THE SET POWER ON BUT NO PICTURE
TOOK TO THE TECHNICIAN.UNFORTUNATELY NOWHERE HE CAN ORDER 2 BOARDS.LIKE IF THE COMPANY WHO MADE THE TV DID VANISH.NO PHONE NO WEBSITE. THE TV IS AN EYEFI LX4700.
  • REGRAGUI1950 Oct 27, 2008
    the firrst board is the control board#667-L37T-01C
    the second is the power supply#667-L47K17-20
Has anyone found these power supply boards. I believe the Polaroid LCD uses the same power supply. Andrews Electrionics has a part that uses this number and is a power supply. The part is $166.00. However, it is a special order part and cannot be returned if it is the wrong board.
Posted on Jan 19, 2009
  • gfree172
    gfree172 Jun 15, 2012
    I have a power supply for your model
The company did vanish !!!! I been running around the last 7 months trying to get parts. I have called practically everone in North America trying to get parts, I also calles Sams club who sold this S**T and they were no help. Largest piece of garbage I have ever owned.
Posted on Jan 02, 2009
I have a Vizio LCD TV. The TV powers on but white horizontal lines flash across the top third of the screen and then eventually vanish. Even after they are gone I have no picture. What's wrong?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 21, 2016 | Vizio Televison & Video
To fix no video Vizio E470i-A0 TV
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
May 21, 2015 | Vizio Televison & Video
It wont turn on at all
Good day to mam wendy311!!!!
If you TV is totally dead set and no red light or green light on the front...
if that so the problem could be cause of dead set power power supply board...
You have 3 choices its either repair it on your own or took it to the technician or buy a new set of power supply board..
But for me I suggest to buy a new power supply board because if you took it to the technician cost of repair is almost or higher depends on the bad parts than the new power supply board...
But before you buy a new PSU please check this simple and common parts that usually cause of dead power supply board..
  1. Transistor----Check if shorted
  2. Capacitors----Check if bulged or leak.
  3. Resistors----Check if open or change value..
  4. Fuses---------Check if busted..
I hope this solution will be helpful..
Thanks for using fixya...
Aug 12, 2011 | Apex Digital LD4088 LCD TV
When I turn my TV on there is sound, but, the picture vanishes after a couple of seconds. Why?
The backlight inverter is what powers the screen to "light up." You will need to check your power supply for the proper voltages going to the backlight inverter. If those all check out ok, then you need to replace your inverter to get your image back. You can find a new inverter by searching "inverter + model number of your tv.
Please rate if this helped :)
Apr 04, 2011 | LG Televison & Video
My tv projector, the screen turn black no picture and for awhile just sound and than turns off, after 5 or 10 minutes, how can i fix the problem with out call a technician
Unfortunately in this scenario the only way you can fix your TV is by calling a technician. It sounds like your power board is failing and you will need to replace that in order for it to function correctly again.
Mar 03, 2011 | Pioneer Televison & Video
My Sony WEGA kv-32" TV
The "D" board is the main circuit board assembly containing most of the set's power and deflection circuitry. It's the board that typically causes most of the problems because there's so much on it. Unfortunately, this board is no longer available from Sony as a part, and must be repaired to the component level. Many shops don't want to (or can't) get into that depth of repair, so they quote a high price on board replacement. There is no single part you could order to repair this board yourself, I'm afraid. There are some companies in the business of repairing boards, but you're still looking at $200 to $300. With the price of a 32-inch LCD set now around $300 to $400, there's no point in trying to fix a TV when it's just a few dollars more for replacement.
Jan 01, 2011 | Sony FD Trinitron WEGA KV-32HS500 32" TV
The tv picture vanishes and there is multi-colored lines on the screen for a second then shuts off and then will turn itself right back on and it will keep doing this
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
I have a 50'' SAMSUNG Plasma TV, yesterday the picture just vanished all of a sudden, I can still hear the speaker but the screen looks like it was turned off, what would the problem can be?
Same Problem HPT5054 plasma. $1000 Plasma Panel went out according to Geek Squad at Best Buy. Part is backordered in USA. Samsung said tv out of warranty so sorry.
Wish I would have bought American.
Dec 15, 2009 | Samsung HPT5054 50 in. HD-Ready Plasma...
No Picture on Viewsonic TV
Had a problem with 32'' viewsonic.No picture and had sound.Fix is a chip on power supply($15.00) part.I replaced and all ok now.
Jan 11, 2008 | Televison & Video
No power with remote or manual power switch
Your convergence module is probably bad. It is a plug in module, so labor would be lower if the convergence settings are still good. The bill would be about $300.00 If not, the labor for convergence would add to the bill. If the whole job needed full convergence the cost would be about $500 to $600. Hope this helps, Lee http://www.CrazyComputers.com
Jun 22, 2007 | RCA P60921 60" Rear Projection Television
Televison & Video Logo
197 people viewed this question
Top Televison & Video Experts
Electro Med Services...
