Question about Vtech LS6115-2 Twin - - Phone
Hi i have Vtech LS6115-2 shut down when press on off bottom and some time paging without request to paging (paging fom itself), how i can solve this problem ?
How do I change the outgoing message for the answering machine?
Without the exact model number from the bottom label I'm guessing this excerpt from a Vtech manual should be close enough to get you started:
Record your own announcement
You can record an announcement up to 90 seconds, but announcements shorter than two seconds will not be recorded.
    1.Press "MENU/SELECT" when the handset is not in use.
    2.Press <Up Arrow> or <Down Arrow> to highlight ">Answering sys", then press "MENU/SELECT".
    3.Press "MENU/SELECT" to select ">Announcement".
    4.Press <Up Arrow> or <Down Arrow> to highlight ">Record annc", then press "MENU/SELECT".
    5.The system announces, "Record after the tone. Press 5 when you are done" and the screen shows RECORDING ANNC... 5-Stop.
    6.After the tone, speak towards the handset microphone.
    7.Press 5 when done. The answering system automatically plays back the newly recorded announcement, then returns to the previous menu. -OR-
    7.Press "OFF/CANCEL" to exit without saving the recording.
If you have lost your origional manual you can get a replacement from the Vtech support site here:
http://www.vtechphones.com/support/general/manuals
May 05, 2016 | Vtech DECT 6.0 Cordless Phone with Digital...
How do I change my outgoing message on my vetch DECT 6 phone
If you have lost your original manual you can get a replacement from the Vtech support site here:
Mar 16, 2016 | Vtech DECT 6.0 Digital Cordless Phone
I have a Vtech answering machine, MI6896, I need to lower the volume of the ringer without changing the volume of outgoing and incoming message.
With the handset in idle mode, press MENU then use up/down-arrow to select "RINGER VOLUME." Use up/down-arrow to change the ringer volume. See full details on page 30 of the manual.
Jul 29, 2012 | Vtech Lands Phones
Somehow my facebook page has shrunk down
To revert the page to the original size, kindly press CTRL and + buttons together.
Or click the Zoom icon at the bottom-right of the Internet Explorer window (see attached image)
Hope this solves your problem. Thanks for using FixYa
May 13, 2010 | Facebook Social Network
Can't shut off AOL Aim intstant messager sounds.
This is easily solved.
Go to Edit on the top of your AIM buddy list window
Go to Settings at the very bottom of the list
Then go to Sounds on the left hand side of the popout window
Then scroll down the settings and edit as you please
Press Save and you are done
Mar 11, 2009 | Computers & Internet
My Iphone has broken the power bottom
Thank you, I solved my problem usin the suggestion of Cruel dog. I downloaded the Ireboot fom the link in my email and I solved so my problem. Thanks.
Oct 08, 2008 | Apple iPhone 3G
My computer keeps restarting itself
  1. Start laptop
  2. When the laptops Logo page closes, start to press F8
  3. You should get a Windows Start screen
  4. If you get a Windows Logo page (the kind you normally get when Windows loads, then reset it and start again.
  5. On the Windows Start page select "Last known good configuration" and press enter twice
Hope that solves it for you =)
Apr 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
VTech 5.8 mhz won't work
I found a solution that fixed this problem (at least for me). On the vtech site they said to unplug the base unit for at least 5 minutes. Previously, I had only unplugged the base unit for a few seconds. This time, I left it unplugged for about 10 minutes or so and when I plugged it back in, everything was working fine. Apparently there is some sort of capacitor that must discharge long enough to completely remove power from the circuitry.
Good luck and I hope this works for you!
Jan 18, 2008 | Vtech 9009111 Cordless Phone
Treo 650 keeps shutting itself down
Hi muchlove,
Please backup your palm to memory card using palm backup application or hotsync it to your computer, then you do a zero-reset. Here's the step by step how to zero-reset:
http://tinyurl.com/babb7
If this solve the problem than it caused by software conflict. Please let me know the result.
Nov 02, 2007 | Palm Treo 650 Handheld
Vtech LS6115-2 Twin - - Phone Logo
22 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
