Question about TOTO MS990CGR Neorest 600 One Piece Tankless Toilet
Toto Norest t600 motion control lid goes up halfway and then back down
Window on drivers side only goes down halfway. it will go back up but only goes down halfway.
while running the window down, push on top to see if it continues down. I so it may only need lubrication, if not, the motor track may be bad.
Apr 19, 2017 | Cars & Trucks
The push button dual flush system on my Toto toilet is not working
the connection rod (under the cistern lid is not connecting or is broken off.. lift the lid adn have a look.
Oct 03, 2013 | Toto Home
What is the velcro that came with my toto tank lid used for?
it is used to soften the lid to tank and keep it from rocking and china from rubbing
Mar 15, 2013 | Toto TCU974CRE-12 Toilet Tank Lid with...
How do I REMOVE SELF CHARGING CYLINDER OF SELF LOWERING LID//SEAT
Undo the two nuts and washer assembly holding the seat and lid onto the cistern. Lift off and lay down lid side down with back of lid facing you. Undo small screws in the chrome hinge arm brackets. They will the slide off. You can now see the two soft closure cylinders. One is for the seat and one for the lid. Usually lid has black tab and seat has white tab. The whole unit slides in and out, but you must push the little clip tab up, between the two locating lugs with a very small blade screwdriver and at the same time grip with pliers or molegrips and draw it out. There are no serviceable parts as far as I am aware. It is a sealed unit. The usual problem is the lid/ seat being forced down and internal pressure cracking the barrel of the cyclinder. Replace the unit and reassemble in reverse.
Jun 25, 2012 | Toto Home
Sometimes the lid slams down. can the unit remote control be reset?
Yes. Remove the batteries and wait 1 or 2 min reinstall the batteries it should be reset.
If the same thing happens again you have a mechanical problem in the lifting and lowering mechanism.
Jan 26, 2011 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
A small leak under the toilette, the seal has been changed many times and the toilette has even been replaced. Plumber says deffective toilettes? The leak seems to only happen when or after it is...
I've installed a lot of Toto toilets and have had few leaks but, not from the one piece toilets. It might be a problem toilet but, I would be sure the drain is not blocked causing a small back up after the flush.I have seen this happen many times. The toilet can be pulled and a 5gallon bucket of water can be poured down the drain to test this before replacing the toilet. also be sure water is not spraying on the top of the tank lid and leaking down the back of the toilet.If you flush the toilet with the lid off it should be easy to see if that the problem. hope this helps.
Dec 21, 2010 | Toto ULTIMATE ROUND FRONT ONE PIECE TOILET...
Toto toilet is constantly running, even though the tank is full
it sounds like it might be the floater ball in the toilet you can adjust the tension on it usually with a screwdriver.... if you look from the top down you should see a screw on the top of the arm that holds the floater adjust the tension and hopefully this will work
Jan 20, 2010 | Toto Drake ADA Compliant Toilet with...
My MLE2000 washer will start to spin and then
more likely an itntermitent lid switch problem as the washer strats it's spin cycle the motion is causuning the lid switch to open making the washer think some one has opened the lid and it shuts down to be safe check the switch make sure it hasn't come loose and check the actuator on the lid sometimes a plastic piece near the front of the lid that goes into sort of a key hole Good Luck
Oct 16, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Need instructions and Switch for twyford close coupled cistern
i presume with lid of u can flush toilet by pusshing switch with finger if so buttons must be spot on when replacing lid can be adjusted inside systern any probs get back
May 07, 2009 | Toto CST414M-51 Aquia Dual Flush Close...
Push Button - Have to Hold Down Button
I had the same problem. The fix cost me 50 cents (literally). I just placed a quarter on top of the Blue and White flush buttons (not sure of the technical terms) inside the tank and now it flushes properly. It seems that the 2 plastic poles the extend from the faux chrome buttons are just a bit too short.
Hope this helps
Feb 18, 2009 | Toto Aquia II Dual Flush Toilet
TOTO MS990CGR Neorest 600 One Piece Tankless Toilet Logo
212 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
