Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
I have a pro series 70 24 volt. I have speed 4 and 5. I don't have 1 and 2 and I think 3 is running the same as 4. I've replaced my speed switch (87-MHF15001T) and it does the same thing. I b
  • 10865 Answers
SOURCE: Wring for trolling motor
just hook the two batteries up in series. To do this buy one short cable and use it to hook the positive of one of the batteries to the negative pole of the other. Then use the two remaining poles, one positive and one negative to hook up to the motor. good luck
Posted on Jan 18, 2009
agent91
  • 2100 Answers
SOURCE: my 12/24 volt trolling motor only runs on 12 volts
Did you connect 2 batteries to try the 24 volt version? You have to link them together like a flashlight, positive to neg and then out the other side, for 24 volts, like a golf car.
Posted on Feb 24, 2010
SOURCE: i got a new 70 pound motorguide trolling motor.
Well if it goes in reverse, to me that would suggest that the batteries are wired in reverse? Either that or the controller has gone faulty?
Posted on Mar 03, 2010
wireguy212
  • 1627 Answers
SOURCE: I don't have any slow trolling speeds. Only fast
To hook up to 24 volts you need to join a positive cable from one battery to the source[motor or controller] and the the negative cable goes to the positive of the next of the next battery,then the negative [of battery #2] goes to ground,same for all 24 volt systems.If the slower speeds don't work then the rheostat in the accelerator handle could be at fault,but getting the 24 volts sorted out may fix everything.
Posted on Jul 22, 2010
SOURCE: Ihave a motorguide brute hyper 67 trolling motor
This is most often caused by a faulty 24 Volt, section, (usually damaged output semiconductors, or the drive?) in the speed controller, fault, the only "Fix" is replacement. Simply obtain the entire speed controller and replace it "En Bloc" as it were. You will need to also obtain a service manual so you can disassemble it and obtain the parts numbers for the replacement parts.Otherwise take it to a professional and ask for a "Quote" as to prospective costings and go from there.
Posted on Oct 21, 2011
Peugeot elyseo 125
If the engine doesn't run well it won't make power or speed, will it run well at low speed, when you say you changed the belt and rollers, which belt.
Jun 08, 2013 | Motorcycles
Pro Form 590s
I think you have the wrong category.
May 10, 2013 | Computers & Internet
I have a 2000 pro street custom harley, goes threw the gears fine when not running. Start the engine pull the clutch,put it into gear, stalls without letting out the clutch. I've checked the clutc
Hi Victoriakung, and the usual suspects are:
1. Clutch controls improperly adjusted.
2. Lubricant level too high in primary chaincase.
3. Primary chain badly misaligned.
4. Clutch discs warpped or rust bound.
5. Insufficient clutch spring tension.
Good luck and have nice day.
May 07, 2012 | 2000 Harley Davidson FXDWG Dyna Wide Glide
I cannot find my manual what is the speed to record on the vcr for 8 hours
Unfortunately, most VCR recorders/tapes don't have an 8 hour option. It is 2 hours on SP (standard), LP for 4 hours or EP (SLP, depending on the unit) for 6 hours. (The slower recording speed usually gives poorer video quality.)
You would need a non-standard VCR cassette to get 8 hour recording. If you do have a tape that would hold 3 hours at SP, then use an EP setting to get 8 hours of recording on your VCR. I don't think I've seen any tapes that do that recording length even when VCRs were popular.
I wish that I had better news.
Jan 28, 2012 | Sansui COM311AD 13 in. Combo
My transmission will not shift out of second gear. I've changed the filter for the transmission twice. I also changed the fluid and it hasn't helped. I don't believe that the transmission...
Have you checked to see if the linkage is adjusted correctly? If the linkage is okay, I'm hoping it's gunk stuck inside the valve body or other component.
My old fix,tried and true, is to add one and a half cans of `Sea-Foam' TRANSMISSION TREATMENT to a large transmission(10 qt. capacity or more).
By following the directions on the can and running the ****** thru its paces, it might start working for you. don-ohio
Sep 14, 2011 | Chevrolet Tahoe Cars & Trucks
Brinkman grill 3 burner pro series 8300 won't
To restore gas to the burners, follow the instructions below.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 04, 2011 | Brinkmann Grilling
When i connect 4 batteries in series for a total of 55 Volt, the ups tells me there is a problem with my battery. is the ups overcharging my battery or are the batteries overcharged. i bought them with...
I think UPS' are supposed to run on 12 volt batteries. You must connect them in parallel and not ie series as you are doing now. Connect all the Positives together and all the negatives together to give 12 volts and four times the amperage of each battery for longer backup. With series connection you may burn the system. Please check the manual that came with the UPS.
Nov 17, 2009 | Powercom King Pro 3000VA...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
143 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
Mike Marcotte
Mike Marcotte
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
