Hi, i have just put my motherboard together, but i'm not getting anything on the screen. the screen is still in save mode. i put another video card in to check if that was the problem but still we have no screen. i dont have a solution. can anyone help?
-   I have all the ps wires connected, all fans in the right place, and I've connected all the front panel wires in, and even played around with them some. Still, a black screen. NO BIOS, no POST beep, nothing. Although the fans spin up and stay spinning until I hit the power switch off on the power supply. OH, and the front panel buttons do not work, but it will power the fans on if I move the power switch connecter on the pins. Being an IT guy for the past 7 or 8 years, this problem has me a bit peeved.
-   lococg
Nov 09, 2007
-   i have connected all the connections still there is no display from the mother board. what can i do? how should i solve the problem? please send the pin configuration . i think it would help for me. -   amul baby
More Info requested? Ok, the mobo is an Abit kn9 AM2 board. The cpu is an Athlon 64 X2 5400+ Socket AM2. The memory, video card, etc. were removed so they aren't a factor since I still receive no post errors at all without those devices. No beep beep to say no video card... no anything except the fans come on.
hi! motherboard was fine moved out of town and computer stoped working. open case found power wire off and a jumper radle free need to know where it gose on the motherboard to make mmonitor work without video card. can somebody help with support?
dont waste your time is not the video card, Idont know what you put together but if you change the motherboard you have to give some info to it, and thas a technical job look for a tech....good luck
Was this helpful?
Yes
No
Solution #5
posted on Jan 08, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem. Fans come on, but nothing else
no the monitor wont post it stays in save mode, so not even getting to bios, ive tried pluging monitor into the vid cards vga jack and the motherboards vga jack but still not getting any screen other then the save screen not sure what the problem is. Ive tried 4 types of ram and 2 processors that i know work, so im wondering if i just got a bad mother board
Was this helpful?
Yes
No
Solution #7
posted on Jun 25, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
bro i got the same problem but i have a temporary fix, reseat the processor and turn on the computer without the heatsink once u see the screen display quickly snap the processor back on and walla there ya go,
Solution #8
posted on May 17, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i am having trouble finsing out what the problem is as well
the way I fixed it was I took the video card out of my other computer and stuck it in the mobo. everything showed up on screen when i did that. I then went into the bios and changed the onboard card to always enabled, this fixed everything for me.
same problem... im not getting a picture or a beep... i know that the video card isint the problem... it works with other computers. can someone please help?
I just reinstalled windows XP home, I had my product key code but not the original disk as that was...
(More)
I just reinstalled windows XP home, I had my product key code but not the original disk as that was lost a long time aqo. Microsoft let me reinstall windows as I had the product key code that was registered to me and one done I booted up but no drivers for ethernet or networking etc. The motherboard is Albatron PX865PE Pro. What do I do?
Hey, Im getting same problem as the others, blackscreen when i press the on button, I ain't getting...
(More)
Hey, Im getting same problem as the others, blackscreen when i press the on button, I ain't getting post/bios/windows, nothing at all, and I can't shut it off with button either. PLEASE HELP!
