Question about Bosch 3107DVS Electric Sanders & Polishers
How do I replace the fan assembly cannot hold armature assembly to get inner bearing out without damaging armature assembly
    Problem Solver:
  • 3 Answers
If you are replacing the fan assembly because the internal thread that holds the rubber/velcro pad has stripped, there might be an alternative.
I had the same problem with my PEX 12AE, which I believe is a similar sander. I found that the hole is threaded a good bit deeper than the screw, so I got a longer screw and so far it's holding ok. If/when that fails, I might try repairing the thread with an insert.
Curious to know how you managed with your sander.
Posted on Feb 11, 2013
  • 3 more comments
  • Lee Hunter Sep 14, 2013
    I have a new fan assembly and have opened the case but can find no obvious way to disconnect the old fan assembly from the shaft. I was hoping to see a slot for an allen wrench down the center hole. Don't think so. If I could get the old one off I could probably get the new one on.
    3107 DVS
  • Lee Hunter Nov 02, 2013
    I tried attaching the pad with a 25mm long bolt. It lasted a few minutes. I can't find a store that carries a 30mm bolt. They carry only even numbers
  • YossiD Nov 03, 2013
    My repair with the longer screw didn't last too long either.
    My repair with the longer screw didn't last too long either. The easiest solution is to replace the entire Fan Assembly (Bosch p/n 2606610901), which is available online for $25.36 from ereplacementparts.com http://www.ereplacementparts.com/fan-ass... If you're a cheapskate like me, and you don't mind a challenge, you can replace only the bushing with the threaded hole, which Bosch calls a "Driver." It is Bosch p/n 2600329027, and you can get it at ereplacementparts.com for $6.88 http://www.ereplacementparts.com/driver-... Note: If you look up your model number on the ereplacementparts.com website you can see a parts diagram which is helpful when disassembling and reassembling the tool. You'll also probably want to replace the bearing (Bosch p/n 2610911986; $7.92 at ereplacementparts). This is actually a standard 6202 bearing that is used, among other things, on many roller blades, so you can probably get it anywhere. Being in Israel I ordered it from Deal Extreme, where it cost $3.00 including wordwide shipping http://dx.com/p/cyt-6202rs-sealed-ball-b... Replacing the Driver in the sander is a bit of a chore. The bearing is press fit on the driver and together they are held into the fan with a round leaf spring (Bosch p/n 2600190059 -http://www.ereplacementparts.com/washer-... With a small screwdriver you can carefully pry the teeth of the spring one by one to slowly inch the driver/spring/bearing assembly out of the fan. Be patient, it will work (at least it did for me). After removing the driver/spring/bearing assembly, you have to separate the three. Due the the press fir I couldn't remove the bearing from the driver. Also, the bearing was damaged (probably part of the reason that the threads in the driver stripped). I ended up having to cut the bearing off using a rotary (Dremel type) tool and a cutting disk. Next step is to assemble the new bearing to the driver shaft, with the spring between them. Make sure the teeth of the spring are pointed away from the bearing so it will side into the fan. I used a vice to press the driver into the bearing and I had a block of wood to protect the end of the driver from damage by the vice. Make sure that everything is straight and square or the driver won't insert properly in the bearing. Assemble the driver/spring/bearing assembly back into the fan. That's much easier since it's a much looser fit. Finally, reassemble the sander and you're done. It's a bit of a process, but it worked for me and it was very rewarding. But as I mentioned, it's much easier to replace the entire Fan Assembly p/n 2606610901. I didn't do that because here in Israel the assembly is much more expensive than at ereplacementparts (who's international shipping is expensive), and it would have been a special order from Bosch in Germany. The driver happened to be available locally from stock at a reasonable price, and as I mentioned above, the bearing was cheap from deal Extreme. I was lucky that I didn't break the leaf spring during disassembly since getting one of those would have been a problem. Anyway, good luck. Let me know how you manage.
I want to remove my table saw motor bosch 4000
Remove the end cap on the motor and remove the 2 carbon brushes. There are 4 screws that hold the motor to the frame and the field and motor housing will pull straight off. The armature will also pull straight out but will require some persuasion and finesse so you don't damage the fan blade.
