Question about Klipsch Audio Players & Recorders
I need to find out what size fuse my Klipsch Synergy Sub-10 takes
What size fuse does it take
5 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: My Klipsch synergy subwoofer not working
No sound problem is power amplifier trouble maybe the IC there is defected or cold solder of joint of the parts.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....
Good luck:
Don't forget to rate;
Posted on Jul 22, 2008
  • 56 Answers
SOURCE: klipsch sub 10 keeps blowing fuses
More than likely the power supply switching transistors have fried. Also check the large caps in the primary side of the power supply. If you don't know what your are doing do not attempt to fix the power supply.. very dangerous voltages involved !!! Send it to Klipsch for repair or purchase a Bash replacement panel http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-750
Posted on Apr 13, 2009
  • 1348 Answers
SOURCE: i have the klipsch sub-10 subwoofer, making noise after use
it sounds like the sub is rubbing in the voice coil.
put the speaker in upside down to what it was before.
sometimes that extra bit of downward pull is enough to offset the error.
There are speaker reconing experts out there but it is cheaper to replace the sub itself.
the sub can be replaced for sure.
Posted on Jan 13, 2010
Testimonial: "helpful"
dunnbiker
  • 8546 Answers
SOURCE: Klipsch THX subwoofer just stopped
Heat is the clue.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If you can gain access to the subwoofer driver, disconnect one side of it and see if the amp comes up. The driver miight have shorted.
If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 13, 2011
What is the difference between a ATC fuse and a ATM fuse ?
ATC Fuse
  • ATC fuses were created before ATM fuses. An ATC fuse will be larger than an ATM fuse in physical size. This is considered to be the regular size. An ATC fuse will be found in late-model electronic devices.
ATM Fuse
  • An ATM fuse is considered to be a mini fuse and it came out in the early 1990s. The only difference is it is smaller than an ATC fuse in actual size. It generally cannot be used in a fuse block that is made for an ATC fuse, as it will not fit in properly.
Apr 24, 2015 | 2002 Mazda Protege
Find out what size fuse for my Peugeot partner van
the amp size of the fuse is on the fuse. when you take it out look at it and you will see the number. some of them are on the fuse by the fuse itself.
Mar 02, 2015 | 2006 Peugeot 405
Location of fuse box
There is no way on earth to answer your question without knowing what year, make and model vehicle you are asking about. Also, You ask what size fuse. There are many size fuses. Are you asking about interior lights, signal lights, tail lights, stereo, a/c or what?
Nov 08, 2014 | Cars & Trucks
I'm hooking up my connex4600 turbo to batteries
The fuse size will protect the wiring depending on its size but the question is what amperage does the system draw/use and therefore what size wire is needed and the fuse will be the size of the system amperage draw and the wire size also determined by the amperage draw because if the amperage draw exceeds the capacity of the wire the wire will melt so the fuse should project the wire by cutting the current flow when it exceeds the wire siaze but the system needs the cureetn flow, amperage it is designed to use.
Sep 08, 2014 | Car Audio & Video
What causes back up light fuse to blow when replaced with a new one
the fuse is the wrong size or the manuals suggested fuse is not the correct size. Try replacing the fuse with one size larger . xoxo
Jun 29, 2013 | 2007 Ford Expedition
Concerning fuses, dash board and tail light use same fuse, size 10 fuse could I use a size 20 fuse in its spot and would it be harmful to use truck ?
In a pinch, yes you can use a 20amp in place of a 10amp as long as you have repaired what blew the 10amp.
It needs to be changed to the correct 10amp ASAP.
What happens is the next time, the 20 becomes a 30, becomes a 40 becomes a ... and the wiring harness burns up.
Feb 06, 2018 | 1992 Ford Ranger
My interior dome lights do not work and neither do my power locks, i am sure this is the same fuse, i open the fuse box in the engine and there is a fuse missing and it is labeled done, i read my owners...
Are you putting in the right size fuse? Your owners manual should direct you to what size fuse to place in there, and be sure to use this size. don't use a higher size, as it could cause a short and/or fire.
If you are using the right size fuse.. then you have a short in that system... somewhere.
Jan 07, 2011 | Lexus ES 300 Cars & Trucks
Size fuse for blower motor
Fuse sizes in car commonly using color coding. There red, white, blue etc. The color fuse is indicate current rate. So if your blown fuse has color is red ( for example), just change it 'new' red fuse. Fuse size of blower motor normally will not exceed 20 Amps.
Nov 28, 2010 | 1992 Ford Explorer
My hotpoint tc71 drier blows the plug fuse when switched on what is the problem please
boy the list could be very long but this dyer draws a large amount of current (amps) it should be on its own circuit nothing else on the line at least when the dryer is running you said "fuse" if it is blowing a fuse as opposed to a breaker you could try a Time Delay fuse 15 amps might help please do not put a larger fuse in (even though it fits) the wire size dictates the size of the fuse and increasing fuse size with out changing the wire size to accomodate will create a fire hazzard good luck
Oct 23, 2009 | Hotpoint TDC32 Electric Dryer
Need fuse size for cobra cpi-850
80a fuse should work fine thats the size i have it installed with i used 4 ga. wire
Jan 08, 2009 | Cobra CPI-850 Car Audio Amplifier
354 people viewed this question
Top Klipsch Audio Players & Recorders Experts
Sock Puppet
rhodesworks
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
