Question about Saws
Bosch 4000 tablesaw
Runs backwards slow and hums?
  • jimjoiner Mar 12, 2009
    I have the same problem as an earlier poster.. The blade turns backward
    and hums. Someone replied "the parity is wrong"... What parity and what
    exactly is the problem with it... What needs to be fixed???
  • 2,176 Answers
What they meant I believe is "polarity" and in that if the switch or motor windings are not wired incorrectly the motor will act like that. The armature and field are not designed to run in reversse. I would check to ensure they are wired to mfrs. code. get me an exact model and brand and I will try and find you a wiring schematic
Posted on Jun 27, 2009
  • 34 Answers
The parity is switch. which means its positive and negatives are switched.
Posted on Oct 23, 2008
Bosch 4000 table saw motor schmatic
I have found the most common issue is a bad field with the second being a bad rear armature bearing and last being a bad speed control.
Most of the time slow speed or even running backwards is a bad field (part #2 on the breakdown) #1619PA5590
Remove the cap on the end of the motor & the 2 carbon brushes.
Remove the 4 screws holding the motor to the frame and pull it straight off.
Check the bearing on the end of the armature to ensure it is not frozen or stiff. If it is also check the rubber boot that sits over the bearing and the motor housing itself to ensure it is not melted.
Dec 18, 2013 | Bosch 4000 - 07 Electric Table Saws
My Bosch table saw 4000 run slow and backward and make a noise like buzzing strong, someone has an idea what could be? if i have to change some parts of the motor an which ones??
Hi, try and change the Carbon Brushes , these are located either side of the motor, you will see a black plastic nut or screw, remove this and you will see a wire inside a spring this will push it's self out and then you can gently pull the Carbon brush out this is about 1/4--1/2 " long ...! if not then replace with new. PS. REMEMBER TO DISCONECT FROM MAINS SUPPLY FIRST....T.C.
Mar 20, 2013 | Bosch Electric Table Saws
Bosh 4000 table saw runs backward and at low speed
I've worked on some table saws with problems like you describe, a couple needed a new speed control unit (Bosch PN 2610997306) in the motor. If all the wiring to and inside the motor is OK and not shorting out anywhere, that's the next part you should look at.
Jul 10, 2012 | Bosch 4000 10IN Table Saw
Bosch 4000 table saw run backward and slowly
I had the same problem with the Bosch 4000.
Changed the field for a new one...end of problem
Apr 28, 2011 | Bosch 4000 - 07 Electric Table Saws
Bosch 4000 Table Saw running backward
You can find the 4000 manuals and parts diagram at bosch tools online. You will need a new armture Bnew bushes and possibly field. I would also replace the bearings and motor speed control circuit board.
Bosch does not sell the motor assembly.
Turn unit upside down and remove the Plastic body - approx 6 screws.
Thake a digital camera and take LOTS of pictures of dissassembly as you will need them later. Blow unit clean and work neatly keeping all parts in labeled bins for reassembly. Don't attempt this job when your pressed for time.
Before you start check to see if this machine is still under warranty!!
Call customer support listed on website if you run into a problem.
Good Luck !!
May 19, 2010 | Bosch 4000 Factory Reconditioned 10"...
Bosch 4000 tablesaw won't start. Brushes replaced
I found that the remaining problem was a intermittent at the switch, which disassembly and cleaning resolved.
Tilting the motor / blade assembly down allows access from below, to the 3 screws fastening the controller circuit board cover on the brush end of the motor. From there, one can easily test exposed wires for power supply, see that brushes are contacting and clean accumulated sawdust.
Jan 06, 2010 | Bosch Electric Table Saws
What's the smart way to remove the motor for
i wouldn,t remove unless you think needs new bearings or cannot get to the brushes, turn upside down if has base cover remove and blow out best you can be sure no water in air line.
Jan 05, 2010 | Bosch Electric Table Saws
My bosch table saw runs slowly backwards what part do i replace
Replace the field coil. I'm going to bet its a Model 4000. I have done about 100 of these saws in the last couple of years and my customers always complain of the same problem, "the saw was running backwards"
Change the armature back bearing while you have it apart, they always seize eventually.
Jun 23, 2009 | Bosch 4000 - 07 Electric Table Saws
My saw runs backwards too!
Try to put the blade in the other way. then see if it works.
Dec 31, 2008 | Bosch 4000 - 07 Electric Table Saws
Bosch 4000 tablesaw suddenly ran backwards and died
I had a customer bring me a saw with this same problem. All components tested OK on my growler. I went on a limb since the speed control and the armature tested OK. I replaced the feild since to me it seemed to be the only component that could cause the motor to run in reverse. Tool now works properly and have had no more problems with the tool.
Dec 02, 2008 | Bosch Electric Table Saws
Saws Logo
267 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