The most common issue with these is the end armature bearing and with a bearing puller you can perform this with the armature still on the saw. If the bearing is frozen be sure to also check the rubber boot that goes over the bearing and also the motor housing where the bearing sits because it often melts from the friction.
Jan 19, 2014 | Bosch 4000 - 07 Electric Table Saws
Milwaukee 6153-20 grinder is running extremely hot.
Your grinder is either working too hard because of broken or seized bearings or the fan is broken or detached from the armature. Take the brushes out then remove the four screws holding the gear housing on the motor housing. Remove the armature and check the fan and both bearings. If the armature bearings and fan are OK check the bearings and gear teeth in the gear housing.
Jan 31, 2013 | Milwaukee tools Milwaukee Tool 6153-20
How to replace bearings
Must disassemble the pump from the motor. The impeller has RH threads so hold motor armature (do not damage it) and turn impeller CCW to remove it from end of shaft. Hold armature in left hand and rotate impeller with right hand, turning hand on impeller back toward your body, or top of impeller toward you. Don't know how else to describe it. Once you have the impeller off everything should come apart pretty easily.
If impeller is really stuck, you will need to figure out how to hold it evenly all the way around without putting pressure on blades. Strap wrench, home made jig, something that can put more pressure on it than your hand.
You may want to remove the motor field so that you can grasp the armature while removing the impeller, do this by removing the long screws from the end of the motor.
Gently pry, tap, slide, however you can, get the bearings off the armature shaft without damaging any parts attached to it like fans, or starter centrifugal weights. Those things can be removed if needed.
Put new bearings on by sliding over shaft and seating in place by driving against the center race only. Do not drive bearing on by striking the outer race to move the inner race, this will damage the bearing.
Aug 14, 2012 | AO Smith SQ1152 Pool Pump Motor
Reciprocating saw armature removal
usually there is a screw in the diaphragm to hold that assembly tight. You need to remove the brushes first and you might need to GENTLY pry the diaphragm from the motor housing. Then using a soft blow hammer tap the armature out of the plate. I would recommend replacing the bearings and brushes when doing the armature. Let me know if you need more assistance.
Dec 29, 2011 | Saws
Replace armature, I have it all apart except I can't see how to release armature from base.
The armature bearings fit very snugly in their holders. If you have the case split and the belt drive pully off, you just have to pry the armature out of the other bearing holder. If you are replacing the entire armature and the new one has a fan on it just pry it out. If the new armature doesn't have a fan on it be careful not to break the fan or any of the fins. It should pull out smoothly, if it doesn't come out with even pressure you still have something on the armature holding it in.
Mar 04, 2011 | Porter Cable Cable 363 4" x 24" 1500 SPFM...
How to replace rear wheel hub
Sodium based grease is not compatible with lithium based grease. Do not lubricate the wheel bearings without first thoroughly cleaning all old grease from the bearing. Use of incompatible bearing lubricants could result in premature lubricant breakdown.
  1. Raise and support the vehicle safely.
  2. Remove the wheels.
  3. Remove the brake drum or brake disc.
  4. Remove the hub grease cap.
  5. Remove the cotter pin retainer, adjusting nut and flatwasher from the rear wheel spindle. Discard the cotter pin.
  6. Remove the outer bearing and cone assembly.
  7. Remove the rear hub from rear wheel spindle.
  8. Using Seal Remover (TOOL-1175-AC) or equivalent, remove and discard the oil seal.
  9. Remove the inner bearing cone and roller assembly.
  10. Clean the inner and outer bearing cups with solvent. Inspect the bearing cups for scratches, pits, excessive wear and other damage. If the bearing cups are worn or damaged, remove them using a Bearing Cup Puller (T77F-1102A) or equivalent.
To install:
  1. Throughly clean old grease from the surrounding surfaces. If a new hub assembly is being installed, remove the protective coating using degreaser.
  2. If the inner or outer bearing cups were removed, install replacement cups using Bearing Cup Replacer (T73-1202-A) or equivalent. Seat the cups properly in the hub.
If a bearing packer is not available, work as much grease as possible between the rollers and cages. Grease the cone surfaces.
