Question about HP Pavilion dv6000z Notebook
Fire Wire Port
My firewire port will not read my sony camera. It shows that something is going on but nothing will come up as before I could plug it in and within seconds I would have a screen up ready to load the video to the laptop. Any help is appriciated.
  • jwj7055 Nov 05, 2008
    I have used this though to make over 60 dvds from this same camera the same way.... it just does not work now....
  • 186 Answers
First of all, you need to check whether the required Drivers for the Videocam are installed in the Notebook or not.
You should be provided with a Driver Disk along with the Video Cam after installing which, you should be able to connect and use it with the Notebook normally.
If you are not sure about the Driver disk I am talking about, you can contact the Manufacturer of the Video Cam and get the required drivers you need to install.
Hope this helps....
Posted on Nov 04, 2008
My sony PD177 firewire por is Not working, it can't connecting to my PC
The problem with pd 177 its that it can burn the fire wire port and its not able to communicate with the pc you should check that the fire wire ports to see if they are working if they are then its the fire wire port that needs to be replaced.
Check the ebay you might be able to find one there.
hope that helps as my selfe had the same problem .
Feb 12, 2014 | Sony Dvcam DSR-PD150 DV Digital Camcorder
The iLink Fire wire port does not work on my Satellite P305 S8915. I have windows 7 installed and I plugged my external hard drive into the iLink port and nothing happens.
Have you Enabled Firewire on your computer, Also If its Brand new It could be a Faulty notebook Read the manual about firewire and that should help you
May 05, 2011 | Toshiba PSPCCU-05702F Satellite P305-S8915...
How do i make a ieee port on the computer to connect via ilink cable
Well you need to buy the Fire Wire Card from PC World, the card pushes into the side slot and then at the back of your PC you will see the Fire Wire port you now have, you will need a standard Firewire cable and then your all set.
Apr 11, 2011 | Sony Handycam DCR-HC38E Mini DV Camcorder
When i connect my camcorder through the firewire
Hello my friend, yes had same problem, I had hair when it happened to me, now bald hi hi, but you need to go into the PC Control panal, go to System settings, look down a long list eg Sound, Drives, Mouse, etc look at Cameras, if your camera is in the list highlight it, and delete driver with clicking you mouse on it, come out of control panal on PC, REMOVE ALL camera cables from PC, turn off your PC in normal way.
Now when your PC is OFF plug your fire-wire cable in camera, then to the PC, turn camera on, and THEN turn your PC on (MUST BE LAST THING YOU DO) then once your PC is fully rebooted and you are in windows your camera is seen all done.
Take care, all the best.
from
David
Jun 21, 2010 | Sony DCR-HC19E Mini DV Digital Camcorder
DCR-HC52 fire wire port doesn't work. Have tried on several computer, none of them even see the camera. Best Buy tried using a different cable same results
This happens only mostly if you connect camera on Firewire AFTER you been PC okay, so plug your camera in the Firewire sockets then put your PC on, then the PC will open the firewire port up for use and set up a user port adrs for the port.
Jun 05, 2010 | Sony DCR-HC52 Mini DV Camcorder
How to fix Sony DCR TR7000 Firewire port
if you can open camera make sure the ribbon cable from port is seated all the way. if not replace input board.
Jun 02, 2009 | Sony Handycam DCR-TR7000 Digital Camcorder
Do I need a fire wire card for PC
Hi a firewire input is different from an 1394 port. For the laptop you can buy an firewire interface.
Regards,
Rob NL
Apr 16, 2009 | JVC GR-D370 Mini DV Digital Camcorder
DCR TRV310 fire wire driver
FOR USB:
Download Driver
http://esupport.sony.com/US/perl/swu-matrix.pl?upd_id=1452
Install then download and install a video program like movavi videosuite or ulead videostudio (i personally recommend movavi).
Plug in the camcorder and switch it on, put it on play/edit and play the video, press record or capture in the software and let it record!
once the video scene in the camera is done, stop the recording and do what you wish!
GOOD LUCK!
Jun 19, 2008 | Sony Handycam DCR-TRV310 Digital Camcorder
Well i don't have a fire wire connection
To my knowledge there is no simple adapter that would interface Firewire to USB. Though both are high-speed bus, there is significant difference between the technologies involved that they can't be joined/integrated nor is it possible to connect a USB device to a Firewire port either directly or vice-versa. Most if not all on the market are a dual/combination Firewire/USB hub but not an adapter.
Alternately:
1. If your computer is a desktop, there are PCI cards that plugs in to one of your PCI slots whose inputs are Firewire based. Here is an example; or
2. If your computer is a laptop, there are PCMCIA cards with Firewire ports. Here is an example .
Pls be reminded that there are 4-pin & 6-pin FireWire DV Cable.
Hope this be of some help/idea. Pls post back how things turned out or should you be in need of additional information.
Good luck and kind regards.
Nov 19, 2007 | Canon ZR60 Mini DV Digital Camcorder
HP Pavilion dv6000z Notebook Logo
29 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
