I can not use IomegaEncryptionSetup.exe. What can I do? I can not install it.
Can I uninstall a install exe after the program has been installed
Yes, you can delete the install.exe file after the install is complete.
Oct 15, 2014 | Microsoft Windows 7 Home Premium 64BIT...
I have compaq presario c700 note book with intel r celeron r m cpu 530 @ 1.73 GHz. I can not found the sound driver could pls help me. and also tell me how to install it.my OS is xp service pack 3.
hello, first u need three driver downloaded into your computer: - Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio: http://rapidshare.com/files/375339812/uaa_sp32646.exe - Conexant CX20549-12 Audio Driver for Microsoft Windows XP: http://rapidshare.com/files/375299248/audio_sp36090.exe - Conexant CX20548 Modem Driver for Microsoft Windows XP HD Audio: http://rapidshare.com/files/375343127/modem_sp36089.exe
to install the audio and modem driver: 1. u have to install UAA Bus Driver first, double click 'uaa_sp32646.exe' then follow the installation 2. install Conexant CX20549-12, double click 'audio_sp36090.exe' then follow the installation 3. install Conexant CX20548, double click 'modem_sp36089.exe' then follow the installation
this will install the sound driver and modem on your computer
hope this useful, regards.
Aug 26, 2011 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
I have a problem with my hpdv5 1205tx my current windows is vista i repormat in windows 7 now my problem is my digital personel fingerprint was not connected i already down digital personel 4.11 help me...
If you have installed either 64 bit or 32 bit, then you have to run the installation as administrator.
To do this, just right click on the installation file and choose run as administrator.
If this did not help, refer the below steps:
  • Download version 2.01 of DigitalPersona software
  • Install on existing system
  • Export data
  • Boot into Win7
  • Install 2.01
  • Reboot
  • Reset properties for each of 7 EXE files
  • Reboot
  • Register a finger print
  • Import data saved in step 3
  • Download from here:
    http://download.cnet.com/DigitalPersona-Password-Manager/3000-18501_4-201746.html
    Step 3:
    Export is available as an icon choice in the system tray. Save to a file for use in Step 10.
    Step 7:
    The run properties for each of the 7 EXE files in the DigitalPersona install need to be adjusted. The files are:
    DPAgnt.exe
    DPConsol.exe
    DPExpImp.exe
    DpFpLogonManager.exe
    DpHost.exe
    DPRunDll.exe
    DPWinLct.exe
    Select each and set as follows:
    • Compatibility tab
    • Press ã¢â‚¬å“Change settings for all usersã¢â‚¬â
    • Select run in Vista mode
    • Select run at admin near bottom
    Repeat for each of the 7 EXE files.
    Nnags.
    Mar 08, 2010 | HP Pavilion dv6000z Notebook
    Audio driver in xp3
    ALL THE DRIVERS U'LL EVER NEED FOR COMPAQ PRESARIO C700
    (VGA) Driver:
    http://downloadmirror.intel.com/13300/a08/win2k_xp1429.exe
    Chipset Driver:
    http://downloadmirror.intel.com/13499/a08/infinst_autol.exe
    Wireless LAN Driver:
    ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34152.exe
    ALPS Touchpad Pointing Device Driver:
    ftp://ftp.hp.com/pub/softpaq/sp31001-31500/sp31075.exe
    5 in 1 card reader driver:
    ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33604.exe
    HP Quick Launch Buttons
    ftp://ftp.hp.com/pub/softlib/software8/COL18360/ch-47422-1/sp33258.exe
    LAN Driver
    ftp://ftp.hp.com/pub/softpaq/sp30501-31000/sp30580.exe
    To install audio / modem drivers, first download and install Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio (sp32646):
    ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32646.exe
    Conexant CX20549-12 Audio Driver for Microsoft Windows XP (sp36090.exe) (UAA Driver needed)
    ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe
    This will create a swsetup folder in C drive ("C:\sp36090")
    Installing this driver may result in an error. But continue with the following steps to get the audio driver installed correctly.
    1. Click on Start and select Run. Now type devmgmt.msc and press enter.
    2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
    3. Select "Install from a list or specific location"
    4. Click Next. Then select "Don't search, I will choose the driver to install"
    5. Click Next and then select "Sound, video and game controller" from the list.
    6. Click Next and then click Have Disk.
    7. Click Browse C:\sp36090 folder and select the .inf file (CpV30D5a) and click open and Continue with the onscreen instructions.
    Conexant CX20548 Modem Driver for Microsoft Windows XP (sp36089.exe) (UAA Driver needed)
    ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36089.exe
    Download and install Conexant modem driver (sp36089). This will give error message and also will create a folder C:\swsetup\sp36089 which contains extracted driver files.
    The same method which is used for installing audio driver needs to be followed for modem.
