Question about Maytag Dryers
My Neptune gas dryer is making a thumping noise on each revolution. Any suggestions?
    Problem Solver:
  • 6 Answers
Bearings that center drum probably bad.
Posted on Feb 09, 2012
JOE LLAMA
  • 26 Answers
SOURCE: LG ELECTRIC DRYER
Henry, its going to be 1 of 2 things. Check inside your drum, see if the vent in the rear has burning or discoloration around it. If it does, it sounds as if your vent is restricted causing the unit to overheat, so clean/fix/replace the venting and your support pulleys will need to be repalce ie flat spots from overheat. If there is no scoarching marks and you know its not the vent or heat issue, the drum seam may have parted causing the thump as every revolution is made.
Posted on Apr 04, 2008
  • 3 Answers
SOURCE: My dryer -model FER311F makes a thumping noise while in use.
Check the 4 feet & make sure top of of appliance is level. These 4 feet will have threaded adjustments, just tilt the dryer back and should be able to turn with your hand or may require pliers, good luck.
Posted on Jan 21, 2009
erpaalai
  • 999 Answers
SOURCE: my new dryer thumps every revolution
Flat spots on the support rollers from sitting in storage will make a thump. So will heavy wet clothes if they are not spun dry enough from the washer. This may lessen as the unit is used but since it is in warranty a service call to rule out major problems is in order.
Eric
Posted on Jun 17, 2009
jumptrout51
  • 3361 Answers
SOURCE: maks thumping noice
Replace the rear drum roller supports.
Posted on Jul 08, 2009
  • 5 Answers
SOURCE: dryer makes a thumping noise when running.
replace drum wheels.
Posted on Jul 16, 2009
Dryer runs and drys but makes a thump soud every revolution "like a tennis ball"
Check the belt that is on the drum. It sounds like it may have a chunk broken off of it and you may need to replace it.
Aug 09, 2014 | Maytag MDE9700AYM Electric Dryer
Neptune MDG9700A Gas Dryer: as dryer turns there is a noise every time it make...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fsf
May 17, 2010 | Maytag Neptune MDG9700A Gas Dryer
Maytag neptune dryer making a thumping noise while drum turns, as if there were a tennis shoe in it, but there isn't? Ideas?
heatman101
Jan 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer making a thumping sound when engaged
HI, rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise,
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maks thumping noice
Jul 08, 2009 | Whirlpool Dryers
Jan 21, 2009 | Frigidaire FEQ332E Electric Dryer
LG ELECTRIC DRYER
Apr 04, 2008 | LG DLE2514 Electric Dryer
Lumpy drum noise
Did you remove the shipping bolts from the back of the machine
Mar 26, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Neptune gas dryer
Did you check the baffles( fins inside the drum) loose of broken.
Can you turn it by hand and hear the same sound? does it turn easy or very hard...let me know I can help
krazytech
Mar 23, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
37 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
