Question about Apple iPhone Smartphone
Iphone stops playing music when charging with a wall charger
4 Suggested Answers
  • 101 Answers
SOURCE: my iphone is only 5 months old and it wont charge
Sounds like you have a faulty battery but because it is only 5 months you can take it to the apple store and they will replace it.
Posted on Oct 18, 2009
  • 22 Answers
SOURCE: Iphone not charging
Try restoring your phone in itunes. Try the home button on off while connected to computer, then try restarting the computer. Did the battery go dead? Leave iphone Connected to computer for awhile. Mine came back after 6 hours connected.
Posted on Feb 23, 2010
  • 126 Answers
SOURCE: ok my iphone is about to die the 20 % came on for
Probably your Iphone Charging Socket is short. Take it to the APP store and they will be able to help you out.
Please rate if helpful.
Thanks
Posted on Apr 12, 2010
I have the iHome iDM1 .. Does this product charge your iPhone or just play music?
It only plays music. Most devices that will charge your phone will need a power source IE connected to a wall outlet so that it can charge your phone and still have power to play music.
Sep 29, 2013 | Cell Phones
Iphone wont charge
That is about the amount of time when my 3GS stopped charging. The USB charger through the computer stopped working on all computers, and my wall charger for some reason continued to work sporadically. I changed the entire charging dock and that fixed it right up!
Sep 24, 2012 | Apple iPhone 3G
My pod won't hold a charge!
Try plugging it into a wall charger, and make sure you are using a genuine apple cable and wall plug.
Jul 22, 2011 | iPhone Apps
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
How do I charge my new iphone 16GB?
Your new iPhone comes with a USB cable and a wall charger in the box. If you don't have a computer, you can plug the wall charger to any socket in your house and connect your iPhone to the wall charger using the USB cable. However, if you have a computer, you can plug the USB cable to any USB slot from your computer and connect it to your iPhone.
You can also charge your device from any iPhone dock, or even those docks attached to your home theater system.
For more iPhone / iPod touch tips, click here.
Feb 12, 2010 | Apple iPhone (16 GB) Smartphone
Sometimes my Iphone will not charge when i connect it to the wall charger. I just bought my iphone a couple of months ago.
If your iPhone is not charging when you plug it into a wall charger or into you computer's usb port, this is a usb connectivity issue and the connection just needs to be reset. All that needs to be done is plug the iPhone's cable into the phone but don't plug into the computer yet. Hold the phone's select button (the round button with the square) down for about 30 seconds or until the apple appears on the screen. your phone will reload and reset the connection and the computer should recognize the device. Allow the phone to charge for at least 30 minutes before unplugging.
Oct 21, 2009 | Apple iPhone Smartphone
When i charge the mp3, can i play music?
you cannot play music while charging with the usb. you can play while you charge with the wall or car charger.
Apr 03, 2009 | SanDisk Sansa Fuze MP3 Player
MY I9 cell phone doesn't wanna to charge
I had this problem. I replaced the provided wall usb charger. (I kept the cable and replaced the device you plug in the wall, you can get it as an ipod accesory in most stores.)
Dec 13, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
356 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