  1. Using a bearing packer, pack the bearing cone and roller assemblies with a premium bearing grease.
  2. Place inner bearing cone and roller assembly in the inner cup. A light film of grease should be included between the lips of the new grease retainer.
  3. Install the retainer with Hub Seal Replacer (T83T-1175-B) or equivalent. Be sure the retainer is properly seated.
Keep the hub centered on the spindle to prevent damage to the retainer and spindle threads.
  1. Install the hub assembly on the spindle.
  2. Install the outer bearing cone and roller assembly on the spindle.
  3. Install the flat washer and nut. Tighten the nut to 18-23 ft. lbs. (24-31 Nm) while rotating the hub to set the end-play. Back off the nut and retighten to 18 inch lbs. (2 Nm).
  4. Install the new cotter pin.
  5. Install hub grease cap.
  6. Install brake drum or disc.
  7. Install the wheels.
  8. Lower the vehicle.
May 04, 2010 | 1998 Ford Windstar
My Bosch 3107dvs random orbital sander stopped working. The screw that holds the sanding disk stripped the part that it screws into. I can't tell from the exploded parts diagram, which part I need to...
Drawing REF: http://www.ereplacementparts.com/bosch-3107dvs-0603310639-random-orbit-sander-parts-c-128_1044_1230.html
To remove the Dust Fan/Coupling Assy. I did the following: I disassembled the plastic housing, removed the Backing Pad Pos. 733 and Dampening Ring Pos. 51.
It seems the Star Washer Pos. 29 holds Bearing Pos. 30. onto the armature shaft and the Coupling Pos. 27 seems to be stuck in Bearing Pos.29. I used a 30mm long M7 hex-head bolt and 11mm ratchet turning clockwise (std RH thread) to pull the Coupling and Star Washer off. Luckily, there was enough thread left in the coupling to do this gear-pulling action with the longer bolt.
To remove the rest of the Fan Assembly I removed the 2 screws Pos. 43 holding the Brush Holder Assembly, Noted the position and removed the Spring Clip Pos. 32, then removed the Armature w/ Fan and Dust Fan/Coupling Assemblies. Firmly gripping the armature I was able to remove the Dust Fan from the armature by turning it clockwise (LH Thread).
Now that I have removed the parts and believe I will be able to reassemble them, I have ordered a new Dust Fan/Coupling Assembly.
I hope this helps someone else having a similar problem.
May 04, 2009 | Bosch 3107DVS Electric Sanders & Polishers
I need to change the bearings on the amature of a dewalt tile saw
I looked at a breakdown and there is no clip. Sometimes the bearing is tough to pull out of the gearcase. Do you have a dead blow hammer? Sometimes I have to apply pressure (pulling) to the armature and tap the gearcase make sure that I hit a solid thick piece of it and generally it will jump out of there. Also in the past with the fan bearing on the armature it is so close to fan that you have to crush it in a vise and use a bearing splitter to remove the inner race, or if you buy the parts from Dewalt you might take it with you and ask them to remove and press the new ones on. Let me know if this doesn't work and I will research further.
Feb 19, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Replacing the fan hub on a kirby classic omega 1CB
I resolved the problem .I found a way to hold the armature shaft still while I unscrewed the pulley drive nut ,which must be removed in order to remove the vacuum fan.
> There probably is a special tool somewhere that would fit over the armature ( the metal part that spins on the shaft of the motor inside the stature) to hold it still ,but since it was suspiciously omitted from the rest of the fan blade parts ,I had to fabricate one myself.
>I happen to have three ,steel blade ,broad paint scrappers which were about 2 to 3 inches wide and thin enough so there blades fitted nicely into the groves that run the length of the armature without damaging it, as would be the case with a narrower screw driver blade .
>Bracing the handles of the 3 scrapper blades in a slot that was in the side of the case ,which was probaby its' intented purpose, held the armature shaft still while I unscrewed the fan nut which happened to have a reverse thread.( turns clockwise to loosen) .
>It unscrewed with ease. Problem solved!
Aug 30, 2008 | Kirby Heritage II Vacuum
Bosch 3107DVS Electric Sanders & Polishers Logo
239 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Awesome12
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
