Question about Hayward Northstar Dual Speed Max Rate 2 Hp Pump
Hayward Northstar 3 HP pump for waterfall too noisy
I have a pump that is way too loud! I've rebuilt the motor, changed out the impeller, slip ring and all o-rings but nothing seems to help. I also put a valve on the outlet side of the pump to create some back pressure since the system is not filtered. It helped a little bit but you cannot restrict the flow too much before the pipes start shaking. Any ideas????
  • 990 Answers
Did you put the slip ring in with the wide end out? This slides foreward when the pump runs and seals the presure side of the impeller from the suction side. If this is not right it can create a lot of cavation noise. I don't know how long this has been a problem but if you just put this in a 3hp pump is a lot and will need a 3" suction on most runs and at least 2.5" on the presure side depending on the run. I hope this helps.
Posted on Oct 05, 2009
I am rebuilding a Northstar pump. I thought I had an o-ring between the diffuser and the impeller ring when disasembling. I don't see the on the schematic however.
The impeller ring moves freely and does not use an o ring. The front of the diffuser does have one. It sounds like they gave you an extra. BTW I have found that Northstar pumps get about 4 years out of their motors. That is about half the average life. I hope you are getting longer than 4 years. If not, it may be worth changing to a different pump.
Jan 03, 2013 | Hayward Pool & Spa
My Hayward Northstar 1.5 HP pump is pumping water into the pool, but not at full flow rate. This started happening after I cleaned out the filter basket that was plugging off the pump. The cap seems to...
you may have some debris in the impeller. you'll have to separate the wet end from the motor and access the impeller to see if it is partially plugged with debris. Northstar pumps have a closed face impeller that can trap debris at the opening and slow flow dramatically.
Aug 01, 2011 | Hayward 1.5 Hp Northstar High Performance...
I'm trying to remove the motor from the back of my Hayward pump (Northstar). I've loosened the large, round locking housing that secures the motor to the pump. It appears the motor should now just slide...
You didnt mention removing the impeller before trying to "slide it out" Remove the impeller and diffuser first before trying to seperate the two pieces. Lock onto the rear shaft with a 7/16th" wrench while rotating the impeller counter clockwise until remoed. Now you can seperate the two halves.
Apr 21, 2011 | Hayward 1.5 Hp Northstar High Performance...
I have a Hayward Northstar 2hp pump that is leaking apparently from the Seal Plate. I replaced the Seal Plate O-Ring, Diffuser O-Ring, Impeller Ring, and Seal Assembly but it continues to leak. I used...
wow, thats odd. If you replaced every seal/o-ring and its still leaking its gotta be 1 of 2 things
You installed the shaft seal wrong- no disrespect, just a possibility
or there is a hairline crack somewhere you are missing...
Aug 22, 2010 | Hayward 1.5 Hp Northstar High Performance...
I have a NorthStar pump. The motor went out so I have it replaced with a different manufactured motor (WEG). Same HP and even a higher SF factor than the original. The new motor draws 10 amps (rated is...
THATS WHAT YA GOT 2 DO ..SOUNDS LIKE YOU HAVE THE WRONG MOTOR .9.6amps IS A 1 1/2 HP ... A 1HP IS 7.6amps.. SO A QUICK FIX WOULD TO GET A 3/4 HP IMPELLER , THAT WILL GET YOU BACK IN THE NEEDED HP RANGE .. welcome to the HAYWARD NORTHSTAR .. HEY IF'N I WAS ANY HELP COMMENT OR VOTE ..JAY
Aug 19, 2010 | Hayward 1.5 Hp Northstar High Performance...
My Hayward pool pump was humming, but I got it running. Now it is not pulling water into the filter. Does anyone know what the problem could be?
WELCOME TO THE DREADED NORTHSTAR..THEY FAILED TO PUT A LOCKING SCREW ON THE IMPELLERS ON THESE WITH A MOTOR THAT CAN RUN IN REVERSE ON A WHIM . SO WHAT ITS DONE IS MUCKED UP THE THREADS ON THE IMPELLER.. YOU WILL FIND THAT THIS IS THE HARDEST PUMP TO WORK ON ! PARTS $$$ CRAZY .. I SEE A NEW PUMP IN YOUR FUTURE ,, A STA-RITE DURA GLASS !....; WHEN GETTING A NEW PUMP TELL THE THE HP AND SF SERVICE FACTOR OF THE HAYWARD YOU HAVE SO YOU GET THE RIGHT SIZE PUMP FOR YOUR NEEDS ..GOOD LUCK AND VOTE FOR ME...JAY
Jun 13, 2010 | Hayward Northstar Pool Pump 2 Hp Sp4020ns
My hayward northstar pump makes a loud noise when
If you have a crack in your basket you may have a clogged impeller. With the power off reach back into the pump through the pump pot with a long screwdriver and feel around. If it feels spongey it there you have a clog. Take the serew driver an use an oceleting motion in a counter clockwise direction this should loosen the clog then reach in with a long set of thin pliers and pull the clog out. This should fix your problem and once water is flowing your pump should quiet down.
Sep 29, 2009 | Hayward 1.5 Hp Northstar High Performance...
I have a Hayward Northstar 2HP pool pump. I need
If the motor still runs at all start the pump with the lock off and it will pop out. If not use some liquid soap and a small straw like a capalery tube on wd. Any thing small enough to fit through the space you can get when you pull the seal plate back, their is an inner plate with an "O" ring and you need to get the soap to that then let it sit for half hour or so and go back to the side to side prying when the soap and the "O" ring come together it will slide right out.
Sep 20, 2009 | Hayward Northstar Dual Speed Max Rate 2 Hp...
Hayward Max-Flo pump: Need to separate pump from motor
Remove the back cover from the motor, lock the shaft in place, thread off the impeller.
Jun 10, 2009 | Hayward 1.5 Hp Northstar High Performance...
Hayward Northstar Dual Speed Max Rate 2 Hp Pump Logo
246 people viewed this question
Top Hayward Garden Experts
Craig Butler
Craig Butler
Bill Boyd
Pushkar Singh
Pushkar Singh
Level 1 Expert
Are you a Hayward Garden Expert? Answer questions, earn points and help others
