Question about Garden
On off switch for a echo gt160ae
No spark at the plug i am puting it a r/c boat please find wiring diegraim
    Sergeant:
  • 316 Answers
Hello, need a operators,parts manual for a stihl,echo chainsaw,hedge trimmer,line trimmer,edger,pole saws,concrete saw, as far as i know thay don't post any of these on line for the consumer,if i had a dealer number than i would be able to provide you with one,these manuals are available through the dealer only,hope this helps.
Posted on Feb 18, 2012
2 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: echo gt 2000 does not have spark and will not start
Your ignition module is probably bad. The part may be as much as $35, but you might want to double check.
Jim
Posted on Jun 21, 2009
I have a CS-4400 Echo chainsaw that wont start. I don't think it is firing
1st thing let's check the spark.remove the plug leave it connected to the wire and ground the side of the plug to the engine. and have someone pull the started rope. watch the gap area of the plug for spark. make sure the plug is gap to factory specs, and hold it by the rubber booth. and the on switch is in the run position. good luck Tom
Mar 09, 2015 | Echo Garden
Echo weed eater not getting any spark?
Remove plug and lay plug base against the cylinder or jumper plug base with jumper wire or battery jumper cables to the cylinder and pull starter cord and see if you have spark on plug, you may have to darken room as some sparks are very hard to see in light. If you have no spark would check the ignition switch by removing wire and make sure the wire does not touch metal. If you still have no spark you probably have bad coil that is if this is not a point type ignition system in which case it could be dirty or pitted points. Would always help if you give model no. When asking questions which we could look up type of machine.
Oct 06, 2017 | Echo Garden
Just got the spark plugs changed and it started idling low and puting?
sounds like a wire is crossed, not making good contact, or plugs are gapped wrong...check all your wire connections..did this help?
Feb 14, 2012 | 2000 Oldsmobile Alero
Not getting fire to plug,replaced ignition still no spark,echo pb-400e
With a good plug and a new switch there are a few remaining basic options. There is either a bad ignition coil or a bad wire or bad connection somewhere.
I hope this helps.
Jul 29, 2011 | Echo Inc. 25.4 CC Backpack Blower
Echo cs-3400 wont start . no spark. what are the primary and secondary coil readings?
if you have no spark
check for faulty plug 1st, then pull kill wire off at kill switch, then check for grounding ht lead ,
then pull kill wire off at armature , if still no spark most likley faulty ignition armature
i suspect the part number you need if its type 1 is 15662639130
replace it and set air gap and reassemble and test
here is web site for parts
http://www.ereplacementparts.com/echo-cs3400-type-chainsaw-parts-c-35043_35970_36021.html
or you could try www.partstree.com , go to echo saws , then find your model
cheers hope it helps
pauly 46
Jan 28, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
I get no spark from the spark plug, replaced it with new one still no spark why, echo hedge cutters
please check kill switch and wire for making ground when they shouldnt make contact in the run position
bassically pull the wire off at the stop switch or at the ignition unit if it fires
faulty stop switch or grounding wir indicated
if not faulty ignition unit indicated
replace ignition unit and assemble
cheers paul
Aug 11, 2010 | Garden
My 2001 toyota echo is cutting out bad I just changed the cat and both o2 sencers and spark plugs and its still doing it help please
Try replacing the spark plug wires if you did not change them when you did the plugs. It is very important that you pull one and only one spark plug wire at a time to keep them in the correct order or your car will misfire. You should change your fuel filter every 30k miles and they are usually about $20. Try the wires first and see what happens.
May 13, 2010 | 2001 Toyota Echo
No spark at spark plug and unit will not start
what kind of gear is it. is there an on off switch? could the wire from the switch be earthed because its worn thru?? check this and see. lets face it. no spark it wont run. try another plug too. sometimes thats the answer
Apr 03, 2010 | Echo Pb - 413t Backpack Blower
Ho spark on a pb 403t backpack blower
Be sure you have no spark ( 90% of the units that come into my shop for repair with the complaint of no spark- have a fuel issue). Be sure the spark plug is good.
If no spark then remove the ground wire from the module and check for spark again. You must use the recoil starter- spinning by hand is not sufficient. If still no spark then replace module. If there is spark with the ground wire disconnected then there is a problem with the kill switch or a bad wire.
Nov 29, 2009 | Echo Garden
Theres no spark, i changed the plug but its still not sparking. I even held the plug and pulled it to double check. Nothing at all.
your switch may be shorting or your black ground wire is shorting. if all is ok on the wiring your coil is bad. replace it. good luck
Oct 15, 2009 | Echo Garden
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
