Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool ultimate care 11 SM8280867 - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
  • 360 Answers
SOURCE: I need to find out how old is my Whirlpool Washer Ultimate Care 2
The copyright on the owners manual is 2003.
Here is a -->link<-- to download the manual if you would like.
Please take the time to give this solution a fix ya rating.
clarkco
Posted on Feb 10, 2009
  • 262 Answers
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Posted on Dec 03, 2007
honeymokey
  • 3113 Answers
SOURCE: Whirlpool Ultimate Care II washer fills with water and stops
Lid switch. Push down on lid.
Posted on Jun 18, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 23, 2009
SOURCE: How to separate auger from agitator. whirlpool ultimate care II
When you look down into the agitator, are there 4 white plastic points that look slightly melted or otherwise deformed? If so, using a small flat head screw and a small hammer, separate the white plastic from the surrounding translucent plastic. Once you've done that, it should easily pull apart.
Posted on Jul 14, 2010
Sm8280867
See if all the connections are tight; try inter-changing the water pipes. Water should have good pressure at faucet.......
Apr 27, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool SM8280867 stopped agitating and makes noise.
you can find disassembly video on youtube,chances are you probably need a coupling,part no.285753a u can find exploded image/parts from sears .com
Mar 06, 2010 | Washing Machines
Washer problems
Remove your drain pump and check for lint and debris.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Cold wash
Hi if this intended to be used in a commercial environment then it will need to be hot and cold water supplied as commercial machines do not have heaters! I can tell you for sure if you give me the exact model number..
Dec 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator
aleethie In order to help you better I need the complete model number of your washer. You can find it under the lid on the frame. Gendos
Jul 01, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
976 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
