Question about Pentair Super Flo 1 Hp Pool Pump 340038
Pentair superflo electrical wiring
2 blue wires & 1 green on pump, 1 yellow wire, 1 blue, & 1 green on control box (2 black & 2 red on box already coupled off).
  • landsharkcon Feb 09, 2012
    Not sure what to connect to what.
    Top Expert:
  • Pentair Master
  • 5,781 Answers
If 220 volts 2 blues 1 to L1 one to L2 green to ground or case
Posted on May 08, 2016
  • 59 Answers
SOURCE: I am replacing a waterways pump and motor
on the motor is a label giving the hp and motor specs. there is also a figure on the label showing the wiring for low voltage and hi voltage.
David
Posted on May 25, 2009
john224
  • 1378 Answers
SOURCE: Pentair WhisperFlo Wiring Help
If you just bought this then there will be a diagram on the motor nameplate and/or under the terminal cover where you connect the wires. Generally speaking, there are two wires inside the motor that change positions depending on 115 or 230 v connection. If one of the wires is on a post common to one of the line leads, that usually means you have the motor set for 115V. Is that the voltage you are supplying to the motor? If there is no diagram you can make out on the motor, post what brand motor and the motor model number for a diagram.
Posted on Dec 24, 2009
  • 8404 Answers
SOURCE: pentaire 011486 wiring diagram
My friend, my experience with the two speed pump in low speed is less than spectacular. There is so little filter action with the lower speed as to render the process useless. If you are trying to save $, better to run the pump a little longer then turn it off. My experience is in a commercial application. I run three such pumps in that system ... the additional expense of the two speed motors was a waste of capitol. In addition, as a commercial facility, we could not meet the required water turn over rate in our pools. Of course yours is a smaller body of water and you are probably not in a commercial facility. We get a LOT of cleaning (through filtration) at night, after the customers go home.
I suppose you could run your system with a intelematic switch ... I have not seen a 'three way' switch in this line ... having said that ... to my way of thinking ... you would wire directly through the selector switch on the back of the motor to each of two intelematic's; one on the high side and the other on the low side. I would allow at least 30 minutes between the two cycles to prevent impeller damage.
Thanks for your interest in FixYa.com
Posted on Aug 02, 2010
john224
  • 1378 Answers
SOURCE: My pump (pentair whisper flow 1 hp) has been
Based on your description of the breakers you should have 230VAC to the pump motor. Even if it is only 115VAC you should still get a response from the unit when powered on. A 230-connected motor will run on 115 for some time but will overheat and eventually fail. If you are getting nothing you have issues with the power as well as the pump. Get the $40-$50 multimeter and check your line voltages to ground and line-to-line. You will find a problem somewhere.
And to answer your other question...yes, connecting 230VAC to a motor setup for 115 will burn up the winding.
John
Posted on Jan 17, 2011
jturcotte
  • 8531 Answers
SOURCE: I have a pentair superflo
Could be the motor has packed up. Or, more likely, perhaps the contacts or coil in the timer have failed. That is a big motor, and a lot of current is going thru the timer contacts. Can you apply voltage directly to the motor? Do you have an AC voltmeter to check the power from the timer with?
Posted on May 15, 2011
How do I install the 4 prong electrical cable to the dryer?
I would attach the black wire to the black & yellow, white to white, red to blue & brown. The green wire is your ground wire and needs to be attached to the cabinet. On the connection where your white wire is located see if there is a copper strap that goes from the terminal block to the cabinet. If there is, you will need to remove that strap and attach the green wire to where the strap was attached to the cabinet. Hope this helps!
Sep 16, 2014 | Dryers
Tip
Telephone jack wiring
Most cheap jacks have 4 wires, red, green, yellow & black. Most modern houses have wires paired up (twisted pair) like blue & white with blue line or stripe. Line 1 is red/green or blue/white. Line 2 is yellow/black or orange/white(with orange line/stripe).
on Feb 21, 2015 | Lands Phones
Pentair Superflo 1 hp. two speed wiring help ??
pump runs 120 volt low speed need 2nd hot for high speed see side of motor
Aug 22, 2017 | Pool & Spa
Wiring
see side of motor it is set up for 220 volt 1st hot black or color to L1 2nd hot black or color to L2 green to case or ground
Jun 15, 2013 | Pentair Superflo 1 12 Hp Swimming Pool...
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Connecting Electrical to Pentair SuperFlo Pump
if 220 volt ok from factory hot to L1 2nd hot to L2 green to ground or case if 120 volt see side of motor for wires to be moved for low voltage
Jun 26, 2012 | Pentair Wf 6 1.5hp Whisperflo Inground...
I have a general lee cb with a 4-pin standard mic. the wires in my mic cord broke at the plug. does wnyone know how to wire this type of mic back and what color wires go to the correct pin?there are 6...
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Jul 12, 2011 | Magnum DeltaForce CB Radio
I need the wiring for the mic
Here is the wire diagram for several common mics in relation to a 4 pin CB. Most recent 4 pin CB's such as Midland, Cobra, Connex, Uniden, etc can use 4 pin mics. The wiring is actually depending on the mic rather than the CB so long as the CB's are 4 pin as well. Once you go back to late 80's the 4 pin design was a little different. Anything new it is simpler.
Stock Mic 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - 4 wire 1- Shield 2- White 3- Red 4- Black
static - 6 wire 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500 Cobra CA Series 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - 4 wire 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta 1- Shield 2- White 3- Brown 4- Green
Turner RK56 Road King 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Regards, Tony
Apr 07, 2011 | Connex Radio Communications
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
Dec 18, 2010 | 1996 Jeep Grand Cherokee
Pentair Super Flo 1 Hp Pool Pump 340038 Logo
955 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
