Question about Maytag Microwave Ovens
Microwave won't fit under cabinet so I am wanting to set it on top of a cabinet and was wondering how much clearance is needed underneath for proper ventilation,this is the hanging type.
  • Maytag Master
  • 9,098 Answers
You can download Maytag owner's manuals and installation instructions here.
That's where you'll find the answer.
This kind of setup sounds like it could be very unstable, so proceed with great caution.
Posted on Oct 24, 2008
Can the Dacor DCM24 be installed in a 19-inch deep
yes / but install still need some air flow in and around the unit . needs air under neath and over the top / and cannot have 0 clearance in back / / ****
Jan 10, 2010 | Dacor DCM24 Convection/Microwave Oven
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Jun 25, 2009 | Frigidaire FMV156DC Microwave Oven
I have a Ge spacesaver model #JVM1350 microwave that I picked up at a sale, and was wondering when installing if the bolts on top go directly thru the cabinet bottom or is there a bracket? Thanks
I assume you also have the wall mount plate with your oven.
That wall mount carries the bulk of the ovens weight and you normally do use the long screws to bring the front of the oven up to the bottom of the cabinet above the unit. Filler blocks made to fit and to the correct thickness ( to fill the gap between the bottom of the cabinet and the top of the oven) are usually made so that the oven 'nests' snuggly to the underside of that cabinet. Without templates to get holes properly lined up.. they aren't that easy to locate the clearance holes in that cabinet. You can get user manual and installation details at this GE website..
http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
Hope this helps..
Sep 05, 2008 | GE Microwave Ovens
Removing under cabinet GE microwave
Remove the face plate above the door. You will see two bolts where you can use a screwdriver to turn them (unlock them). Those bolts go all the way to the back of the microwave. Once you have turned them (you do not need to remove them), you will need to remove the one - three screws that come in from the cabinet above. You may have to jar it loose if it still stuck.
Aug 27, 2008 | Microwave Ovens
How much clearance do you need to allow when installing a panasonic microwave inside a cabinet and installing a trim kit. The specified cabinet opening only allows about one half inch clearance top and...
That really doesn't sound like enough, but to be sure, you should consult your owner's manual.
If you don't have the manual, you may be able to download one free here: http://service.us.panasonic.com/OperMan
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 26, 2008 | Panasonic Microwave Ovens
Gap between cabinet and top of microwave oven
eastlake...only if you think so. Most of these units use a submounting bracket set and then you hook your oven to it. This is a rather nasty installation...I've done several. If it's sturdy, you may just want to put in a filler piece.
Dec 10, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Installation Advice
The trim kit would be passively vented. I would contact the manufacturer's customer service peoiple for details. You may also need to ask to speak to a technician if the customer service folks can't fully answer your inquiry. See http://www.baumatic.co.uk
Apr 18, 2007 | Baumatic BTM25SS Convection Microwave Oven
Microwave Ovens Logo
52 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
