Question about JVC RX-6018V Receiver
JVC Receiver RX-6018V - power no input
Help. My JVC receiver, RX-6018V will power up, but there is no sound from the speakers. It's not showing any input signal on the display. We have had this system for several years with no problems, not poof, nothing. I've unplugged the receiver and plugged it back in, but still nothing. help?
  • copernicus12 May 24, 2008
    jvc rx-6018v is having problems , no sound comming out of it, i think its about the settings on it, the button near the adjust
3 Suggested Answers
SOURCE: JVC RX-884VBK RECEIVER
The JVC RX-884VBK is a great machine, I had it for over 5 years and had no problem at all. I came across the (NO SOUND at all) and I believe it is an easy fix. Check the Front left, there are 2 keys marked 1 and 2 for SPEAKERS output, sometimes you don't notice that you connected the speakers to 1 and the 2 key is pressed. You could have both keys pressed and you will get the sound. I hope that helps.
Posted on Jan 14, 2008
SOURCE: jvc rx-5032v audio/vido control receiver
HI MATE YOU NEED THE REMOTE
Posted on Aug 19, 2008
How do I get the digital audio cable to work from my tv to my JVC rx-6018v reciever
To start, make sure your receiver supports "digital" in the form of coax (rca) or optical type to their respected video inputs.
Mar 31, 2014 | Audio Players & Recorders
How can I hook up my jvc rx-6018v to a gemini xga-2000 amplifier?
you can do it a couple of different ways, depending on what you're trying to do with your set-up.if you're trying to do something different than what I describe here, add a comment.
for independent volume control (each unit contols volume to a set of speakers independent of each other) use the rca 'tape' out of the jvc into the rca inputs on the back of the gemini.this puts a stereo signal from the jvc to the gemini. if you want your gemini to power your subs, get an rca y-splitter (single female to double male) and a single rca cable, hook single rca cable to sub out of jvc, connect y-splitter to gemini rca inputs, and single rca to y-splitter.
Mar 05, 2013 | JVC RX-6018V Receiver
How do i turn off the linear pcm on a jvc rx-6018v
The nature of a source's digital bitstream is automatically detected at the receiver. Look at your unidentified source and ITS manual for that answer.
http://www.retrevo.com/support/JVC-RX-6018VBKJ-Receivers-manual/id/315ag011/t/2/
See the box on page 14.
Sep 23, 2011 | JVC RX-6018V Receiver
5.1 surround sound will not work. Only showing digital auto and linear pcm.
You should try pressing the surround on/off button or the speakers on/off button
Jan 02, 2011 | JVC RX-6018V Receiver
My subwoofer is working but I think it developed a short ciruit. The input jack in the back hums but no sound? Am I right and where can I go to get it repaired?
you need to perform this ...one end of the jack is on the input of your unit and the opposite end try to touch if there is hum ..set a maximum volume..to hear it better...if there is sound your unit is good..if without,your input is deffective..make sure that our jack is good.
Sep 06, 2010 | JVC RX-6018V Receiver
No sound out of subwoofer
Connection from receiver subwoofer output jack RCA plug male go into your powered subwoofer low level input with other end of cable, then you need to select Subwoofer YES/NO on the JVC receiver speaker setup menu option, select YES if this is a powered subwoofer you are using, should power up the subwoofer, may have to adjust a test tone balance for multi speaker output also, try trimming up on the subwoofer channel to initiate the signal on if the sub has an auto-on feature.
Feb 07, 2009 | JVC RX-5020VBK Receiver
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
JVC receiver
Did you check impedance value and wattage on speakers you want to add to receiver?
Sep 30, 2007 | JVC RX-6018V Receiver
Overload
No, one of your speakers is damaged (could be an amp channel went bad, but speaker is more likely). Unplug all spkrs, then plug one in and see if it acts normal when turned up. Repeat this until all speakers are hooked up or the culprit spkr is found.
Sep 25, 2007 | JVC RX-6018V Receiver
Overload
Try first to disconnect all of your speaker wires and turn back on this receiver. If the problem persists, you will need to take the unit into a shop and have the output circuits checked out, as these are all solid state parts that are soldered into the printed circuit boards and there are no user replaceable parts inside this receiver. Good Luck
Jun 07, 2007 | JVC RX-6018V Receiver
JVC RX-6018V Receiver Logo
79 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
