Question about ESQ Swiss Beacon 07301129 Watch
Instructions on setting time ,date, etc
Would like to know how toset the time,date,etc
Instructions for Armitron All Sport 40/6623 time setting needed.
Here's how you set the 40/6623 M175 for anything. I figured it all out with help from here :). Okay so want to set the alarm? Press MODE once. Then hold it. And use the DATE and ALARM buttons to set the alarm. Press MODE twice and you're done. To set time do the step before this and press MODE once. Use the DATE and ALARM button to set the time. As for the 24 hr deal what you do is hold ALARM and press MODE or hold MODE and press DATE. To turn alarm on/off hold ALARM button and then press the DATE button. To set the date go to time set mode and keep cycling between the hours and mins until you get to the date :). That's all you gotta do :D. I know many of you need the instructions so here it is!!
Apr 02, 2011 | Armitron Digital Sport 406623BLK Watch
I have a screw down crown and dont know how to set the time, date etc
I don't know the make of your watch but typical operation is described below. If the instructions are not correct, then some experimenting will sort out the correct functions- good luck!
Unscrew the crown (anticlockwise) and pull it out.
There are probably two "out" positions, the first one for date, forward(?) for date and backward(?) for day.
The second position should be for time.
Try this and check which
Mar 01, 2010 | Watches
I need to view the manual for Citizen watch #BL8000-54L so I can know how to set the time, date, etc.
ou can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
Feb 15, 2010 | Watches
Rolex oyster perpetual datejust time/date setting instructions
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
Dec 12, 2008 | Rolex Datejust SS
GapKids Digital Watch - Need to know how to set
Light button is A
Mode button is B
Start button is C
Reset button is D
Standard Time Adjustment:
1) To set time, date, etc. press button B three times (assuming you start in standard time display mode)
2) Press button D until the area you'd like to change is flashing. (i.e.: minutes, date, day, etc.)
3) Press button C to change. Press once for one unit increment of change. Hold for 3 seconds for speedy advance.
4) Press D again until the next area you'd like to change is flashing.
5) At completion of changes press Button B to resume standard time display mode.
Nov 29, 2008 | Nike Triax Fly WK0006 009 Watch
Instruction Manual for DZ-7087
hey..i found out how to set the time for the model: diesel dz7087..
all u have to do is press and hold the light button..the when it starts ticking press the mode button repeatedly to set the time,date,etc...when u finished setting everything press the light button and everything will be set..
ciao ciao
Sep 09, 2008 | Diesel Audio Diesel Watch
Setting Bench Watch
Reset Instructions Bench. (BC0013BR)
Time and Location
If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
Alarm
Hold in the light, start and the reset button for a few seconds a screen will appear
press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
Feb 27, 2008 | Watches
Adjusting my timex expedition cr2016
nike T20 lap digital sport watch? Older model. cannot adjust time, date, etc. Know where to get instructions?
Sep 25, 2007 | Nike Super WR0064405 Wrist Watch
ESQ Swiss Beacon 07301129 Watch Logo
Top ESQ Watches Experts
Bill Boyd
Are you an ESQ Watch Expert? Answer questions, earn points and help others
