Printer Driver for Linux : Epson C1000
I am trying to make work that printer under ubuntu 10.10. But there are only drivers for Epson C900 and Epson C1100. And it did not work so far. By trying to install the driver from Epson C1100, I got an error that some library was missing. I installed that library with synaptic and it still does not work. Does anyone have the correct driver or something which works?
    Top Expert:
  • Office Equip... Master
  • 74,251 Answers
Hello
Try these links.
driverscollection.com/?...ACULASER%20C1000...Epso... - United States
support.epson.ru/upload/library.../howtoinstallprinterdriver_linux.pd
www.downloadsarea.com/Free_driver-epson-aculaser-c1000-linux/
http://www.dataentryjobs.us/67948.html
Posted on Feb 09, 2012
Inky
  • 691 Answers
SOURCE: epson c1100
you may have replaced the cart with a faulty one. It does happen occasionally. Get another cart and swap that one also. If the error clears, return the original full cart for a refund as faulty. If the error does not clear you may have a problem with the receiver on the C dev and it will need an Engineer.
Posted on Sep 17, 2007
  • 5 Answers
SOURCE: Epson Aculaser C1100 E537
Hi there
This suggests a fuser error. This is the hot unit at the rear top of the machine.
Steps are as follows:-
1. Open COVER FUSER.
2. Draw out the COVER RH boss from the hole on COVER FUSER while pushing
COVER RH outward, and remove COVER FUSER.
After removal check coninuity across heater lamp amd thermistor terminals. If either shows anyhing more than 13 Ohms then you need to replace your fuser unit.
Anything more than that requires hands on technical expertise.
Good luck
ivorpits
Posted on Dec 20, 2008
SOURCE: I am new to Linux. How do I instal an Epson SX210
Try this:
http://blog.sadhill.net/impresora-epson-stylus-sx210-en-ubuntu
Posted on Feb 22, 2010
SOURCE: epson aculaser c1100 not printing right hand edge
The problem may well be that the drum needs cleaning. There is a plastic flap on the rhs of the machine. Open that and you can pull a long lever out. You also need to let down the front cover and pull out the lever on the right hand edge that faces you. Then extend the long lever at the side as far as it can go and push it in and out a few times. This should solve the problem. Put the front lever back and close the cover. It took me ages to find this - Epson are not good at highlighting it,.
Posted on May 08, 2010
  • 186 Answers
SOURCE: how exchange cartridge for Epson C1100
Make sure that Ready or Sleep is displayed in the LCD panel.
Select Change Toner X (The letters C, M, Y, or K appear in place of X, indicating the colors Cyan, Magenta, Yellow, and Black.) in the Reset Menu on the control panel.While the cartridge X you selected above moves to the cartridge replacement position, Please Wait appears on the LCD panel.Replace Toner X appears in the LCD panel when the cartridge to be replaced reaches the cartridge replacement position.Then Open Cover A.Push up the right lever to unlock the toner cartridge. Then remove the toner cartridge from the printer.
Posted on May 23, 2010
I had install all the available drivers for Canon LBP 2900 on Ubuntu (Linux) but it's not working. Because the printer model is LBP 2900B instead of LBP 2900. Can you arrange the drivers for LBP 2900B for...
The 2900 driver should work for the 2900E. The problem may be that there is a:
Canon SENSYS i-LBP-2900, and
Canon Laser Shot LBP-2900
Which printer do you have? Which driver did you download?
You can try this site if you can confirm your model:
http://software.canon-europe.com/index.asp
See here for Linux compatibility for Canon products:
http://www.canon-europe.com/Support/software/linux/
Trust this is helpful. Please vote. Thank you. :)
Dec 21, 2010 | Canon LBP2900
I need a driver for my epson c900 for iMac. I cannot find it. Can any one help me?
The mac can pull the driver automattically. Try connecting it to the mac and see if it pulls it
Nov 16, 2010 | Epson AcuLaser C900 Printer
I have ubuntu 10.04 using printer epson lx-300 how to install . Give step by step
http://free-linux-trick.blogspot.com/2009/06/how-to-install-printer-driver-epson-lx.html
Aug 19, 2010 | Epson LX-300+ II Matrix Printer
Can I have driver Epson TM 220 for Linux Ubuntu??
download here...
https://download.epson-biz.com/modules/pos/index.php?page=soft&scat=32
Aug 02, 2010 | Epson TM-U220PB Matrix Printer
I need to define it with linux i want driver plz thanx
Did you try just plugging it in? If you run Ubuntu Karmic, or another recent flavor of linux, it may just work right away. In fact, this has been the case with every printer that I've tried with Ubuntu Karmic. No driver needed! To check, plug in your printer, and wait for a while while Linux recognises your new hardware. If it works, it will say your printer is ready to use.
If this doesn't work, check out this page to see if a driver is available for your printer: http://www.openprinting.org/drivers
Apr 23, 2010 | TallyGenicom 6306 Matrix Printer
Try this:
Jan 21, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Looking for linux drivers for Epson SX215 printer
get the Epson Linux drivers from the Avasys site and install them
http://www.avasys.jp/lx-bin2/linux_e/spc/DL1.do
Nov 18, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Communication error
Remove and rthen reistallthe printer driver from you PC and select the USB connection option.
Sep 24, 2009 | Epson AcuLaser C900 Printer
Epson C900 print shifted down page -
OK after messing about with the drivers I got it to work. I downloaded a driver from Epson singapore and it made no difference. So, I re used the driver from Epson UK and hey presto the thing works again. Why? Good question. Maybe the people in Epson have no idea either.
So, I suggest deleting the driver rebooting the system and reinstalling it. I hope you get it working.
Oct 08, 2007 | Epson AcuLaser C900 Printer
203 people viewed this question
jasbo
jasbo
