Question about Jenn-Air JES9800BAS Electric Kitchen Range
Oven over heats and gives a 1D11 fault
This weekend my wife put the oven the clean mode. She didnt think the cleaning cycle worked, because when she tried to use the oven after it was over, none of the buttons on the key pad worked. Everytime she pushed a button, feature not available appeared on the display. I cycled the breaker for the range and it fixed that problem. Now when you set the oven up to bake, both bake and broil elements come on. After the oven preheats the bake element will turn off but the broil element stays on. This causes the oven to get very hot, then faults out on 1D11. The range is only five months old.
I have a similar unit with a similar problem, and found the Maytag troubleshooting manual online. Code 1d11 means the the unit reached 600 degrees (not supposed to get that hot). Basically, it had a runaway temperature. The computer does not know why it happened, so it just tells you that it happened by showing code 1d11. But you can tell what went wrong by your description of the problem: the broiler element was turned on without any command from you. Which means the swithc/relay in the electronic control unit is bad. I am guessing it was fried when you ran the oven through the self-cleaning phase (should not get fried with this little of heat--it was defective to begin with). Mine just went bad after 4 years of use. You can get an electronic control unit for this unit for around $170 at Sears online parts store. Notice that Maytag has replaced the old part number for this electronic control unit with a new one, which probably means they had a design flaw and have fixed it.
Posted on May 24, 2012
5 Suggested Answers
  • 833 Answers
SOURCE: Oven will not bake or broil
bann...why did you replace the element? It is possible that the relay or the control circuit were the problems and still are. The hi limit switch is a temperature 'box' which is designed to open the circuit in case of overheating. Rarely a problem. First, these units are 3 wire units. That means 220 volts ... two breakers. They may be part of a linked unit or separate. Turn them BOTH off and then on. Do all of your burners heat properly on high? If you have a voltage tester, you can test to see if the voltage is there. Unplug the unit. The vertical slot is neutral. Each of the other slots with the neutral should light the tester. If not, your problem is outside the stove.
Posted on Dec 12, 2007
  • 370 Answers
SOURCE: Tappan Millennia range's baking component doesn't work.
Your ignitor has gone out or is no longer drawing enough current to open the gas valve. Replace the oven ignitor and it will fix your problem.
Posted on Nov 26, 2008
  • 43501 Answers
SOURCE: My oven is not working properly Went to bake a
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
Posted on Jun 01, 2010
  • 15935 Answers
SOURCE: Kenmore oven baking element replaced wont heat or broil
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Why doesn't oven work after using the self- cleaning mode?
Check for incoming power; you may need to change the heater element.
Sep 11, 2015 | Whirlpool GBS307PD Electric Single Oven
Stuck in clean mode. Ge Spectra xl44 My wife cleaned the over a couple of years ago using the self cleaning mode and ever since then the oven has been stuck in clean mode when we try to use it. I've...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 25, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Our oven will not heat up. Wife did used the self
If you have a problem with your cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Feb 15, 2010 | Whirlpool RBS305PDS Electric Single Oven
I ran a cleaning cycle on the lower oven. Now it won't heat
the answer is the thermal sensor, mine has gone bad everytime I clean the oven. Solution, run a fan on the oven while you are self cleaning, this keeps the outside heat away from the unit. Pain to replace the sensor, its in the middle back of the oven, have to pull the whole unit out.
Sep 24, 2009 | Whirlpool RBD306PD Electric Double Oven
Self cleaning oven won't start self clean mode
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven does not heat
I would suggest that you check the oven element, it sounds as though it is faulty to me.
Dec 14, 2008 | Ovens
Whirlpool Double Oven RBD305PDB7 - Upper Oven Won't Heat
I have the single oven of this style and I had to replace the thermocouple (part number 4450934) on the back of the oven three times (used the cleaning cycle three times). After using the cleaning cycle, the oven would not heat so each time I had to pull the oven out from the wall to access the back so I could change the part. Once a new part was put on the back of the oven, it worked fine. To pull the oven out, open the oven door and look down by the doors hinges. On each side you will see a screw that's holding the side molding on. Remove the screws and then the molding. That will give you access to the screws that hold the oven into the framing around the oven. Remove the screws and then you can pull the oven out to access the back to change the thermocouple. The oven is heavy so you may want some help to get out. It is not a one man job, maybe a one man and wife job. It is heavy. I hope this helps. Better late than never.
Aug 23, 2008 | Whirlpool RBS305PD Electric Single Oven
OVEN will not heat
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Feb 24, 2008 | KitchenAid KEBC107 Electric Single Oven
Jenn-Air JES9800BAS Electric Kitchen Range Logo
1,255 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
