Question about Sony Cameras
My cybershot 5.0 mega pixels will not turn on
It wont charge by wall or computer......
  • 734 Answers
Check your lens position, perhaps not fully retracted?
Posted on Feb 09, 2012
welcomejee
  • 10594 Answers
SOURCE: sony cybershot 7.2 mega pixels
Lens of camera is not being open properly, so it gives "access" message. Try this trick, while puching power up button, tapp the lens or pull upward. Please don't give much force as it can be damaged easily.
Posted on May 28, 2008
SOURCE: not working
wher do I get a new battery?
Posted on Aug 09, 2008
welcomejee
  • 10594 Answers
SOURCE: My Sony Cybershot DSC W55
Please RESET your camera , go to Menu > Initialize > OK
If problem still exist you need to replace flash unit in camera.
Let me know if you need further help.
Posted on Jan 28, 2009
  • 11967 Answers
SOURCE: Sony cybershot digital camera with a stuck lens
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 03, 2010
Kensolutions
  • 455 Answers
SOURCE: When I turn my Sony
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Posted on Oct 21, 2010
SonyManual for Cybershot DSC-W290
Go to setting then select date & then time change then and save the settintg.
Aug 08, 2012 | Sony Cameras
Sony cybershot w570-water damage
water might damage and only way bring it to a expert
Apr 17, 2012 | Sony Cameras
I WANT TO SEND 11 PAGES OF A DOCUMENT BY EMAIL HOW CAN I MAKE IT SMALLER
Turn down the picture quality and it will require less memory
Example 10 mega pixel camera
change it from 10 Mega pixel to 5 mega pixel
Mar 07, 2010 | Fuji FinePix 2600 Zoom Digital Camera
My sony cybershot 3.2 mega pixels camera's power wont stay on. I put new batteries in. they are the right way. What would be the 1st step in fixing?
Hello!
Please ensure whether the Battery is fully charged. You may also try removing the Battery pack from the Camera and clean the Battery compartment using a cotton swab. Then, try using the Camera.
If the issue persists then the Camera requires to be serviced.
Aug 24, 2009 | Sony Cameras
My problem is i want a digital camera has 10 to 15 mega pixel cyber shot
I HAVE A SONY CYBERSHOT 5 MEG PIX WITH A CARL ZEISS LENS AND I LOVE IT IT OUT PERFORMS THE 8 MEG CYBER SHOTS
Mar 09, 2009 | Sony Cybershot DSC-T200 Digital Camera
My sony cybershot 7.2 mega pixel
repair shop is your best option...
no point wondering whether you can fix it yourself if you lack equipment and knowledge!
Oct 11, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Not working
Jul 17, 2008 | Optimus DS-5080 Digital Camera
What is the number of recorded pixels on the DiMAGE 7i?
The DiMAGE 7i has four different image size settings; Full 2560x1920, UXGA 1600x1200, XGA 1280x960 and VGA 640-480. The recorded pixel size in each mode is almost equivalent to an image captured with a 5 mega pixel, a 2 mega-pixel, 1.3 mega-pixel, 0.35 mega-pixel DSC respectively.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Cameras Logo
43 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
