Question about Panasonic Televison & Video
I have a panasonic pt-53wx54j tv there is a blue picture on top and lower screen it wont go away
Slinteriors
  • 8617 Answers
SOURCE: Panasonic PT -47WXC43G 42 inch TV
replace the convergence amp ICs both of them. They cost about 15.00 each
Posted on Mar 10, 2008
Slinteriors
  • 8617 Answers
SOURCE: panasonic cinemavision pt-53wx54j
if the led is blinking one time its the 140 volt circuit. If its blinking a series of 3 blinks its the convergence circuit
Posted on Feb 16, 2009
  • 13 Answers
SOURCE: I have a Panasonic PT-53WX54J that will not Converge
you need to replace or have professional convergence amplifiiers. If know how to desolder and solder you could repair yourself or in home professional tv repairperson will cost you $275-$400. The convergence adjustments via remote are half the battle the IC's loose clarity over time.
Posted on Aug 23, 2009
Slinteriors
  • 8617 Answers
SOURCE: I have a Panasonic pt-53wx54j rear projection tv
The HV from the Flyback. Double check the flyback wire going to the HV splitter.
Posted on Nov 07, 2009
  • 111 Answers
SOURCE: I have a Panasonic PT-52LCX65-K TV. It has some
no you have a bad light engine sorry
Posted on Feb 04, 2010
Panasonic PT-53wx54j" Rear Projection Television blinking light 3 times, wont turn back on. Originally turned off by itself
sounds like a bad power supply my mother has one done the same thing we found out he power supply went bad $125 to fix so we junked it and she bought another TV
Jan 29, 2014 | Panasonic PT-47WX49 47" Rear Projection...
Problem with Panasonic PT-53WX54J 53 in. Rear Projection HDTV Television - Green Screen
You may have a component failing in the red drive stage possibly the blue as well or even the quadrature stage. A can of cold shot should help narrow the search considerably. It is also possible the red and blue projection tubes are nearing the end of their service life as well. If you have the means to test the tubes themselves, check the red and blue tubes for gas.
Dec 19, 2011 | Panasonic Televison & Video
Hi Their, I have a Panasonic TV (PT-53WX54J) That wont turn on can you help me please...
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2011 | Panasonic PT-53WX54 53" Rear Projection...
I replaced the convergence ICs and the resistors on my Panasonic PT-53wx54j. When I powered it up, it worked great. After about an hour, the blue started to blur across the screen, and then the TV shut...
nwlounsberry,
Check all the components in the vicinitry of the convergence ICs. Concentrate on the diodes, resistors and electrolytic capacitors. In fact all the more they cost I would just replace all of them. If I had to guess I would say you have a bad electrolytic capacitor. Cost is minimal. Parts are available at http://www.mcmelectronics.com .
Thanks for using FixYa and for the great rating. Please consider a testimonial.
hardrocko
Jan 08, 2011 | Panasonic Televison & Video
Panasonic PT-47WX54J - There are colors running down the middle of the screen while the rest is black. I cannot access a menu to make any changes.
Let me ask you an important question to resolve what I think your problem is:
Do you see a narrow band of light from top to bottom but no picture?
Does it take it a minute or so and is just to the right of center on the screen? It can be towards the far right---Is this what you are dealing with?
Respond by making a comment here or if you repost the question mark it in the title: ATTENTION SD TECH.
IF you have the problem I suspect you do it is a bad cap and I can tell you exactly how to get at it and replace it.
I am here to help.
REGARDS, SD TECH
Aug 13, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Aug 23, 2009 | Panasonic Televison & Video
Panasonic cinemavision pt-53wx54j
Feb 15, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
