Question about Universal Remote Control Omega MX-650 LCD Remote Control
A piece fell off inside the remote
A large piece of the inside of the universal remote came unattached. We can see where it goes, but can't get it to stay.
Need codes for sanyo universal remote
You will need the Sanyo remote control model number, which should be located in small letters on the front. If not, then they will be on the back of the device or possibly inside the battery compartment.
The following website has a large list of programming manuals for universal remote controls: Free Sanyo Universal Remote User Manuals ManualsOnline com
Aug 30, 2015 | Sanyo Televison & Video
Transmission
Hey, I was the person who asked you if you could provide pictures on yahoo answers. Sorry I didn't get back to you in time before it closed but you might want to refer to this video: a500/a518 Transmission Part 4 - Valve Body Installation
Sep 02, 2012 | 1996 Dodge Ram
Is there a diagram for my kelvinator chest freezer? i need to repair a wire that fell off during our recent move
If the wire is green it's a ground wire and can be attached to any metal screw that is near that area
Jun 11, 2012 | Freezers
I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Jan 18, 2012 | Garden
Lost remote need code for universal remote
since most of the disney TVs are manufactured by memorex company ..... from your universal remote control's manual check the codes for memorex brand & try it .... if you don't have manual for your universal remote then from this link http://www.remotecentral.com/features/remotes.htm identify your universal remote & in that check codes for memorex brand & try it .... while searching answer for your question i have found that many people have same problem that is code for universal remote ..... but they never got right answer ......... & also neither same original remote control nor equivalent remote control is available (spare ) ...... so in case if you don't get right code then consider selling of this TV & buying new tv ...........
Oct 28, 2011 | Disney Lightning McQueen TV
Dropped the remote and batteries fell out. Put
Check ur universal remote manual for ur tv codes.Re enter ur tv model universal codes.Ur remote should work again.Try website like 1-800-Remotes factory original.Buy an exact remote to ur tv original remote.Never care for codes agian,because u have the original remote.
May 06, 2010 | Philips Universal PH301S Remote Control
My granddaughter put a toy in printer & a part broke off - thin, translucent piece about 1/4 inch wide by 7 inches long. How do I open up the printer in order to try to put this part back?
The plastic piece you are talking about it just prevents the paper from bending forward when is inserted in the printer. That plastic piece should not cause any paper jams or printing problems. If you do happen to have paper jams maybe a piece of plastic fell inside where the paper goes. Simply turn off the printer, remove the paper and flip the printer upside down and shake it a little that should remove any debris inside the printer.
Jan 31, 2010 | Lexmark X5470 All-In-One InkJet Printer
Phillips Universal remote control fell to floor & will not work
unscrew it and check the broken part and try to put solder in that connection
Sep 11, 2009 | Televison & Video
Universal Remote Control Omega MX-650 LCD Remote Control Logo
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
