Question about Singer 7462 Mechanical Sewing Machine
Can someone please tell me how to remove the cover of my singer 384 sewing machine. It is stuck in reverse.
  • 46 Answers
Take it to a repairman.
Posted on Oct 24, 2008
My heavy duty Singer sewing machine is stuck in reverse. How do I fix it?
If this machine has a mechanical lever or button it may be internal parts have broken and need to be replaced. this is a common issue with lots of machines. The machine breaks when in reverse and will only sew in reverse. Please have a professional look at the machine and make a repair if necessary.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Singer Sewing Machines
Singer stuck in reverse
Usually it is because someone made a button hole and it is in the 3rd step of the button hole (Step 1 goes forward, Step 2 bartacks the end and Step 3 goes backwards to finish the buttonhole)
Make sure that the machine isn't set on buttonhole and it should begin to sew forward again. Good Luck
Sep 02, 2017 | Singer Sewing Machines
Singer simple sewing machine will not move forward, but will sew reverse with holding the reverse lever down like it is supposed to do. I have been sewing for 50+ years. No simple answers please
Sorry--the only thing I can find is that possibly the auto reverse is turned on. Other than that, perhaps contact Singer directly or take it for service.
3221 SIMPLE Singer Sewing
Jul 08, 2016 | Singer Sewing Machines
How do I remove cover from Singer sewing machine 384?
Generally, there is a separate cover over the thread path, and it's designed to be removed by the user for cleaning, removing thread ends and jams. It's held by one or two screws; if it's one screw, it's in the back of the cover. If it's two, one is in the side, and it's usually covered by a white disk for cosmetic purposes. In that case, push a flat-blade screwdriver on the edge and the other edge will pop out enough for you to grab and remove it. Replacing the disk is not mandatory for the machine to run--it's just for looks. Word to the wise--keep adhesive tape next to you when you do these things, and tape the screws back in or next to their holes when you remove them.
Aug 26, 2014 | Singer 3116 Simple
Singer model 384 sewing machine problem
try adjusting the top tension one number or letter higher till the stitch looks better
also change the needle
clean under the needle plate & in the bobbin area for lint or threads
May 12, 2012 | Singer Sewing Machines
Reverse stitching on a singer 514, HELP!
In the center of the stitch length knob (at the right side of the machine) is a button. You would push that button in to get the machine to reverse.
May 08, 2009 | Singer 7442 Mechanical Sewing Machine
3116 just goes in reverse
It is possible the reverse lever is stuck in the wrong position Move it back to the forward position and see if it will work. Failing that, it's possible the machine is in buttonhole mode. Put it back to normal mode. If it still won't work, you probably have a seized mechanism which will require a technician to repair. If the machine is new enough to be under warranty return it to the store you bought it from for replacement or send it to the Singer warranty center listed on the paperwork that came with your machine.
sewman7
Jun 28, 2008 | Singer 3116 Simple
Singer 7462 Mechanical Sewing Machine Logo
91 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
