Question about Brother HL-2040 Laser Printer
Brother HL-2230 drum reset - Brother HL-2040 Laser Printer
jaylex
  • 417 Answers
SOURCE: Brother HL-5240 drum light flashing
Normally clearing the drum count the machine has to be on open front cover as if to change the drum press and hold the button in for about 10 second then release and shut the door. This should reset the count if not please get back to me and I'll check the service manual to see if anything in that.
Thanks J
Posted on Feb 04, 2008
crayzeetrayn
  • 837 Answers
SOURCE: I am changing the drum on my Brother HL-4040N
Follow these instructions
Posted on Dec 31, 2008
POCBM
  • 121 Answers
SOURCE: Brother HL 1250 Laser. Drum & page counter
Reset the drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
  4. close front cover
Posted on Mar 23, 2009
  • 10 Answers
SOURCE: How do I replace the drum on a Brother hl 2040.
I have 'reused' the same drum three times and still prints like a charm.
Open the toner door and pull out the toner/drum assembly. Take the toner off the drum tray. Use a alcohol pad or lint free cloth and wipe the mauve coloured drum to remove the excess lint and toner collected on the drum. Rotate the drum with the white gear and keep cleaning until the whole drum is done.
Put the toner back in the drum tray. Clean the corona wire by sliding the blue tab back and forth 3 or 4 times. Put the toner/drum back into the printer and close the door.
After the printer does the self test the drum light will cone on again so then you need to reset the counters.
Open the door again
Hold the GO button until all 4 lights are lit up
Release the GO button
Close the door
Printer will self test and should extinguish all the trouble lights.
Posted on Apr 20, 2009
  • 73 Answers
SOURCE: I have on my Brother HL-4040cn, drum end soon.
Here is a photo of the drum unit and a link to the Brother website for you printer.
http://www.brother-usa.com/support/default.aspx?PGID=1&R3ModelID=HL4040CNaefb82c.gif
Posted on Mar 11, 2010
OPC-Life over error. How to fixit
If the print quality is still acceptable you may be able to perform a reset on the drum counter. If print quality is bad you will need a new drum. Reset instructions at this site.
Brother HL 2150N Drum Unit Reset Instructions
May 26, 2015 | Brother HL-2150N Laser Printer
How do I remove a stuck toner cartridge
Did you try to press DOWN the BLUE TAB that des-ENGAGE THE TONER FROM THE DRUM?
Dec 06, 2014 | Brother HL-2230 High Yield Black Toner...
Hl 2270 won't stop printing
I would guess you were trying to print a spread sheet or similar. It has nothing to do with the reset gear on the cartridge. You need to open your printers folder on the computer, open the print queue for the printer, and cancel all documents waiting to be printed. That may take more than one try. When you are ready to print again, be sure you know what is to be printed before committing.
Apr 21, 2014 | Brother Reset Gear for TN-450 TN450 TN420...
How to install hl 2230 brother printer off a usb drive
Make sure you have drivers for the 2230 brother printer put the driver s in the windows folder. Go to control panel...printers click on it. Should say have disk and find drivers then install. Sometime there will be exe file that decompressed driver files will start as blue screen follow directions.
Dec 11, 2013 | Brother HL 5250DN Laser Printer
BROTHER HL-7050 CHANGE DRUM STILL INDICATES CHANGE DRUM
you need to reset drum counter by pressing go & + together "reset parts life" "drum unit"
then press "SET" button.
that's it.
Feb 12, 2010 | Brother HL 7050 Laser Printer
Mar 23, 2009 | Brother HL 1250 Laser Printer
Brother printer HL 5250 DN. The drum light was flashes and I have replaced the drum kit and toner cartridge.
Brother Drum Reset Instructions
The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Reset the drum counter only when you replaced the drum unit with a new one.
Dec 05, 2008 | Brother HL-2070N Laser Printer
Printer drum light on
Have you already replaced the drum? If you have not replaced the drum that may be why you are getting smudges. If you have already replaced the drum, here is the reset procedure. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one. The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below: Open the front cover of the printer. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button. Close the front cover. CautionReset the drum counter only when you replaced the drum unit with a new one.Related Models HL-2030, HL-2030R, HL-2040, HL-2040R, HL-2070N, HL-2070NR http://www.tonerovernight.com
Mar 31, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
690 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
