Disk not working - Computers & Internet
  • Debs
    Debs May 11, 2010
    When you say disk not working do you mean the drive that the disk goes into or an actual disk itself?
    Guru:
  • 257 Answers
Ok once disk is not working and that makes your system not work at all alright
then if is for the disk replace with a new one and fix it back and enjoy your system ok
Rate this Solution
Posted on Oct 23, 2008
Toyota echo 2002 cd player (without cassette, marked 31804) Radio works fine, but when a put on a cd, it reads it and starts playing... with no sound. Any ideas? Thanks a lot
well , as with all discs, old player will NOT play all CDs.
not even close.
first ask an old guy for CDDA disk or buy one from walfart.
then try that, only these disks work in all players.
other disks may or will not work.
like DVD-R, CD-R and any other recordable disks will fail.
that is the acid test, if the CDDA disk works (real audio disk)
works then the drive is ok, if not, its bad. simple as apple pie.
Nov 14, 2014 | 2002 Toyota ECHO
Tip
Cloning Disks
Cloning an existing hard drive, whether it is a HHD or SSD can sometimes be very frustrating. Using the disk drive manufacture's cloning software does not always work, it may report allocation size, block size or sector size as being in compatible between the two disks. I have spent a great deal of time trying the different suggestions on the web to fix this problem and none seemed to work, that is, until I came across HDCLONE.
This is a free software utility that automatically corrects these incompatibility issues. The software can be found at www.hdclone.com . I have used this software to clone disks for two different laptops and I have not had any problems. I think the only limitation is the destination disk for the cloning must have a larger capacity than the capacity on the original disk. I cloned from an installed hard disk to a USBSSD and to a HDD/SSD hybrid disk and the cloned disk booted up and worked fine.
This software can be used either to clone an existing small disk to a larger disk, or making a backup disk that can be installed and used if necessary.
The cloning process from a 500Gb to a 1Tb disk took most of the day, so I would suggest you start the process when you go to bed so I will be completed by morning.
Let me know how the software worked for you.
on Nov 27, 2017 | Computers & Internet
Dvd player says no disk
does it read other disks?
try a few difference DvD's.
if other disks work, the disk you want to read is broken.
if other disks do not work, your dvd player is broken and you should get a new one or contact JVC if it is still under warranty.
May 02, 2011 | JVC XV-N320 DVD Player
The screen comes on that says it cannot read the disk, so we follow what the manual says, which is eject disk, turn machine off then on and wipe the disk from centre to outside and try again and the same...
Do NOT use a system cleaning disk on a Wii. You can ruin the lense and break it.
1. If your disk is not dirty or scratched, try taking it out and turning it around. The shiny side should be facing power/eject button.
2. If that doesn't work, try another disk. If the other disk works, the first disk is either damaged or defective.
3. If the second disk doesn't work, try a third.
4. If the third disk doesn't work your Wii is either damaged or defective. return it or send it to be serviced
Mar 08, 2011 | Nintendo Wii Console
Cd not working say disk not workable
Make sure that you are using a proper audio CD - some players will not work with computer DATA disks, especially re-writeable disks.
Those that do accept computer disks often only like one format either R+ ( and RW+) or R- (and RW-). Most do not accept both.
If your system will not work with any disks, including proper professionally recorded CDs then try purchasing a CD cleaning disk (a computer CD/DVD drive cleaning disk will work okay). It is like a normal CD but with a tiny little brush mounted on it, which will clean the lens of the laser unit as the disk spins.
You can also try cleaning off the lens by opening the lid of the player and using a small paint brush (dry) to remove any accumulated dust.
Feb 10, 2011 | Bose Wave Radio
How i can partation my hard disk
look for a third part software or look here:
http://windows.microsoft.com/en-us/windows-vista/Create-and-format-a-hard-disk-partition
May 14, 2010 | HP Pavilion dv6000z Notebook
Disk spins fast then disk read errer
could be the disk is dirty, you can try cleaning it. or it has too many scratches on it that makes it impossible for the lense to pickup what's on the disk. try another disk to eliminate that it is the disk problem, or the lens is going or gone.
Aug 16, 2009 | Nintendo GameCube Console
Xbox 360 disk drive not working right
Ok, if you are sure this disk is readable and all the other disk work fine, this will confirm optical lens damage. i would replace this optical lens assembly asap. this will fix your issue.
You should know that, if the Xbox states that the disk is unreadable, it may be the disk. if you are positive that this disk is good, simply replace the optical lens assembly.
May 27, 2009 | Microsoft Xbox 360 Console
Problems when trying to play sims 2 torrent (Image Files Mounted)
1st download Sims2v1.0Fixedexe
then copy paste it in the TSBin file after u installed the sims 2
Mount disk 1 & it will work!
Oct 05, 2008 | Video Game Consoles & Games
Dvd writer problem
If everything works fine except that disk then its the disk its self.
either there is a scratch on the disk or it was a bad burn from the manufacturer.
Nov 03, 2007 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
