Question about Acer Aspire 3680 Laptop
Image or Ghost my pc
I have had a major lifestyle change and I need to "clean" my computer. I don\'t want any remnants of **** on my computer and I am not savvy enough to completely remove all that **** from my acer computer. there are 3 profiles on my computer. one is the one my father set up one is mine and one is a guest account. I want administrative rights on my account. I need to clean the memory of **** from my computer.
However I have documents for school and things that I would like to keep like all of my music. how do I back up these files and "wipe clean" the rest.
I also have no money for downloads or for products.
  • tinamariek Oct 23, 2008
    it is an acer with windows vista
    Thank you so much! This has been a real Godsend. I have three questions though.
    1 What is an ethernet? Is it a what is plugged into the back of my old desk tower type of pc? Does it look like a phone jack/wire?
    2 Where can I double check that I have all drivers? You said I could use "this link" (in the second paragraph after step 8)
    3 Where would my Acer model # be?
    Thank you again. I will post again after I have finished going through all of these steps.
  • 34 Answers
What type of computer is it?
Posted on Oct 23, 2008
  • 1 more comment
  • fixyaixya
    fixyaixya Oct 23, 2008
    If you have been watching pron on your computer you probably have viruses. That stuff destroys computers and I don’t know how many times ive had to reinstall windows on my friends computer because of that… Every one of my friends that I do that for I tell them… Ill do it for free this time but next time ill charge you cause im not your mommy that has to clean up after you… If your computer runs perfect… just delete everything, uninstall all programs you don’t want and defragment your computer. Run a virus scan… download adaware free and run the program. And be on your way… If your laptop runs like **** which it probably does watching porn on it… read the following.
    PLEASE KEEP IN MIND! This process deletes ABSOLUTELY EVERYTHING! Including any programs you might have installed like adobe, or Microsoft suite. So don’t be surprised when you reinstall windows and there are no programs on your computer… Just FYI before you do this. I would not recommend you try this unless you are some what tech savy. If you are not go find some geek to reinstall windows and im sure they will do it for a cheap price. But please don’t go to geek squad… they rip people off… you would be better off buying a new laptop then dealing with those guys…
    1st. take everything you want to keep and put it on a cd. If it wont fit on a cd put it on multiple cds. This is the only way your going to safely transfer your files. Be careful about what you take cause viruses like to interweave them selves to other files some times… So only take what is important.
    2nd download a version of windows vista installation off of limewire or ares or any file sharing network. At this point you wont have to worry about viruses since your about to wipe your computer. You don’t need to worry about piracy as you have your own vista serial number that should be located on the bottom of the laptop on the authenticity sticker.
    3rd. Print these directions out because once you do the wipe you may not be able to access this again until the process is complete.
    4th. Put the vista installation on a cd. Make sure it is not compressed.
    5th. Place the cd in your cd player on your laptop. You might get a screen that asks you if you would like to repair windows or do a fresh install. If you do that is a good thing. Do the fresh install. If this does not happen, restart your computer with the cd in the drive. When you see the acer logo come up, depending on your system you wil have to hit 1 of the following buttons. (F2, F8, or F10, or F12 or delete). Anyways, you are looking for the boot menu. In the boot menu you will find an option to boot from a cd or disk. Click that option. (try each F button until you find this menu. You may have to restart a couple times if you don’t get it the first time.)
    6th once the process starts it is pretty self explanatory. MAKE SURE! That you delete any partitions that are left on your laptop. Some viruses can partition a hard drive and hide there so that your system can not see it. You will see what im talking about. Now select the hard drive and install windows. Now you wait and answer and questions during the install.
    7th. Now that was the easy part. The hard part is getting all of the drivers installed back onto your computer so that everything works properly. What you will need to do is connect your laptop with an Ethernet as your wireless no longer works until you install the driver for it. Basically every piece of hardware that is installed on your computer need a driver to work correctly… example: bios, chipset, wireless adapter, video, sound, etc…. pretty much everything. SO!!! This process is very important and must be done correctly.
    8th. Go to the ACER website. They have a downloads and support section… Go there and look for drivers and downloads. You should be able to look up what computer you have and it will list out all the drivers you need. Download these drivers in order from top to bottom. Hopefully, they are smart enough to put them in order that they should be installed. Download the first then install. Download the second then install… If any of the installs asks you to restart do just that.
    There you go. After that is all done your computer will probably run better than it did when you bought it. SO NO MORE PORN!
    Just incase acers website does not give you the drivers you need this link will provide you with all of the specs on your computer. This way you know exactly what drivers you are looking for. In the case that your comp is different im sure you will know… but the rest is pulled by spec of your system. Hope this helps and good luck. This process should take 30 min to 2 hours depending on your level of expertise.
  • fixyaixya
    also, if you use mozilla firefox as a browser instead of internet explorer you wont get viruses quiet so much. it has a spam / virus / adaware / spyware blocker. it is awesome. so use it and dont click on anything dumb.
