Have to press ENTER key eight times with blank screen to make computer boott. Why?
Using Dell Optiplex 280.
  • canbuy
    canbuy Feb 12, 2012
    Thank you to all for the replies. Nothing worked. I took a look at the contacts under the cpu and sure enough they were melted worse. I was using a 20 pin PSU instead of a 24 pin. I need a new motherboard. Actually I don't know if that was the problem since I had been able to get it to work before by readjusting the chip.
  • canbuy
    canbuy Feb 12, 2012
    Thank you to all for the replies. Nothing worked. I took a look at the contacts under the cpu and sure enough they were melted. I was using a 20 pin PSU instead of a 24 pin. I need a new motherboard. Actually I don't know if that was REALLY the problem since I had been able to get it to work before by readjusting the chip.
  • 27,725 Answers
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the delete or F2 key
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps you
Posted on Feb 09, 2012
dopefinger
  • 79 Answers
SOURCE: Can I replace the Dell Optiplex GX 280 motherboard
If you do you will probably need to replace the proccessor also. The proccessor is what is DuoCore and the the motherboard needs to support it
Posted on Jul 31, 2009
ell9
  • 43 Answers
SOURCE: Dell Optiplex GX 280 bios
Hi, take the small round battery out of the mother board for about 5 minutes
and put it back in, and that removes the password,
Posted on Nov 24, 2010
Tech_Mate
  • 680 Answers
SOURCE: I have DELL Optiplex GX
Hi, Thanks for using fixya.
I have the same computer with the same problem. I changed the power supply that cured it for me, I hope it does the same for you.
Terry
Posted on Feb 15, 2011
  • 2226 Answers
SOURCE: please i need your help dell
check the boards compasstors if they have a round top on them or not if they do you need new board check also the power supply as well jim look at fan on cpu if it turns or not
Posted on Apr 05, 2011
  • 10 Answers
SOURCE: i want to reset password
remove the jumper, they have two pins only, turn on the computer, wait for 1 minute. The jumper is located close to the power plug, in the right side,
Posted on Apr 09, 2011
Guide for setting bios options ?
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow keys navigate through options.
Apr 20, 2013 | Dell OptiPlex GX270 PC Desktop
My dell desktop asking for a password
If you want to create a new Basic Input/Output System (BIOS) password on a Dell Optiplex 745, reset the password. Resetting the password also applies if you want to remove an existing BIOS password. BIOS passwords are used to add an additional level of security to your machine. Without the correct BIOS password, your Dell Optiplex 745 will not complete the boot process. The password can be reset whether you know your current password or not.
Turn off your Dell Optiplex 745. Start the computer. Press "F2" the moment the Dell logo appears on the screen. You will only have two to three seconds to press the key. Enter your BIOS password. Navigate to the "Exit" screen. Select the "BIOS Password" setting. Enter your BIOS password and a new password if desired. Do not enter anything in the "New Password" box if you want to remove the BIOS password completely. Press "Enter" to save your password settings. Reset Forgotten Passwords Turn off your Dell Optiplex 745 and remove the power cord from the computer. Disconnect any external hardware and cables. Slide the release latch located on the back of your Optiplex 745. Lift the cover as you slide the latch. Hold the cover firmly and pivot it back on the hinges. Remove the cover from the hinges. Find the "PSWD" jumper on the motherboard. This is a two-pin jumper and should be clearly labeled. Use a flashlight and magnifying glass if you have trouble locating it. Remove the jumper from the motherboard. Replace the cover and slide it into place until the latch snaps into place. Reconnect the power cable and restart your computer. Shut down the computer after it has completely restarted. Disconnect all cables and remove the cover again. Replace the PSWD jumper. Replace the cover. Reconnect all cables and restart your computer.
b> Clearing forgotten passwords http://phubner.eng.ua.edu/Files/Optiplex 745/advfeat.htm - wp1117484
Mar 20, 2013 | Dell OPTIPLEX 745 PC Desktop
Blue screen error 0x0000007B
This error indicates you have a device driver issue especially those related to hard drive and other storage controllers, viruses, data corruption, and sometimes even hardware failures. The first thing you need to do is run the built in diagnostics.
