Question about Lowrance iFINDER H2O C Plus GPS Receiver
My H20c ifinder will not boot up, all it does is the main page flashes on and off. I changed the batteries but nothing changed. What can be the problem?
The last time it was used there were no issues with the GPS
2 Suggested Answers
SOURCE: gps color not bright
I contacted lowrance tech and we came up with the software has a no 1.1.0 the new one has 1.2.0 . We are not sure is changing this will make it brighter,they are going to send me some thing to try.
Thank you for your response
Seayagrandpa@bellsouth.net
Posted on Apr 03, 2008
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
I lost or misplaced my Manual for my H20c, how can I get another one?
Hi try this link below
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/iFINDERHUNTc_0148-771_101905.pdf
Jan 27, 2011 | Lowrance iFINDER H2O C GPS Receiver
Dv6700 boot up problem. power light on. When power on is pressed, the lights in top panel flash once then nothing happens. does not boot. Tried removing battery, reseating RAM nothing worked
Try taking the sys to the BIOS screen and set the defaults after that if the sys doesnt boot up do a system restore by going into the recovery manager page from F11 key on startup to a date when the sys was working fine. IF that doesnt work try enabling the low resolution mode from the advanced boot options from F8. If this doesnt work out than finally you will have to run recovery on the sys.
All the best
Feb 09, 2010 | HP Pavilion dv9000z Notebook
I pluged in the power supply and nothing is happening. The small yellow batery icon came on near the screen and nothing else is happening
Remove the mains power lead and then take out the battery. Hold down the on/off button for 30 seconds to dispel any residual power.
Plug in just the mains lead (AC adapter) and see if the machine will boot on mains power only. If it does let it boot up and then shut it down again. Remove AC and reinsert the battery, plug in AC power again and see if it will boot with the battery in.
If it boots up the problem is sorted, if not then there is a problem with battery so you would have to use it on AC only until you find a replacement battery.
Please post back if need anymore help.
Good luck and regards.
Jan 11, 2010 | Dell Latitude D505 Notebook
CK30 is cold booting when I remove the main battery. The supercap battery status is high and I am not depressing the cold boot button in the battery compartment.
Hello jcapsto. It could be that the backup or 'flash' battery isn't totally charged for one reason or another. This little internal battery keeps a minute current going to the units' flash memory that holds settings and other data and allows warm boots. I would recommend putting your CK30 in it's cradle with the main battery in overnight. Then trying removing the battery and it should spring right back to life. If not, then I would pin the issue on your backup battery and would implore you to contact Intermec or the vendor you purchased it from about replacement/repair. I hope this helps to at least isolate the problem. Good luck!
Jan 08, 2010 | Intermec CK30
I have a 1995 BMW 525 TDS SE AUTO.Where do Ifind the start battery??
The start battery? Or just the battery in general? Typically the 12 volt battery in a car is used to run the starter and that's it.
In your car it is in the back...yes the back, it is nowhere under the front hood so quit looking. Open the trunk, on the right side---and underneath the access panel is the battery.
Oct 31, 2009 | 2001 BMW 5 Series
Ifinder go 2 frozen!
But a Garmin!
Jun 05, 2008 | GPS
Gps color not bright
Apr 02, 2008 | Lowrance GPS
Dell Dimension 8300
Here's Dell's page for changing the battery for a Dimension 8300:
http://support.dell.com/support/edocs/systems/dim8300/sm/battery.htm
Nov 01, 2007 | Dell Dimension 4600 PC Desktop
Lowrance iFINDER  H2O C Plus GPS Receiver Logo
64 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