    Sep 16, 2009 | HP Compaq Presario C700T
    No audio output installed
    (VGA) Driver:
    Chipset Driver:
    LAN Driver
    Sep 06, 2009 | Compaq Presario C700T Notebook
    I also need the audio driver of compaq laptop c773tu series
    Source of Info is Here
    Compaq Presario C773TU Laptop drivers for Windows XP
    August 8, 2008 — saysprasad
    I. Get the following drivers and install in the given order only.
    01. VGA/Display - winxp_14331_VGAGL960.exe (14MB)
    02. WinXPSP2 Enhancements - sp28668_Enh4WinXPSP2.exe (3.3MB)
    03. Card Reader - sp33604.exe (2MB)
    04. Webcam - sp35414.exe (5MB)
    05. UAA Driver for HD Audio - sp32646.exe (35MB)
    06. Audio/Sound - download C772 audio driver (3MB)
    07. Modem - SP33442.exe (6MB) (unzip the file and read help attached)
    08. Wireless - Manual install net5211 (260KB)
    09. Quick launch - sp38266.exe (20MB)
    10. SM Bus Driver - Manual install sp32555.exe (1MB)
    I Hope This Helps.
    Jan 19, 2009 | Microsoft Windows XP Professional With...
    Installing jetflash 2 windowsme
    Download and install the following files and try again. The should also work with Windows ME as it is just a dressed up version of Windows 98.
    For Windows 95, 98 and NT VBRun60.exe - VBRun60.exe installs Visual Basic 6.0 run-time files.
    VBRun60sp5.exe - VBRun60sp5.exe installs Visual Basic 6.0 sp5 run-time files
    For Windows 98 only DCOM98.exe - Extends the support for Distributed Component Object Model (DCOM) for Microsoft Windows 98.
    Apr 10, 2008 | Computers & Internet
    Audio
    Dear Mayel ,
    Before installing the audio drivers please install the UAA drivers first. Then restart the computer and install the remaining drivers. Carefully follow on-screen instructions, if any, during the installation.
    UAA Driver
    Audio Driver
    http://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe
    Modem Driver
    http://ftp.hp.com/pub/softpaq/sp36001-36500/sp36089.exe
    Wireless Lan Driver
    Synaptics Touchpad Driver
    ftp://ftp.hp.com/pub/softpaq/sp35001-35500/sp35444.exe
    Intel Chipset Drivers
    http://downloadmirror.intel.com/13799/eng/ChipUtil.exe
    Ricoh 5-in-1 Card Reader Drivers
    all these drivers for XP .
    cheerup and Be Happy Always
    Mar 25, 2008 | Compaq Presario 700 470024-192 Notebook
    Videosafe drivers wont install fail at 80% "1628 failed"
    1. Detect if another installation process is running Press Ctrl + Alt + Del and select Task Manager. Go to the Processes tab. Check the running processes for any or some of these names: setup.exe isetup.exe ikernel.exe msiexec.exe idriver.exe IsUninst.exe IsUn16.exe Uninst.exe Uninst16.exe End previously running installation processes Follow these steps for any of the above processes that are found running on the system. 1.Select each process. 2.Select End Process. 2. clean your Temp directory try reinstall it good luck :-)
    Jan 12, 2006 | Zio Corporation CameraMate VideoSafe...
    Open Questions:
    can you please help ms drunel broussard who just received custody of 2 of her abused grandchildren in nov 2017 have a great xmas not having a home with furnishings..she no longer have stable housing ms drunels daughter and boyfriend had been abusing her children..shes a great person with such agood heart and shes struggling to keep the kids..while in moms care the kids was sleeping on the ..have very min clothing..ms drunel took her car notes monies to get the kids basic clothing and hygiene needs..shes help so many7 ppl and always been an strong person..not knowing where they would lay their heads at..i watch her go and visit ,pray for ppl in the hospital..when you ask herhow is things going shell say all will be well..but today i seen her breakdown and crying..letting the kids know she might have to let them go to foster care because she cant provide them with a stable place..to know her is to truly love her..and to see her not be able to care for them the way she cared for hewr children and other ppl children is taking a toll on her.but she keeps smiling..she really need help and an agency in jax fl where she lives told her to give them up or go to a shelter...she replied ok ..and left..doors is not opening and due to the NATURE OF THE abuse..and physical abuse these babies been through she said no..they have nothing i mean nothing for xmas...less alone shes facing losing her means of transportation to get them to and from school...counseling ...and dr.appt...PLEASE PLEASE I BEG OF YOU HELP THIS FAMILY...THANK YOU FOR YOUR TIME
    Dec 14, 2017 | The Computers & Internet
    Computers & Internet Logo
    163 people viewed this question
    David Payne
    David Payne