1) Turn the computer off.
2) Turn the computer back on.
3) Immediately at the Dell logo screen, starting tapping the <F12> key once a second until the One Time Boot menu appears (if the computer boots to Windows turn the computer off and try again)
4) At the One Time Boot menu, press the <Down> arrow key to highlight Diagnostics, PSA+ or Enter ePSA, then press <Enter> to begin the PSA.
5) At the One Time Boot menu, press the <Down> arrow key to highlight Diagnostics, PSA+ or Enter ePSA, then press <Enter> to begin the PSA.
6) Write down any Error Codes and Validation codes listed.
Here is a link for Diagnostics pertaining to your model:
http://support.dell.com/support/topics/global.aspx/support/kcs/document?docid=DSN_300428&isLegacy=true
Feb 22, 2013 | Dell OptiPlex 360 Desktop Computer
Can't change bios settings
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
hope this helps
Jul 31, 2012 | Dell OptiPlex 780 PC Desktop
Cannot get into set up to check bios
  • 1
    Turn on your computer. If your computer is already on then reboot it. You need to see the initial display screen to get into the BIOS.
  • 2
    Press the "F2" key when you see the initial screen displaying the BIOS provider information. If using the Optiplex and Dimension models, press the "DEL" key instead of the "F2" key.
  • 3
    Enter password if required. When finished in the BIOS be sure to save your changes. For changes to take place you must reboot the computer.
    Read more: How to Get to BIOS on a Dell Computer ' eHow.com http://www.ehow.com/how_4745021_bios-dell-computer.html#ixzz1VDktcHYE
  • If the bios is password protected you will have to dump the bios batter first, then reconfigure the bois.
    Aug 16, 2011 | Dell Dimension 3100 PC Desktop
    I want to reset password of DELL Optiplex Gx-280 to enable cd rom on boot option .
    Apr 09, 2011 | Dell Optiplex GX280 (99301) Motherboard
    I can not instal w 7 in dell optiplex gx620 please help me
    Things that you can try:
    1. Restart the PC. Once the dell post screen comes up. Immediately press F12 (Keep pressing F12 key while starting up).
    2. Boot Menu will come up on the screen. Make sure your win 7 disc is inside the cd tray.
    3. Select your DVD drive and press enter.
    4. A message will come up that says "Press any key to continue" press enter key real quick.
    5. The win 7 installation should load.
    Good Luck.
    Jan 02, 2011 | Dell OptiPlex GX620 PC Desktop
    Need to reboot my dell optiplex 330 to factory settings
    If you wish to restore your computer's factory settings, you need to back up you computer first.
    Here is a link from Dell on how to reset your Dell's to it's factory settings.
    All the best!
    Nov 16, 2010 | Computers & Internet
    I have a dell optiplex gx 620 i install a new harddrive put the os cd in it said no boot device,i put in the dell boot cd it booted the computer up it got to A> prompt and stop loading what do i type in...
    First put your Windows CD in the drive.
    While booting, the screen should offer you a couple of choices - Enter "Setup" and tell you which keys to press or "Boot Options" and again which key to select.
    Try Boot options first, and choose to boot from CD. It will revert next time you boot.
    If you choose or have to enter "Setup" . Usually achieved by pressing the "Delete" or "F2" key look for and change your boot options to select you CD drive first but make sure you put it back later.
    You may have to re-boot a couple of times to find the commands I mention, they do flash through fairly quickly.
    Mar 13, 2010 | Dell OptiPlex GX620 PC Desktop
    My dell gx-270 power keeps shutting down.
    hmmm,
    Dont worry just boot your computer using Bootable disk or windows installation disk, enter into Recovery console by pressing"R"
    type the Administrator password if any or simply press "Enter".
    At the command prompt type-"fixboot"
    once done restart your computer normally.
    Mar 25, 2009 | Dell OptiPlex GX270 PC Desktop
    Computers & Internet Logo
    60 people viewed this question
    David Payne
    David Payne
