Question about Sony KP-53HS10 TV
KP53HS10 power supply board
I am looking for a power supply board for KP53HS10 Sony big screen. Do you have an idea where to find it? or who can repare it?
I'm looking for a A board and D board for the Sony KP-53HS10 does anyone know where I can find a good board for a reasonable price?
Posted on Aug 10, 2009
  • 905 Answers
You can check here or leave a post that you are looking for one
http://www.tv.quuq.org/forum/index.php
electech
Posted on Oct 23, 2008
I have a Olevia lt37hvs, When i plug it in the blue(olevia)light comes on then goes off and the screen will be blue for 5-6 second then go black for 1-2 seconds then screen goes blue again and it just...
tried to connect again the supply for main board and disconnect the supply for the inverter board of back light. and turn on the tv, if the indicator stay the inventer board was the cause of voltage drop at the power supply board.
Sep 08, 2012 | Olevia LT37HVS 37 in. LCD HDTV
My Sony kp53hs10 turns on and has a picture but in afew seconds the screen goes blank and I see 7 blinking lights. Any ideas?
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply section..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Sep 14, 2011 | Sony KP-53HS10 TV
I have a Sony KP53HS10 projection tv, occasionally the picture will move in and out around the edges kind of shrinking and growing as if the focus is adjusting. the screen goes blank and the red led in the...
You have a weak capacitors in the power supply. Your description has enabled me to say this is the solution. We TV techs call this "breathing". You may control some of this with raising the contrast and brightness to see the picture stabilize.You will need a TV tech to correct the power supply. I have not worked on projection TVs for some time. This is a classic problem with a classic fix. Thanks for asking and show all hands of support!
Sep 13, 2011 | Sony KP-53HS10 TV
Sony kp53hs10
Try (with your remote) hit Display + Channel 5 + Volume - + Power hit each key within 1 sec of each other and the tv should go into error check mode on the screen and display some data, record that and google.
Mike
Dec 22, 2008 | Sony KP-53HS10 TV
Sony HP53HS10 power supply board
Please mention correct tv model as
HP53HS10 is incorrect.
Oct 23, 2008 | Sony KP-53HS10 TV
Just sound
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
Feb 26, 2008 | Televison & Video
I have a convergence problem
Here is a source for the service manual in pdf fromat. $15
www.user-manuals.com/service-manual-SONY-KP53HS10.html
Jan 03, 2008 | Sony KP-53HS10 TV
I have sony 53 Projection TV Model No KP53HS10
First check the batteries in your remote. if that doesn't work check the setup menu. see if you have any kind of auto on\off, alarm, snooze or enabled. some of Sony's tv's had these features
Oct 08, 2007 | Sony KV-32CS70 32" TV
Need power supply
as service rech has iold you that power supply is defective so it is not necessary to replace whole power supply. you can ask him which part is defective that can be replaced easily. as reputed company like SONY design is excellant.lot of protective ckts are there.parts are easily available.please request your tech. to replace part which is at fault.
Sep 18, 2007 | Sony KP-53HS10 TV
43uwx10b hitachi big screen
Check and see if lights on board in back of set, if non then look for fuses in power supply.
Sep 14, 2007 | Televison & Video
Sony KP-53HS10 TV Logo
265 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
