Question about Genie Company Genie Gwkp Keypad Replacement Cover Sandstone 35365t
Genie garage door wont go down, only up - Genie Company Genie Gwkp Keypad Replacement Cover Sandstone 35365t
5 Suggested Answers
SOURCE: Genie garage door comes down and goes back up.
You need a general inspection of all related parts. Make sure none of the track mounting bolts have loosened leaving a misalignment of track segments. CAREFULLY with power off use fingers. turn EACH roller. Something as simple as a bad roller bearing can cause this, even a flat spot on a worn roller. Rollers can be bought at a home supply store. These are 2 most causes.
Posted on Aug 16, 2009
blanchettohd
  • 143 Answers
SOURCE: Genie Garage door will not
If you hit the button on the remote and nothing happens then you may need to code in the remote. On the motor head press the learn button and then press the button on the remote 3 times.
If it looks like the remote will work the opener or it opens the unit but not close it you are experiencing safety sensor problems. Make sure they are aligned. There will be a light on each and each should be on. Check the wiring to them too. They are not polarized. Thanks BB
Posted on Nov 06, 2010
blanchettohd
  • 143 Answers
SOURCE: genie excelerator light won't turn off...
First unwire the wall button. If the light will go off now replace the wall button. If not then you will need to replace the logic board on this unit(genie.com for replacement). Protect this with a surge protector as well 900 joules or higher. Thanks BB
dcramer531
  • 1654 Answers
SOURCE: I have problem in my garage door. I have manual
Does this opener have intellicode opn it? if so it can teach itself the code. What excactly are you wanting, are you needing to find out what the code is on the opener to program the remote? Is your opener a Genie model also? I also need the model of the remote to find the coding info on this.
This is from Genie themselfs. ( Remotes manufactured after 1996 should work with your Intellicode® opener. Pre-1996 remotes use fixed-code sequencing and are not supported by Genie® Intellicode® technology. If you are unsure about when your controller was manufactured, contact us, your local Genie® retailer or your local Genie® ProTM dealer.)
Posted on Jul 25, 2011
I am missing the lever for the bolt
Genie Screw Drive Garage Door Opener Failure - Repair ...
? 6:16
https://www.youtube.com/watch?v=htCkcs1SWvI
Feb 11, 2011 - Uploaded by sengsationa1
Genie Screw Drive Garage Door Opener Failure - Repair - Part 2 .... on the openings of the clip and wrenches ...
Prevent Garage Door Break-Ins - Instructables
www.instructables.com/id/Prevent-Garage-Door-Break-Ins/
InstructablesCatch the emergency release lever (yellow arrow) and gently pull until the ... That may work on many garage door openers, but this one is a Genie screw ... They don't care about breaking windows or making noise because they will be gone before the police arrive. ..... I am sorry to hear this is happening in Iowa now, too.
[PDF]garage door opener assembly/installation manual - Home ...
Dec 02, 2015 | Building Materials
Can I use tje existing screw/rail of the 1/2HP Genie CM86001C and replace the old head with the new PowerMax 1500 head or does the new PowerMax 1500 require a new screw/rail?
No rail wont fit quite right. I would consider a liftmaster/craftsman/chaimberlain with yellow antenna wire. The liftmaster models are 8355 or 8550. Not sure how those model #'s translate to the craftsmans and chaimberlains. These units use 3 frequencies which are chosen automatically by opener radio. This gives you the best option to avoid interference. Genie typalically uses 2, but their fixed, so its a crapshoot to avoid interference. Do not confuse these frequencies with the rolling code feature which is a static frequency with only the "channels" changing.
Mar 28, 2015 | Genie Garage Door. PowerMax 1500 1 HPc DC...
Re-engage carriage on genie garage door opener
good morning Anonymous.
Usually there is a hand-switch where the arm from the door connects to the Drivescrew. It will often have a cord hanging down that you can pull to disengage the arm from the screw. It's there so that you can manually move your door if the power goes out. If the drivescrew spins and nothing moves, then you probably need to get on a stepstool and click the lever back up to re-engage with the screw. Good Luck!
Feb 16, 2015 | Genie Company Genie Garage Door Opener...
Why won't my Genie garage door opener close without going back up.
So it seems the Main garage door unit on the ceiling is ok. The problem is with hand held unit. Usually the circuitry is ok. Try changing the battery. It has helped me. Also make sure the sensor on ceiling unit is not blocked ad is free of cobwebs.
Jun 26, 2013 | Genie Company Garage Door Parts Genie Gwkp...
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
Genie H4000A manual
The garage door will only go down by holding the button on the wall switch
Aug 30, 2012 | Sears Genie Garage Door Gpwk12 Wireless...
Genie auto garage door. closes then imediately re...
GET A COPY OF THE ADJUSTMENT INSTUCTIONS FROM THE GENIE WEB SITE - IT IS A SMALL AND SIMPLE ADJUSTMENT - BUT, IF YOU MESS IT UP THE DOOR WOULD BE UNSAFE.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Genie Directlift garage door opener, wall control problem.
Sounds like a skinned wire on your front or rear limit switches is touching metal. Go over your low voltage wiring and test again.
Jul 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Genie garage door openner won't stop when it goes down or up
there should be a "travel distance" adjustment screw on the opener.
Apr 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Genie Company Genie Gwkp Keypad Replacement Cover Sandstone 35365t Logo
75 people viewed this question
Top Genie Company Home Security Experts
Lawrence Oravetz
Are you a Genie Company Home Security Expert? Answer questions, earn points and help others
