Question about Olympia Office Equipment & Supplies
Need info re Olympia CPD 5420 calculator
I can't replace the paper roll. I don't know how it is supposed to be threaded into the machine.
SOURCE: BOUGHT A HR-8TE CALCULATOR AND CANNOT INSTALL THE PAPER ROLL
First feed it through the back, then cut the paper to form a V then feed this from the bottom and finally when you push feed it grabs the paper! Why they never put this in the instructions is beyond me!
Posted on Oct 27, 2008
SOURCE: Cannot load new paper roll into the calculator so it catches
Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
Then, slide the paper roll onto the feeder arm and you're in business.
Posted on Apr 13, 2009
RonPark
  • 855 Answers
SOURCE: Replacement paper roll size???
Your calculater takes 2 1/4 inch wide standard rolls of paper. These rolls are available all over the place so you should have no trouble finding the rolls.
Posted on Sep 26, 2009
SOURCE: Victor 1520A Calculator
buy my victor 1560 for 7 dollars
Posted on Jun 18, 2010
SOURCE: I have an Olympia CPD
Hold the X time set for 2 sec, then set with % the date to 2000-01-01 . Now set the exact date and press once on te X time set.
The date will be saved and with the % key you can change the view of the date to the one you like .Ex 13-06-2011.
Posted on Jun 13, 2011
Paper won't feed into slot on Canon P26-DH 111
Could not find anything directly about a Canon P26-DH III calculator but, here are steps I found for a similar model. Please let us know if this does the trick for your situation or not. Thanks & Good Luck.!
Installing a Replacement Roll
Move the power switch in the upper right corner of the calculator to the "Off" position. (or wherever it may be on your model)
Push the wire roll holder back so it protrudes from the back of the calculator. Place the replacement roll on the holder so the paper's end extends from the bottom of the roll.
Cut the paper's end diagonally and insert it into the slot in the back of the calculator.
Step
Move the power switch to the "PRT" position to turn on the calculator.
Oct 14, 2017 | Canon Office Equipment & Supplies
What size paper roll is used for TI 5045sv? Can't seem to find it anywhere!
Standard 2-1/4 inch wide plain paper single copy calculator paper rolls, available at Office Depot, Reliable Office Supplies, and many other office supply stores and catalogs. Probably have them at Staples, too.
Mar 24, 2013 | Texas Instruments TI-5045 SVC Calculator
I have an Olympia CPD 430 Desk Calculator - I am unable tro change and save the date
Jan 20, 2011 | Olympia Office Equipment & Supplies
How do I install adding machine paper roll
Slide off the upper cover of the calculator, and cut across the paper roll to form a clean end.
If you are mounting the roll externally (outside of the back of the calculator), then look for a slot in the rear of the calculator, which will accept the paper. Feed the end of the paper through the rear slot, and then into the internal feed slot, and hold the [FEED] key. After that, you can flip the arm back to mount the roll and replace the upper cover.
If you want to place the roll inside of the calculator, then you need to feed from the bottom of the roll into the internal feed slot, and hold the [FEED] key. After you are finished, replace the upper cover.
Nov 23, 2009 | Canon P1-DHV Calculator
How do you load the paper?
Aug 31, 2009 | Canon P23-DH Calculator
Need help replacing the paper roll on a Casio BIG 12-Digit adding machine.
Aug 21, 2009 | Office Equipment & Supplies
Calculator paper roll change, How to?
feed paper throught bottom to top hold down paper feed botton
Jan 26, 2009 | Sharp EL-1801P Calculator
Paper Roll Replacement
i work i mservice ,but for that model i don`t have a holder,but if you want i vill send you a universal holder.
beljin sasa
sbeljin@mgnet.co.yu
Feb 01, 2008 | Victor 1240 Calculator
Changing paper roll on Citizen CX-121 Calculator
At the back between the top cover and bottom cover is a tiny groove to slip the paper in. Simple if you know how. I need a manual please.
Dec 04, 2007 | Office Equipment & Supplies
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Michael Galve
Michael Galve
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
