Question about Brother MFC 210C All-In-One InkJet Printer
Clogged print head brother mfc215c
On test print no cyan and poor magenta. black and yellow ok.have tried new cartiges but the same.
Mix-it-up
  • 832 Answers
SOURCE: Brother Printer Cannot Print in Black
This could be because of several probs: 1. The ink cart is not original and wont let the ink flow, because the valve is not open. 2. There might be air bubbles within the capillaries. 3. The ink is not genuine ink and has pigments in it. Solution: see here, too: http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=dcp110c_us Insert another ink cart. Use, if possible, the genuine ink cart from brother. Do the cleaning cycle twice. This will extract the air bubbles out of the caps after the second time. If you dont have any success the printhead is clogged and cant be cleaned anymore!
Posted on Sep 17, 2007
SOURCE: no black ink printing
Ah, solved already. Cleaning the black print head a few more times did it for me.
Posted on Mar 18, 2009
SOURCE: Brother MFC-620CN print head clogged
Open up amd release blue stay at bottom by pressing edges inward and pulling slightly forward. Remove the 4 screws, 2 small plastic covers and the earth screw. Pull out the ribbon connector near the USB plug. Unplug the 2 white and one red connectors, noting how the cables fit in. Fully open the lid and pop the scanner part off. Remove all the ink cartridges. Now using a flat screwdriver unclip the top of the base all the way round and lift off. The print head is now accessible. Rotate the white paper feed cogs to release the print head. Slide it all the way to the right and remove it by tilting the back edge upwards. You mow have access to the print head!!!!
Posted on Jun 02, 2009
  • 1121 Answers
SOURCE: Printer is Brother MFC215C. Cyan colour not coming
  1. Press Ink or Ink Management key on the control panel of the machine.
  2. Press 1 to choose 1.CLEANING.
  3. Press the up or down navigation key to choose the Black, Color or All you want to clean, and then press Menu/Set or Set.
The machine will clean the print head automatically. When cleaning is finished, the machine will go back online automatically.
Note If you clean the print head at least five times and the print has not improved, please contact Brother Customer Service from "Contact Us".
Posted on Feb 15, 2010
  • 186 Answers
SOURCE: suspected clogged blue ink tube
most of the time, the print head need to be replaced for your case... but there are cases whereby it's the ink cart that causes the ink clogged.. you can try replacing the cyan ink and do another round of cleaning.. but chances are slim...
Posted on May 24, 2010
Testimonial: "thanks a bunch! just seems to confirm what i suspected all along..."
I've got a J125 brother printer and i have a problem printing the yellow color since it has four cartridges, Black, cyan,yellow, magenta. i just purchased a yellow cartridge and i tried the "cleaning"...
It is a new cartridge and you have cone all you can do. You have a bad print head. Sorry. Replaceable item but expensive to the point where often it is better to just get a new printer rather than replace that part.
Sep 08, 2017 | Brother DCP-J125
How to clean printer head for brother mfc j265w
Hi .. i have a similar problem ... i juste replaced the Black cartridge ... and when i run a "test print" or an 'alignment print" ... the whole black ink block doesn't appear at all .. only the Magenta, CYan & Yellow are ok. HELP ! ;)
Apr 19, 2012 | Brother MFC 420CN All-In-One InkJet...
My HP 6500 only prints yellow and black. I refilled all three color cartridges and only the yellow is working. Any ideas?
This printer having four cartridges and two print heads.Each print head having two pens, black, yellow & magenta,cyan. As you said yellow & black are OK.. So replace Magenta & Cyan print head..
Oct 28, 2011 | HP Officejet 6500 Wireless All-in-One...
It appears that the yellow print head on my Brother MFC240 printer is clogged. There is lots of ink in the cartridge, but it does not print yellow. It will print black, cyan and magenta. Where is the...
some solution.
ry to clean by properties of program on your computer.
then you try to print some text or image use yellow ink only..
but if it doesn't changed. try to reinstall the driver.
May 31, 2011 | Brother MFC 240C All-In-One InkJet Printer
MY Printer Brother : MF 235 C has problem with printing the Magenta and Yellow. bought 4 original catridges for Black , Cyan , Magenta and Yello. The Cyan and Black are printing with blurish and faded...
Try the instructional video below. ou can get a sringe from Pharmacy department of any store for free and tubing can be purchased in stores like walmart. It is a simpole fishtank airtube. I have a link below for walmart air tube. Aqua Cultures Standard Airline Tubing 8ft Walmart com
May 30, 2017 | Brother Office Equipment & Supplies
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
Printing problems
try to clean the noozle of you catridge..... then try again...... or try to shake it
Sep 01, 2009 | HP PhotoSmart 7960 InkJet Printer
No black ink printing
Mar 11, 2009 | Brother MFC-5840CN All-In-One InkJet...
Brother DPC- 115C
What error does the machine show up?
Plz give some more info in detail!!!!!
Oct 24, 2007 | Brother DCP-110C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
95 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
