Question about Vacuums
Power nozzel not working sears vacuum - Vacuums
Brown wire came off where does it go. electrolux guardian power nozzel
send me picture of the wires and connection location, then I'll be able to help
Jun 13, 2012 | Electrolux Guardian Bagged Canister Vacuum
Need help with power nozzel wiring. Two black connectors and a white and a grey connector. How do you arrange them in the power nozzel?
Give me a picture of your wires and connector and I'll tell you how to hook them up...or how they should be connected
Sep 09, 2011 | Electrolux Guardian Bagged Canister Vacuum
We have a Kenmore canister vacuum cleaner. the carpet cleaning attachment, I think is called the power mate has a beater that is intermittently working now
Your hose could be bad. The wires frequently go bad up by the handle switch. also could possibly be the wand, those go bad. You can check that by attaching your powermate directly to the nozzle without the wand and see if the same problem is there. Do you have the mini powermate also? the one that is usually mounted on the wand. If so plug that in directly to the hose and see if you have the same problem. If that tool works fine then the problem is in the powerhead.
Jan 03, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
My Rainbow Power Nozzel will not **** up things
Check your belt and make sure your brushroll is good.
Oct 20, 2009 | Vacuums
How do i open the roller area to my kenmore canister vacuum
You have to take off the top of the power nozzel that has the light lense. There are two pressure locks,one on each side. Use a screw driver to release. You will see the screws.Take the two screws out and on some models, there are two pressure locks on the back of the nozzel. Again use the screw driver to release. The top should come right off.Hope this helps.
Oct 18, 2009 | Kenmore 25512/ 25513 Progressive Canister...
My vacuum hose won't power on but the vacuum in the attic powers on
I guess you are talking about the power nozzel not working. Try pushing the reset button on the top of the power nozzel first. Make sure you have the switch on the hose handle is in the right possition. If it still dosen't work, you could have a bad switch or a broken wire in the hose itself. If this is the case, you'll have to take it to the shop. All you need to take is the hose and the power nozzel.
Oct 18, 2009 | Electrolux Central Vacuum
Just bought new power head electrolux guardian and
Did you get new wands with the power nozzel? The wires that power the nozzel run through the wands from the hose to the nozzel.The connectors at the end of the wires are fomous for getting too big and making a bad connection. This causes the on/off problem. This will only get worse if you continued use. The wires in the hose handle, the hose and the power nozzel elbow can all be changed out. You will not have to replace the hose handle or the wands unless the plactic has been burned. (A loose electrical connection causes heat). Take your hose,wands and nozzel to the shop for repair. Don't let the sales/service manager tell you that you need new parts until you can see the parts are bad. I think they saw you comming when they sold you the new nozzel.(just my opinion)
Oct 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
I just replaced the drive belt on a Guardian vacuum and am having difficulty putting the cover on. Is there a trick?
There is a collar on the power nozzel elbow where the elbow goes to the nozzel. You need to pry it off with a screw driver. Don't worry about it breaking. It just snaps off and on. This will make it easier to get the top aligned. Make sure that the front of the cover is touching the rubber bumper and lay the cover down to the back side of the nozzel. You will have to lean the elbow up when you are trying to get the cover down in place. You'll see what I mean when doing this. When you replace the screws, you'll have one that is shorter than the rest. The short screw goes in the hole on the front side of the nozzel on the part that the motor is not on. Hope this helps.
Oct 12, 2009 | Electrolux Guardian Bagged Canister Vacuum
How to open a kenmore powermate vacuum to replace belt
You have to take the light cover off (push in at the bottom on each side) and there are two screws.
Some models have pressure locks on the back of the power nozzel cover. Just use a screw driver.
Jul 15, 2009 | Kenmore Canister Vacuum Vacuum
Vacuums Logo
54 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
