Question about Frigidaire Refrigerators
Frt21h7asb5 Freezer not freezing
My kenmore upright freezer is running but not freezing is there a reset button
**Freezing gas may have leaked out at some point. Compressor works but freezer not freezing.
**Thermostat setting not suitable for freezing to occur; check and adjust
**Check whether evaporator at the back of your freezer is hot/slightly warm to touch. If it's not; call your freezer service/repair man asap
Oct 14, 2017 | Kenmore Computers & Internet
My freezer will not freeze or cool. I checked the compressor and us cool to the tough but the copper is very hot??? Help please
Repair for a Freezer That Is Running But Not Freezing ...
homeguides.sfgate.com > ... > Other Types of Mortgages
Also, using a freezer to cool hot items or opening the freezer frequently will affect the... the freezer is running but not freezing is improperly packing the contents.
Fix a freezer not freezing but still cold - YouTube
? 1:34
www.youtube.com/watch?v=hCUewYVyiFQ
Aug 19, 2013 - Uploaded by Dave Here My freezer wasn't doing a good job freezing but there was ice on the back ... If not, approximately how often will I need to repeat the process?
Oct 19, 2015 | Refrigerators
MODEL AFG 5496-C FREEZER WHICH BUTTON SHOULD BE LIT WHEN SWITCHED ON TO FREEZE
Green light means that freezer is connected to the mains/electric
Red means that your freezer has not reached minimum working freezing temperature, this is not good news, something may be wrong with your freezer, get it checked by a competent person.
yellow light means that you have switched the fast freeze button on. This yellow switch allows the freezer to run continuously so that the frozen food you brought home from shopping can freeze up quicker. You must not leave this light on for more than 3 hours. It will cause you to waste a lot of electric and will place a lot of stress on the working component in the fridge.
Feb 10, 2015 | Whirlpool 10 cu. ft. / 283 liter Chest...
New 3.6 Danby freezer not freezing
maybe you should go with a different brand???
Feb 04, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Refrig not cooling but freezer is
The freezer door not closing properly would caused the freezer to freeze up
Feb 21, 2018 | Whirlpool GB2SHKRLS Stainless Steel Bottom...
FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Dec 06, 2008 | Refrigerators
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
27 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
