Code comes on sd
SOURCE: very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
SOURCE: Front loader door will not open after a washing cycle is finished
call the repair man it is a comp. issue
SOURCE: getting error 5e WF7708 samsung front loader. Have
A 5E code means that the drain pump is iether clogged, with lint, impeller damage, drain hose clogged, or a loose connection on the pump connectors
Testimonial: "i was draining the water out only coming out in dribbles so i think you hit the nail on the head....ty ty will give it a go..."
SOURCE: wont finish cycle there is a F code
Remove the bottom panel. The tech sheet with fault codes and diagnostics is behind the motor control unit,white box to left. Clean out the pump filter and housing, maybe that will help
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this
problem you have to take the bottom front panel apart and then clean the drain
filter pump assembly completely, make sure the washer is unplugged before
working on it. Please get back to me if you have any other questions.
Kevin
