Question about Welding Tools
Tecumseh oh 140 solid state module
Is there any way to test the electronic module to ascertain whether it is faulty?
  • 169 Answers
Check that the gap between the flywheel magnet and the module is correct, take the kill wire off the module, hook up a spark tester to the output of the module (spark plug removed), spin the flywheel - No spark means that the module is bad.
Rank this answer please,
Carl
Posted on Dec 02, 2008
Show me the right fuse to replace for the parking lights, dash panel light, and tail lights on a 1999 crown Victoria police interceptor
More then likely the lighting control module is bad , But testing would be a good idea. Look at a wiring diagram at http://www.bbbind.com/free_tsb.html .Do you know how to test solid state electronic componets . Testing basic automotive electrical circuits ? The lighting control module supply's power to turn on the lights. Your best bet , take your vehicle to a ford dealer .
Feb 19, 2017 | 1999 Ford Crown Victoria
First codes were 201 300 301 put in reman comp. codes were202 300 302 another reman comp code is 203. are the remans bad or other problem
You mean P0202 , an what engine does yours have ? 2.6 L ,3.3 L , 3.6 L or 5.7 L ?
DTC P0201, P0202, P0203, P0204, P0205, or P0206
The engine control module (ECM) enables the appropriate fuel injector on the intake stroke for each cylinder. Ignition voltage is supplied directly to the fuel injectors. The ECM controls each fuel injector by grounding the control circuit via a solid state device called a driver. The ECM monitors the status of each driver. If the ECM detects an incorrect voltage for the commanded state of the driver, a fuel injector control DTC sets.
Test your fuel injector for cylinder #3 ! Do you know how to do that ?
You probably changed computers for nothing ! Check out this video on testing fuel injector circuits an checking computer driver that controls the injectors , Oh , by the way P0300 P0301 an P0302 are misfire codes , P0300 is a random misfire an the other two are for cylinders 1&2
Testing Fuel Injectors Fast PCM Driver Testing II without scan tool Did you just replace the PCM - engine computer ? Didn't test anything !
Apr 06, 2015 | 2004 Cadillac CTS
Continuity testing a 34443A solid state iginition
Hello, the only way i test the coil is unplug the ground wire and remove the plug,use a spark checker.pull the rope if no spark than coil is bad,hope this helps..
Jan 22, 2012 | Tecumseh Snowblower Snow Blower Starter...
I have a 6hp tecumseh motor on a go kart that is not getting spark.it has been sitting for a whilei have cleaned the magnet behind cover but im not sure if it is the problem or something with the on/off...
First, try a new plug, then if still a problem ....
Assuming it's not pre-1985, then the ignition is solid state. To test - disconnect the 'kill' wire (usually black, but could be green or even red) coming from behind the cowling. Check for a spark. If OK, your problem is in the wiring. If still no spark, replace the coil.
If your engine IS ancient enough to have points, post back here and I'll advise.
Jul 18, 2010 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I'm wanting to change points & condenser
At that age, it's highly likely that there aren't any! You don't say what engine is fitted, but if it's a Briggs or a Tecumseh, they went solid state in 1982. If that's the case, just replace the coil module.
May 12, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tecumseh HM80 engine, new carb, won't run
Not the solid state ignition. If this were the problem the engine wouldn't start at all. There is some adjustment needed to the carb but without more info, I'm not sure what.
Jun 17, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Was working fine,then i get mess.gps module not responding ???
hi,your gps module-antenna is powered into 12 volt same as unit,have you traced your cable-fuses etc
john
May 20, 2008 | Lowrance GlobalMap 3300C GPS Receiver
Xerox C2424 problem (11,009:46 and 13,008.47)
The second fault is a result of the faulty electronics module. It is a print head heat related issue.
Question is, is the print head also faulty.
That electronics module is very expensive.
But the 11,009 specifically is a failure of the electronics module.
Have had those codes a couple of times.
Most likely the 50 volt source has failed, that maintains the print head heat.
A Drum Assembly thermal error has occurred. The following troubleshooting procedures apply to these errors:
arrwup.gif 13,008.47 The Drum Heater is too hot
Jan 30, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Welding Tools Logo
239 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
