Question about Westinghouse LTV-32w4 32.02 in. LCD HDTV
No picture I turn on the TV - blue power light comes on small sign at top of screen says VGA - No Signal Detected Stays on about 30 or so seconds then turns off by itself Is this a problem with the TV or should I call cable company If problem with TV, is there a way I can correct it?
My parents bought the same tv, TV ran fine for 2 years then started giving them problems. Blue light comes on then few seconds later turns to yellow. Turn tv off then back on it worked, until last week it would not turn on.
Took it to a repair shop they said it was a bad power supply and it will cost 50$ for this check up, as it turns out the total bill would be $650 minus the original $50 it would only cost you $600.
Needles to say i took the tv home with me. Since they were not going to use it i started looking at it took the back off, removed all heat shiels ect. Took my magnifing glass out and started looking at the power supply come to find out the part was made in China, it was missing a solder joint, pulled my old soldering gun out, five minutes later the tv came back to life.
i hope this helps.
JOHN
Posted on Oct 24, 2008
Sceptre X32GV-Komodo
See troubleshooting (p.96-99) of user manual
but Unfortunately i think this problem is for Sceptre ...
For technical help, contact our Sceptre Technical Support Group via email or
phone. Please have your Sceptre p/n number, serial number, and date of
purchase available before you call.
Tech Support E-mail : monitor-ts@sceptre.com
Customer Service Email : cs@sceptre.com
TEL : 1800-788-2878
Operation Hours : Mon - Fri at 8:30 AM – 5:30 PM Pacific Standard Time
Mar 20, 2008 | Televison & Video
Black screen
Possible causes
  • Your TV is not receiving or displaying the signal from your DIRECTV® Receiver.
  • Your receiver has correct guide information, but is not processing video correctly.
  • You are viewing a channel where an upcoming sporting or special event is scheduled or has recently ended.
Solutions
  • Turn TV off and on.
  • Make sure light on front panel of receiver is lit.
  • Press the "TV/DSS" button on the remote control or front panel of the receiver (not all receivers have this option).
  • Reset the receiver by unplugging the power cord for 15 seconds.
  • Check all cable connections between the dish, receiver and TV.
If the picture is black, but the program title and description display in a banner the top of the screen:
  • If the problem is only occurring on a few channels, check the detailed description of the program through the on–screen guide on those channels. Often, we display a blank screen with a banner before and after a high–profile event to alert customers about the event.
  • Reset the receiver by turning off and unplugging the power cord for 15 seconds.
  • Run a signal meter test to check your signal strength (press "menu" and look under "setup" or "installation").
If your signal strength is below 70 (or below 60 on HD receivers) in clear weather on transponders 1 and 2, see our troubleshooting steps for "Searching for satellite signal. Please stand by." You may see zero strength on transponders 4, 12, 18, 20, 26 and 28. This is normal in many areas. Your system manual shows how to run cables and point your dish.
Oct 24, 2007 | Toshiba 30HF66 30" TV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
My tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Apr 07, 2009 | JVC LT-42X579 42 in. LCD TV
New JVC flat screen cuts off 10 sec. after cutting on
Mar 26, 2009 | JVC LT42P789 42 in. LCD TV
No Picture, No Sound While Watching
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | RCA L37WD250 37 in. LCD HDTV
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
TV goes out
pyrosp4,
it maybe you blue crt (picture tube). mine turn blue and then shuts off. i got it repaired for 460. 300 for the part 160 to install. you can try to adjust the voltage settings behind the speaker screen and see if that clears the problem. if not its you blue crt.
pridah
Dec 18, 2007 | Sony KP-65XBR10W 65" Rear Projection...
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Westinghouse LTV-32w4 32.02 in. LCD HDTV Logo
257 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
