Question about Video Game Consoles & Games
B button dont work on my mad catz2 streeing wheel
Streeing wheel
pump might be going out
Sep 06, 2013 | 1999 Ford Ranger SuperCab
Horn not working when you press on the streeing wheel but will work on key pad for a chevy pickup 2005 year 1500
Check the horn button on the steering wheel if it has continuity or just short out the wires on the switch connections. If there is only one wire on the horn switch, short it to earth to see if the horn works that way. That will indicate if the horn switch is faulty.
May 16, 2011 | 1999 Chevrolet Silverado 1500
5 year old grandson just found his mothers old PS2 and the Mad Catz racing wheel and pedals. Lookig for instructions for wheel/pedals so he can play his PS2 "Cars" game. Wheel doesn't turn car...
Well, the game has to first be compatable for the MAD CaTz Steering Wheel. The Mad CaTz Steering Wheel is compatable with almost any racing game. Instead Of Using the Pedal for the game, he can use the X button that is ON the Steering wheel.
Feb 16, 2011 | Mad Catz Racer Racing Wheel - PS3 for...
I dont know how to connect my mad catz steering wheel to my xbox 360?
if its wireless there must be a button to press then press the 1 on the xbox , not much help i know
Feb 12, 2011 | Mad Catz XBOX CONTROLLER-MADCATZ MICROCON
Stalls when turning steering wheel
Check your high pressure power streeing switch, sit on the pressure hose, will have two wires going to it.When this switch sense pressure from power streeing computer will increase power to motor by way of RPM.
Jan 08, 2010 | Pontiac Grand Am Cars & Trucks
I have a 94 grand am SE quad and i got a new blinker switch do i have to pull the steering wheel to install
BLINKER FUSE IS UNDER THE DASH ABOVE BRAKE PEDAL TO THE LEFT THERE IS TWO, ONE FOR THE TURN LIGHT,AND ONE FOR THE BLINKER, THIS IS ALL YOU NEED TO GET THE BLINKERS TO WORK ,BUTTON BROKEN AT STREEING WHEEL THEN YES
Oct 29, 2009 | 1994 Pontiac Grand Am
How do you take out airbag on steering? need to tighten streeing wheel nut!
well first thing is take battery cable off so u dont short the air bag sensor on that make of car should have four bolts on the back of steering wheel if it dont take horn botton off and u will see the bolts
Oct 13, 2009 | Renault 181 Cars & Trucks
Upgrade 97 Lexus ES300 Steering wheel to 2001.
Yes you can switch steering wheels, the wood grain is pricy. disconect the battery, wait 5min. remove caps from side of steering wheel. remove torx bolts from air bag assy. Remove wires from air bag. Place air bag upsode down in passenger seat. Make sure steering wheel is straight, remove 19mm nut and remove steering wheel.
Mar 06, 2009 | 1997 Lexus ES 300
Catz2
okay. is your screen clean?
Aug 21, 2008 | Nintendo DS Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
