is most often caused by a poor connection of the circuit board connectors.
Mar 25, 2017 | Samsung LN-S4092D 40 in. LCD HDTV
Televison & Video Logo
29 people viewed this question
Jerry Greenberg
Jerry Greenberg
