Question about Chicago Pneumatic Heavy Duty Jitterbug Air Sander
BUFFAL OPNEUMATIC ORBITAL SANDER MODEL966 ANY BODY KNOW ANYTHING ABOUT THIS SANDER?
WON'T VIBRATE. ACTS LIKE A GASKET IS BAD. WHERE CAN ONE GET PARTS FOR THIS MODEL SANDER?
Have a Metabo SR221 sander and a part is broken but don't know the name of it. There are 4 things that vibrate ???
Bearing Pot part number 341142470, swivel Pin part number 344091780 and if the springs are bad they are called the torsion springs part number 342020930
Jun 26, 2017 | Sander Tools & Hardware - Others
Palm sander not vibrating
Only real way to find out what is wrong is to open it up on this one. They are mostly plastic parts and you will probably find the broken part or where a gear is worn out.
Jul 04, 2016 | Ryobi Tools & Hardware - Others
Parts manual sander model 315.11751
Confused:
"Problem with Riding Mowers & Garden Tractors"
"Parts manual sander model 315.1175"
"Need large plastic driven gear for dust impeller"
So is this a mower/tractor? ... If it's a manual sander, why does it have a gear, driven by plastic, for a dust impeller? Who is the manufacturer of said ambiguous item?
Have you contacted the manufacturer?
Sep 02, 2012 | Garden
No powerto sander. Cord is good,switch is good and brushes are long
It sounds to me that you have used the sander a lot and the vibration has broken a wire or it's about to break on the field windings. The brushes you need to look at to see if worn. But I kind of think wire problem. I had this happen on mine and opened it up to find this is what happened. The sander would be turned on and would not operate until I turn upside down and it would work. This is great if you are sanding upside down but this is just a sign that you are on borrowed time as this will eventually not turn on at all. I was able to fix mine with new wire crimp connection and solder with heat shrink material. If not you can order new field winding if this is what is wrong. Cleaning up the sander won't hurt either. You might want to see what a new sander will cost vs. part. Good Luck!
Aug 23, 2012 | Dewalt Sander,random Orbital - DEWALT
Model no 333 wont start unless i turn it on its side?
Aug 15, 2010 | Porter Cable 332K Quicksand Random Orbit...
Excess vibration
Remove the 4 sander plate screws being carefull not to strip them. Look at the plastic ******** extentions attached/flooting to the houseing and look for broken or bent arms on them ,replace with new ones, this should solve your problem.
Mar 19, 2009 | Porter Cable Cable 0330 Speed - Bloc...
Open Questions:
Chicago Pneumatic  Heavy Duty Jitterbug Air Sander Logo
75 people viewed this question
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
