Question about Kirby G6 Bagged Upright Vacuum
Slef propell is not working correct
The transmission full engages when it is pushed foward almost ripping it out of my hands?
  • Rocky
    Rocky May 11, 2010
    You say "drive lever moves a lot more when you put it in drive?" Do you mean the DRIVE PEDAL is the one that moves?
    Also important is to know if someone had worked on the Kirby before this problem occurred?
    Do not post your answers as "Solution" - it closes the ticket and I accidentally came across your post as it was among "Solved" items.
    Rocky
  • Rocky
    Rocky May 11, 2010
    Need to know few things:
    1. Did you or anyone else worked on the Kirby ?
    2. Model or color of the Kirby
    3. (if no one was working on it) Holding very base of the handle try moving it back and forth (Kirby OFF). I am trying to figure if there is something that does not allow the handle to move smoothly. Turn it on, push it forward (by the base) and release it. Does it keep going when you stop pushing? Does it spin wheels in reverse at all?
  • 35 Answers
The transmission may be out of adjustment.Remove the top cover exposing the pivot handle assembly.On top of the pivot handle assembly,you should clearly see the adjustment screw along with the adjustment spring.Once the adjustment screw is loosened,the spring should automatically adjust the pivot handle to the factory setting.Just make sure the screw is tight
Posted on Dec 16, 2008
Something is wrong with my Hoover U6311-930. It won't self propel but all belts are new.
It could be the transmission is not working properly. Check the linkage from the handle and cable down to the parts that move back and forth to engage the transmission.
Nov 06, 2017 | Hoover Vacuums
The vacuum is not rolling easily. It "drags" on the rug.
Hi There,
When a Hoover Windtunnel becomes hard to push, this usually indicates that self-propelled has stopped working.
When this stops working, it can be caused by several things. The first, most common problem is that the belts have either broken, or stretched to a point where they no longer engage the self-propelled mechanism. In order to verify this, simply make sure that the machine is set to the Carpet setting, turn the machine on, and turn it over on it's side with the handle release pedal reclined (make sure it's not in the upright position). Is the brush at the bottom of the vacuum spinning? If no, this definitely indicates that your belts have gone bad and need to be replaced. There are two belts on your machine, one controls the brush, the other controls the self-propelled mechanism. We've shot a helpful video that walks you through step by step on how to replace the belts.
This is by far the most common problem that we see on your particular model:
The other problem if the belts are installed properly that would cause the self-propelled wouldn't work would be the self-propelled actuator arm. There is a cable that starts at the handle of the vacuum, and runs all the way down to the floor head of the vacuum that controls the transmission. As you pull backwards on the handle of the vacuum, the cable pulls this actuator arm backwards, which then turns the wheels backwards, and when you push forward it turns the wheels forward.
The problem with the way it's designed however, is that if you pick up the vacuum cleaner by the handle of the machine rather then using the carrying handle on the back of the vacuum, it causes too much tension on the actuator arm, and will cause the cable to rip right out of the arm.
This is a VERY common problem on this model. To check and see if this part is broken on your vacuum, step on the handle release pedal so that the handle is in the vacuuming position, push the pedal a second time so the machine lays flat on the floor.
Now if you look right behind the height adjustment switch, and the rug / floor switch where the floor part meets the upright part, you should see a cable that connects into the actuator arm. Pull up and down on the handle and look for movement. Is the cable loose with only a nut attached to it, or is it resting in the actuator arm?
Here's a very helpful link that shows you exactly how to replace the actuator arm:
How to Replace the Actuator Arm on Hoover Self-Propelled Windtunnel
If this didn't help you, and the problem is still happening, please just use the add a comment form here on Fixya and let me know that you're still having problems. I'd be honored to go through and do some more advanced diagnosing with you.
I hope this we helpful to you. If you did find this helpful, please be so kind and leave feedback for me. This is why repair professionals like myself continue to come back and give free repair advice, to get the recognition of a job well done.
Thanks so much,
Chris Jones
GoVacuum.com
May 06, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Hoover wind tunnel won't self propel
There are really two reasons why the self-propelled wouldn't work. It could either be the belts on the vacuum cleaner are stretched or broken. The belts on this model control both the self-propelled transmission, as well as the brush roller. Here's a video that shows you how to inspect the roller brush and belts to make sure that they are installed properly and working. Try this repair first, as this is the easier one to fix.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 17, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Kenmore Upright vaccuum self-propel won't work/engage
No, I can't solve it. However, if you go to SearsPartsDirect.com you can find diagrams for this vacuum. There are three. You can click on "View full size", highlight the image, and print it by saying "Print selection" in the Print dialog box.
Perhaps by looking at how the thing is put together you can begin to figure out where the trouble is. You can also order some of the parts for this venerable machine (but not all of them.)
John
Indiana
Mar 21, 2009 | Kenmore Vacuums
G-4 Kirby self propel unit works in reverse but not foward
Jon,
Here is a helpful link to use to adjust the tranny. About a 7 on the difficulty level.
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
Marci
Dec 10, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Self propelled function
There are few things that may have gone wrong:
First thing to check is if when pushing pedal it moves gears located on the rear axle (you will have to take cover shell off to see that)
If that works fine then primary belt may be broken (see it here). Then just replace entire set to make sure that belt type matches gears
Last - the most expensive problem - the main transmission belt within transmission is broken (then I would recommend replacing entire transmission)
Sep 10, 2008 | Kirby G4 Bagged Upright Vacuum
U6439-900 Self Propell on/off switch
Check the cable to see if it is broke either in the handle or down below, you can see it from the top . If it isn't broke, the part that the cable hooks to (actuator)may be broke. Could be the flat belt, they stretch after awhile and will just slip and drive the transmission or brush roll under load.
Apr 20, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Self propel will go foward, but will not reverse. Seems like handle is all the way extended.
There is a cable that connects to the handle and goes down to the powerdrive transmission. It is visible at the actuator arm on the drive if you look at the bottom of the handle where it pivots on the main housing. It will be on the right hand side, front corner of the handle bottom. You should be able to see the cable connected to the arm of the drive and will move back and forth with the top handle. Sometimes, they break at this connection. The cable may be frayed and broken, or the acuator arm may be broken where the cable connects.
This could also be a simple worn belt problem. The roller is always rotating in a direction that pulls the machine forward and if the belt is worn, the roller will turn sluggishly but still enough to pull forward, but the belt also drives the transmission and a worn belt will not have the capacity to overcome the forces involved to propel the machine backwards. Always change the belt(s) yearly.(on average)
Dec 22, 2007 | Hoover U6630-900 WindTunnel Bagless...
Kirby G6 Bagged Upright Vacuum Logo
197 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
