Question about Behringer Xenyx 502 Audio Live Music Mixer New!
Low-frequency buzzing/static in my recordings (behringer xenyx 502) wont go away
HI, Recently I purchased a Behringer Xenyx 502 to go with my Behringer C-1 microphone to do some acoustic recordings. Originally I had a large buzzing sound through the output that I was able to largely get rid of by changing my power source, however there is still a static noise I am unable to get rid of. I unplugged my microphone so that there was no inputs and I still get the buzzing. It does go away when I turn the gain/output levels down however this kills off the output to the point where any recordings are almost silent. Anyone else had this problem and managed to find a solution? Thanks
  • 5603 Answers
SOURCE: Behringer XENYX 1622FX, won't power on. Phantom power works(?)
After reviewing the schematic, I don't understand how the Phantom power can REMAIN on with the power switch off... this CANNOT occur except for what energy is left in the 48 volt supply filter cap... This might last for minutes after the fuse went... UNLESS you have devices connected which are backfeeding the 48 volts. (which would be a disaster)
The 48 volts, +/- 12 volts and +/- 15 volts and the +5 volts ALL come from the SAME switching power supply. I suspect one of the filter caps went or the primary switching regulator a TDP245Y chip.
You should ONLY work on the line side of this using an ISOLATION transformer since the line side has lethal voltages.
To do testing, one replaces the fuse and puts a 60 Watt light bulb in series with the hot side of the inout line. The lamp "acts" as a resetable fuse and limits the current for testing. When all is well again, the lamp will remain out with the power flowing through it.
The D1 diode bridge and C7 input rectifier and filter are first things to check. You can do those with an ohmmeter.
I will caution you to ALWAYS power any and all equipment from the SAME power source. Plugging in devices from across the room will set up ground loops and any ground fault will fry equipment.
Posted on Apr 05, 2010
  • 5603 Answers
SOURCE: LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Posted on Apr 28, 2010
  • 5603 Answers
SOURCE: type pf op amp in a Behringer XENYX 1204USB Mixer
Behringer uses 4580's in appropriate packaging everywhere. There are 339 comparators for the level indicator area.
The Mackies uses both NJM2068 and NJM4560M
The 2068' are used in most of the low noise areas and the 4560 is used in the 75Hz high pass filter for example.
Posted on Jul 23, 2010
  • 6 Answers
SOURCE: I have an Behringer Xenyx 1222FX that won't power
The phantom power light wouldn't illuminate unless the unit was powered on. Possibly the main power indicator light is burned out.
Posted on Jan 16, 2011
  • 5603 Answers
SOURCE: how much output power supply
The supply will be similar to that in the 1222. Download a schematic here. Look at the SPUS2 portion of the compressed file.
http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m_ub-spsu2_sch.zip/download.html
There are several voltages present.
Posted on Jan 20, 2011
Behringer Xenyx 502 Mic buzzing...PLEASE HELP
Get yourself anti-static spray and spray over the connector before inserting into the jack, most times its dust or static buildup which causes that buzzing sound and in other times replace your mic
Mar 02, 2012 | Behringer Xenyx 502 Audio Live Music Mixer...
I want to know the contact detail of Behringer Xenyx 502 Audio Live in Delhi, India
MUSIC Group Services EU GmbH Otto-Brenner-Strasse 4a
47877 Willich, Germany
Tel: +49 2154 9206 4149
Jan 27, 2012 | Behringer Xenyx 502 Audio Live Music Mixer...
I am trying to record from xenyx 2442fx to audacity. I am not sure how. I think it has something to do with usb, but do not know how to connect the mixer to the computer to get a good sound. Please help.
First, connect the USB audio interface which came with the Xenyx to a USB port on the PC. Then connect the TAPE OUT from the Xenyx to the IN of the USB audio interface. And connect the OUT of the USB audio interface to the TAPE IN of the Xenyx. You should now be able to record from any of the Xenyx channels. To listen back, engage the control room button which reads CD/TAPE. Contact me if you need any clarification.
Sep 06, 2011 | Behringer XENYX 2442FX Mixer
I have a Behringer xenyx 1202 fx. I get static when I turn up the main fx to main control. I've had the unit for a year working fine until now.
Sounds very much like the control knob is dirty, needs a good cleaning!
Sometimes just giving the knob a good exercising (turn it up and down quickly a few times) can help it.
Some cleaners can leave behind a residue and make it worse, so ask at an amp repair place what product is best to use.
Hope this helps!
Jul 13, 2011 | Behringer XENyX 1202 FX Bundle
I have the Behringer Xenyx 502 mixer, it's brand-new, and for some reason there's a weird buzzing/hissing sound in the main mix that will just not go away no matter what I do. I've unplugged everything,...
Is the sound a low frequency buzz or high frequency hiss? With all the input level controls at the minimum position and the output level controls at the maximum is the sound audible?
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 31, 2011 | Behringer Xenyx 502 Audio Live Music Mixer...
Type pf op amp in a Behringer XENYX 1204USB Mixer and a Mackie - 1202-VLZ3
Jul 22, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
How do i hook 1202fx to computer?
just connect a baby plug to rca from the pc to the mixer respectively
Feb 14, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Behringer Xenyx 502 Audio Live Music Mixer New! Logo
510 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
