Rank: Guru
Rating: 92%, 309 votes
Based on your post above it sounds like the chips you tried were knock offs and not original Sanyo chips. They will look almost identical but the knock off chips will only last a month or two.
Here are some of the most common symptoms of a convergence problem.
- Screen looks 3D
- Colors don't line up
- One or more colors can't be adjusted when using the convergence menu.
- Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You need to replace the convergence chips and convergence resistors. Check the site
www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Comments:
Jun 25, 2009
- Note that most but now all Toshiba projection TV sets use STK392-110 chips.