  • fixyaixya
    fixyaixya Oct 24, 2008
    Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista HomeBasic 9980286710 PC Notebook >
    I was assuming that this was your note book. This was in the title.
    go here for a list of the drivers your computer recommends... You may not need all of them... if you dont have a camera or wtvr you wont need the driver for it and that goes for the rest of them... if you are not sure what you have or if you need it... install it anyways... it wont hurt anything.
    http://www.acerpanam.com/synapse/forms/A...
    yes the ethernet looks like a phone cord but its bigger. you need to use that instead of wiresless since the wireless needs a driver.
    once all the windows install is complete go to the website and install the recommended drivers on the website for your model. Im assuming its the Aspire 3680?
    If this info helps you please rate. Thanks.
RICOH FW740 is printing with a ghost image. Can I clean it myself?
Ghost images appear on the printed page because of bad cleaning blade or improper charging of the drum unit. Ghost images appear on the next printed page if cleaning blade does not clean the drum surface. Drum/ photoconductor is very sensitive to light, so special care should taken while pulling it out. Read More here Image ghosting problem
Dec 02, 2011 | Ricoh Office Equipment & Supplies
Does Alohabob PC backup give you the option to reinstall start menu programs from the backup, just as they were in your start menu before you backed them up, Rather than reinstalling from CD/DVD's? I...
If it truly is backup software then yes and no. Yes it can back up the programs but a lot of the time there are registering of DLL files and registry settings that don't get backed up and there for the programs wont work. So backing up programs is never a good idea. You can however download some free software such as EASEUS. This program can do drive to drive copy this would allow your programs to be copied over and work on the new hard drive. You could also get Norton Ghost and create and image disc and use that as well to essentially move the programs and data to the new computer.
Comment if you need further assistance.
Aug 15, 2011 | Eisenworld Alohabob PC Backup for PC
Hey Guy ! i have a big broplem ! i have 4 desktop PC !i want to clone this harddiks! so i use hiren's boot Cd ..but i think that's not Ok for me ....some hDD when i use Ghost HDD ,, It too slowly...
Hi there, In my experience, Norton Ghost is the fastest cloning software. If you want a true clone of a large hard drive, it's not physically possible to do it in less than 15 minutes. There are a few things you can do to speed it up though. If you're cloning to an image or another hard drive, write it to a local hard drive within the computer. SATA to SATA transfers are always the fastest, so try and avoid using USB. Ghost really is the best tool for cloning hard drives and it can be very fast when done internally on a computer. That's my recommendation. Alex
Jun 06, 2011 | Computers & Internet
Is it possible to create one generic win 7 ghost image and use it on any pc or laptop. I've tried this in the past with xp and it was an epic failure; sometimes it worked after ghosting, sometimes it...
A ghost image can be used on only one computer the same image cannot be replicated on other machines. Create a different image for the other computers and then burn the image file to the DVD drive for future use.
Dec 19, 2010 | Computers & Internet
How do erase partition and wipe clean, saving operating systerm
the only way to erase a partition and wipe it clean while saving the OS is to use Symantec Norton Ghost (or a similar product) and create a Ghost image before you delete the partition and restore it after you have deleted the existing partition, recreated a new one and formatted it. then restore the OS from the ghost image.
Apr 15, 2010 | Compaq Computers & Internet
Ghost-image on VPL PX31
There is dust in RGB Panel,that ghost image is actual dust.It need to clean.
Mar 16, 2010 | Sony VPL PX31 Multimedia Projector
Hi, How do I recover my Office 2003 Auto Correct from Norton Ghost? I back up my PC image and formated my hardrive. Now I want to reover just my autocoreect file and apply it to my new Windows...
This will only work if the drive with your new Windows installation is larger than the drive with your ghost image.
Assuming that the above is true, do the following:
Using disk management, create a partition on your hard drive which is large enough to accept your entire ghost backup. Restore your ghost image to this partition and then select any files or folders you may need. Once you have the necessary files you can delete the partition again if need be and use it for other storage purposes.
Let me know if you need any further assistance regarding the above.
Best wishes,
Graemevm
Dec 20, 2009 | Symantec Norton Ghost 14.0: Windows
Epson 1290 prints a ghost image in cyan or magenta
I like this one! No don't have a solution but....interesting Try it's test not by computer, just printer, may need head alignment, should be a command for this on printer
Apr 23, 2009 | Epson Stylus Photo 1290 InkJet Printer
Dell Precision 490 constant reboot after ghost image completed
Hello-
I figured out how to ghost a Dell Precision 490 with a 32 bit Windows XP Image! Like you I had the same problem where it would constantly reboot after I imaged it with an existing 490 image. The answer is actually very simple. Boot up your Precision 490 and hit F2 to enter the bios. Select Drives and then SATA Operation, change it to "Raid Autodetect / ATA". Reboot the 490 and re image the machine, it will now work!
Dec 01, 2008 | Dell Precision Workstation 490 - MT -...
Ibm thinkpad T40 Hard Drive change out
After fdisk and format you need to ensure that operative system is installed into yor hard drive. Using ghost you restore the image disk by booting from ghost image CD if you made a bootable image disk. Ensure Bios is set up to boot from CD.
If you used Norton Ghost ensure you captured the image of full bootable original hard disk drive for same computer. If it does not boot after restoring ghosted image, than the image it is probably not complete. If hard disk image is not good, easiest thing to do is using Windows install CD to installl again operative system, then you eventually restore ghost image.
Aug 17, 2008 | IBM ThinkPad T40 2373 Notebook
Acer Aspire 3680 Laptop Logo
97 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
